View Full Version : Large Drive on graphing paper?
speedfreakcobra
12-29-2020, 09:03 PM
Does anybody know what the technical term is for this? I have my car raised up and need large graphing paper to lay under my car. I am trying to find all my suspension pick up points so I can find my optimum settings. Thanks.
CSG
12-30-2020, 06:23 AM
I am going to follow this as I have never seen it done that way. I put a bunch of tape on the floor and make my marks on that.
Tsaints1115
12-30-2020, 12:10 PM
I've never seen paper like that. If it was me I'd be using lots of measuring points and make a pattern from 2x3 sheets. A thought to something that IS that big would be material used to wrap houses when doing siding.
speedfreakcobra
12-30-2020, 02:55 PM
I swear I've seen it in a picture somewhere. For now, I'm using a plumb Bob, chalk, a 5ft level, tape measure and angle finder. Drawing on the ground is kind of frustrating as it gets erased easy. ��
WOLF1732
12-30-2020, 03:15 PM
You don't need paper. you use plump bobs and a pencil to mark the locations on the concrete. take lots of pictures and then move the car out of the way . use your full scale drawing on the floor to make a 1/2 scale drawing on paper. then you can plot out your roll centers , dive angles, Cg's ect, ect
stab6902
12-30-2020, 03:45 PM
Most of the better quality Christmas wrapping paper has 1" grid cut lines printed on the back of it. That's what I'd use if I were in your shoes.
Luckily, you asked this question at exactly the right time of year - 50% off $3.98 at your friendly local Walmart or Target!
https://www.walmart.com/ip/Hallmark-Wrapping-Paper-with-Cut-Lines-on-Reverse-Foil-Dots-20-sq-ft/163170575
dhutton
12-30-2020, 03:46 PM
Something like this?
https://www.geyerinstructional.com/graph-paper-roll-200-ft-1-2-squares.html
Don
speedfreakcobra
12-30-2020, 04:20 PM
Wolf, yes this is what I have been doing. The issue is the car can't move because it doesn't have a suspension.
speedfreakcobra
12-30-2020, 04:24 PM
Don
Don, thanks, I did look at this earlier. I might pull the trigger on this one and attack the grids together. I need a 7 ft wide roll. Hell I might send it out to have it professionally laminated.
raustinss
12-30-2020, 06:53 PM
what kind of car
OldTimer
12-30-2020, 08:50 PM
Way back when I was an industrial design student, we had to do a semester in photography and that included learning all the ins and outs of the art, from film processing to studio work. That's where I learned what a "psyche" was... slang that some pros used to describe a seamless background. That's where you want to look for plain paper up to 140" wide X 36' long. Nobody calls it that anymore, its just "seamless backdrop" paper or vinyl. You can get plain white or numerous colors, and some companies will offer printed material, and that includes custom printing. I actually have two 6' wide x 12' fabric backgrounds blue and black) in my basement that I've used for eBay shots sometimes. Here's a link to get you started.
http://https://www.buy-backdrop.com/attractive-hot-selling-new-design-brick-wall-wooden-floor-vinyl-photography-fashion-background-backdrop-p-4352.html?gclid=CjwKCAiA57D_BRAZEiwAZcfCxUoPYfsCos Lwi7tT-du6dpKF-xge2odwbUWxu9zPkIV7oFnpb3nXcBoCdhQQAvD_BwE
Give these guys a call and tell them about your grid needs. Maybe it even exists, or maybe they can print it. If they can't do it, they probably know who might be able to do it.
Mike
speedfreakcobra
01-12-2021, 09:39 PM
what kind of car
Ryan, it's for a 69 Cobra fastback.
- - - Updated - - -
Mike
Mike, I'm going to give these guys a call. Vinyl sounds like it might work out. Thanks for the link.
speedfreakcobra
01-20-2021, 10:33 PM
I found it. I knew I had seen it somewhere. My memory is a bit obscured though, I thought it was alot longer than what these guys are making. I do think it's pretty cool.
https://dcsperformance.net/unijig/measuring-system/
