View Full Version : QA1 coilovers with Moser fab 9 problems
puck8345
01-05-2021, 08:48 AM
I have a 71 Cutlass that I am putting a Moser Fab 9 with back brace and QA1 coilovers on. My problem is the brackets that come with the kit from QA1 have no chance of fitting the Fab 9. Do I need to make my own brackets or does anyone know of a kit that will bolt on to Fab 9. Any help will be great.
dhutton
01-05-2021, 03:28 PM
Pics would better enable folks to help you.
Don
puck8345
01-06-2021, 06:07 AM
Here are some pics, if better ones are needed please let me know183142183143183144
dhutton
01-06-2021, 01:36 PM
Is this what you need?
https://www.moserengineering.com/Super-Shock-Coil-Over-Bracket-Kit---Bracket-notched-for-Moser-Back-Brace.item
Don
Jimmy Sean
01-07-2021, 08:42 AM
What does the axle housing bracket look like without you holding up the QA1 bracket?
I suspect you'll need a bracket like this.
183179
Rod
01-07-2021, 08:46 AM
ummm... just weld it to the bracket? ... or redrill the holes?
csouth
01-07-2021, 10:37 PM
My guess is that QA1 designed those brackets around the GM housing LCA bracket. The Moser LCA brackets are different. I know this because I have a Moser 9 and when I received my Ridetech rear kit the brackets would not line up. I sent Ridetech a pic of the brackets and they told me those were for a 12 bolt. They swapped them out and all was good.
