View Full Version : motor angle
chpr1972
12-10-2020, 09:05 AM
What should be the angle that a BBC sits at in a 66 Chevelle. I am having trouble with pinion angles. Or should I ask the question as : what should my pinion angle be and then adjust motor angle to it? Using Tremec gauge on my phone, I have 01.0/ 00.2/ 00.8 front to back and 90 degrees I have 00.1/ 00.5/ 00.4 all in the green. A 1/8th shim either way makes it outta sync! To make their phone gauge phone gauge work, I cut down a paint stick taped to my phone and made holes for the buttons. Works that way. I have 2 mechanical gauges and they hardly move with lots of adjustments. I have adjustable rear upper control arms and a Centerforce? crossmember.
andrewb70
12-10-2020, 04:09 PM
Is your suspension lowered in the rear?
chpr1972
12-11-2020, 07:35 AM
car is lowered all around
andrewb70
12-11-2020, 07:50 AM
Lowering A bodies causes all kind of driveline issues. You basically need to raise the back of the trans as high as possible, but that probably won't be enough. I use a CV driveshaft in my 70 GTO to solve this problem. They are made by The Driveshaft Shop.
andrewb70
12-13-2020, 01:49 PM
I just ran across a view that has one of the better explanations regarding driveline angles:
https://www.youtube.com/watch?v=-FyUwV3uNaA
It's in the middle of the video.
WOLF1732
12-13-2020, 06:03 PM
Normal street car engine with standard oil pan and transmission 3 deg down in the rear. Tha'st the way GM builds the stuff to drain. The pinion angle 1 deg up so on acceleration it will come level. the pinion can be offset left or right 1-3 degs no issue. The only reason to have any angle at all is so the needle bearing will rotate and not wear in one place.
andrewb70
12-13-2020, 07:38 PM
All of that goes out the window when the ride height in the rear is altered from stock.
