View Full Version : 1st gen camaro hub recommendations.
Camaros
12-18-2020, 01:13 PM
Wondering what hub to use for 1967 camaro. Just picked up ride tech upper/lower/spindles from here and trying to get the rest of the front kit, plus I grabbed camaro ss 2010-15 calipers too. I think I知 gonna order the adapters from big brake upgrade and would like to run a 18x10 us mags u567 with 5 5/4 bs up front. Looks like big brake upgrade may not sell there billet hubs anymore? Would a wilwood 270-7037 hub work? Thanks
greezemonkey
01-23-2021, 03:13 PM
BBU`s 64-72 hubs are available, plenty of stock!
Camaros
01-24-2021, 08:45 AM
Thanks for the heads up. That’s what I went with and I thought I had the camaro 2010-15ss calipers but BBU got me squared away. They are gen6 calipers and went with c7 z51 rotors through him. I messed up the order a couple of times and he fixed it , really nice and smart guy. I’m going to buy rear setup from bbu when I order a Ford 9 , a ways out on that. Thanks
andrewb70
01-24-2021, 12:31 PM
What's BBU?
Camaros
01-24-2021, 05:15 PM
Big brake upgrade
- - - Updated - - -
I guess it’s all together, so bigbrakeupgrade.
MCMLXIX
05-05-2021, 01:53 AM
talk to Tobin at KORE3 if you haven't picked something yet ...
www.kore3.com
https://static1.pt-content.com/images/pt/2021/05/6778562238_b25ca53695_b-1.jpg
Camaros
05-13-2021, 04:01 AM
Thanks for the heads up. Them kore3 look great. I already went with bbu’s.
Sleeper68
05-19-2021, 04:28 PM
FYI 2015+ camaros use 5x120mm bolt pattern wheels/rotors. The old school "chevy" passenger car pattern is 5x4.75" (5x120.65mm). No they are not compatible. Hope the BBU hubs come with rotors that are 5x4.75" so that your chevy wheels work
Camaros
05-22-2021, 06:28 PM
The bbu billet hubs are 5x4.75 , thanks.
Camaros
05-22-2021, 06:52 PM
189008
mdavidthomas
09-19-2022, 01:04 PM
Were you able to get this brake kit installed? Any issues when installing? Also, what wheels did you end up going with to keep the caliper from hitting the backside of the wheel? Any pics?
mdavidthomas
TheBandit
09-19-2022, 02:03 PM
www.kore3.com (http://www.kore3.com)
Does that center cap pop in with a snap ring or something? My kore3 hubs have tiny screws holding the caps on and I know I'm going to strip them eventually
CarlC
09-20-2022, 08:43 AM
They are held in with an snap-in/interference o-ring. I have a set if interested.
Camaros
11-13-2022, 02:10 PM
Front brakes installed, no issues, worked great. Calipler mounted on back but need to open the whole on the rotor a few thousandths to swallow the axle. Rocket racing wheels , 18x10 front and 18x12 rear if I remember right. Trying to figure out how to post pics again.
Camaros
11-13-2022, 02:12 PM
Car is rough. 203446203447203448203449
Camaros
11-13-2022, 02:53 PM
The wheels do have a center cap , not installed .
sqrlnts
01-03-2023, 06:09 PM
So I believe I have the same wheels and caliper but using a C7 rotor. My caliper is hitting the inside of my wheel. You didn't use any spacers up front?
My setup is using a stock GMSS with a F Body hub that will get turned down.
Rocket Attack 18 x9, 6" backspace
calipers are ATS Brembo calipers
rotor is a C7 JL9 = 12.6 dia, 2.010 hat depth
I am wondering if your 2015 rotor hat (2.40") difference is allowing fitment vs my current C7 rotor hat (2.010")
Camaros
01-08-2023, 08:58 AM
I’m not using spacers up front. I’m not sure on the hub differences, and we’re using different calipers , but I do have clearance between the caliper and wheel. I did go with big break upgrade for their hub , adapter , and rotor and I used a gen 6 camaro ss caliper.
Canadianwraith
02-04-2023, 04:23 PM
Do you have pics of the caliper mount? Looks fantastic
Rb_69camaro
02-15-2023, 01:48 PM
How did you manage the big wheels up front on the stock subframe? I need to do some measuring for rims on my 69'
Camaros
02-20-2023, 04:10 PM
Ridetech tru turn and notching the subframe a little helps some.
