View Full Version : Rotary Switch...Anyone know where this switch is sold?
badazz81z28
12-25-2020, 03:45 PM
Went bad in me 5 minutes of use...can’t find it or similar online.
dhutton
12-25-2020, 04:54 PM
Similar switches are readily available. Four terminals: power, low, high and park.
Google wiper rotary switch.
Don
badazz81z28
12-25-2020, 05:13 PM
Don, I googled it and didn’t come up with something similar...can you point me? It’s a 7 position switch.
dhutton
12-25-2020, 06:08 PM
Sorry I thought it was a simple hi lo park switch. Looking closer it has a printed circuit board on the back of the switch so custom. You will need to go to the wiper system manufacturer.
Don
badazz81z28
12-26-2020, 08:47 AM
Anyone know the pinout of the connector? Im trying to figure out how this switch makes the delay work.
cpd004
12-26-2020, 01:11 PM
If you get desperate, maybe try the delay switch from New Port Engineering. I believe there's is a 6 wire switch with one being for a washer and the other ground. Should be wired as power, high, low and park. Who's wiper system do you currently have?
badazz81z28
12-26-2020, 01:13 PM
It’s Detroit Speeds
ween
12-26-2020, 04:40 PM
Appears to be from an older Detroit Speed wiper motor kit, which uses a GM wiper motor. Electronics in the motor assembly performed delay function. Switching various resistances onto an input lead changed delay time. High speed activated a relay. Newer switches have a wash function, wiper motor is from GM also. Don't believe newer switch is compatible with 'old style' motor.
badazz81z28
12-26-2020, 05:03 PM
It is from their old kit, but I just bought it brand new from NPD. I hope DSE has one sitting in a drawer or someone around has a broken kit I can salvage the switch. Hopefully if it’s not avail, the new switch does work.
dhutton
12-26-2020, 05:29 PM
Are you sure the switch is bad? DSE stopped using that setup because of a connection that was failing in the wiper motor.
Don
badazz81z28
12-26-2020, 06:23 PM
Don
I can bypass the switch and the motor works. Trying to test the switch for continuity in all positions and none of them give me a reading. If the switch was working I assume I would at least have high and low...I would think.
dhutton
12-27-2020, 05:48 AM
When you are testing this is the switch grounded? Just a thought....
Don
badazz81z28
12-27-2020, 06:29 AM
Don
Grounded? What do you mean? I’m testing continuity.
dhutton
12-27-2020, 09:30 AM
I assumed incorrectly that you were bench testing it with power. Switch would be grounded in the car, not sure if it makes a difference.
What are you testing continuity with? An ohmmeter? What scale?
So it worked and then died? In the car?
Don
badazz81z28
12-27-2020, 10:00 AM
Yeah, I was adjusting the sweep of the wiper arms and they simply stopped and parked. The switch would do nothing after that. I’m using a common multi-meter. I figured there could be a problem with the circuits in the motor, but if that was the case, I should have been able to turn the wipers on low or high, but can’t. With the switch in high or low, I should have continuity from the power input pole to the switch wire pole, but nothing. If I simply bypass the switch at connect the wires, the motor runs. So I don’t have continuity through this switch, unless I’m totally missing something.
ween
12-27-2020, 04:54 PM
How many positions on the wiper motor connector, and how many wires used?..colors?
badazz81z28
12-28-2020, 09:18 AM
4 wires, 7 total positions. Orange (power), green, blue, and white dotted black.
XLexusTech
12-28-2020, 09:25 AM
https://www.alliedelec.com/product/grayhill/56dp36-01-1-ajn/70217146/?utm_source=google&utm_medium=cpc&adpos=&scid=scplp70217146&sc_intid=70217146&gclid=Cj0KCQiAoab_BRCxARIsANMx4S7x8vZmGZ3f7696rOBR hq9vPfNCGTi7NgPevL2WSyJWfrDtBk4dJKkaAgj6EALw_wcB&gclsrc=aw.ds
badazz81z28
12-28-2020, 09:33 AM
i think I found the source of the actual rotary switch, but no wiper board. So this is a custom piece from Detroit Speed, or they contracted it out? U
XLexusTech
12-28-2020, 09:40 AM
They outsource
badazz81z28
12-29-2020, 04:11 PM
The board was def custom made for them...The switch looks available, I just can't find this one...Some that look very similar...but different. The switch is def bad...The board may be be good and can be soldered on a new switch.
badazz81z28
12-29-2020, 06:05 PM
I figured out the fault. Its the main power terminal on the board to the main power terminal on the switch that's faulty. The wire that is embossed in the circuit board is broken. I jumped it and all the wiper functions work in all switch positions. Now I need to see if this can be fixed...or simply solder a wire from one pole to the other.
dhutton
12-30-2020, 05:08 AM
Just replace the defective trace with a small wire. It can’t be repaired otherwise.
Don
badazz81z28
12-30-2020, 06:50 AM
Don
I'm having a difficult time finding someone with the skills to do that.
dhutton
12-30-2020, 07:06 AM
Any electronics tech can do that. Or a TV repairman, cell phone repair shop etc...
Don
murtah
08-24-2023, 08:38 AM
Were you bale to find a resolution? I fear I may have to scrap the whole system and buy a new wiper set up.
