View Full Version : FS: Custom Flex-A-Lite Radiator and Derale fan shroud
G5R
12-08-2020, 11:13 PM
SOLD:
Located in San Diego area. Selling a NEW, (never used, only installed) Flex-A-Lite radiator, Flex-A-Lite overflow tank, Derale 4000 CFM fan shroud, Billet Specialties black anodize Filler cap and CSR inline filler neck. Over $1500 invested into the whole deal. Will sell the whole packagefor $700 plus shipping. This is a heck of a deal for the right person.
Flex-a-Lite custom: INFO FROM THE VENDORS SITE: The Flex-a-fitŪ radiator and electric fan combination offers three times more cooling surface and twice the core thickness compared to the stock 2010-2015 V-8 Camaro radiator for significantly better cooling. The 2-row 1 inch radiator is all-aluminum and hand welded for better construction than the original composite.
NOTE: The Flex-A-Lite Rad/fan and shroud Camaro kit fans flow 3000 CFM. We had Derale make us a custom shroud with their fans that flow 4000 CFM for even more cooling.
RADIATOR DEMENSIONS: 32.25 X 18.75 X 3.75. SHROUD DEMENSIONS: 26.5 X 17.15 X6.125. The fan motor sticks out another 1.25"
181954
The rad was designed as a replacement for 5 Gen Camaro but it would be easy to mount on another platform. HOW TO MOUNT THE RAD: One of the neat benefit of the Flex-a-Lite rad are the patent cooling fins on the tank. They give you a lot of FLEX-A-BILITY to mount it. It has screws the slide in-between the fins and allow you to put a "L" bracket either on the front, side or rear of the tank. We actually mounted the rad from the rear making it look as if it was floating. See pics below and hit me up if you have any questions.
Here a link to a Flex-A-Lite Rad/fan Camaro kit selling for $1125 on EBay. https://www.ebay.com/itm/Direct-Fit-...IAAOSwBLlVaRfP
182017
I had the radiator made with no filler cap. We used a CSR billet inline filler. We welded extension for the extension tubing to the CSR billet inline filler and a fitting for the vapor line.(NOTE: If somebody wanted to run the filler cap on the radiator, I can weld one to the top of the tank Radiator)
182014
181948
181949
G5R
12-11-2020, 12:33 PM
Just lowered price from $800 to $700 plus added the overflow tank to sweeten the deal, LOL. I haven't posted it on eBay yet, so I figured I'd pass the eBay service charge as a saving to the Pro-Touring community before I do post it.
astross89
12-11-2020, 03:32 PM
Good seller. Wish I had the 11"s of clearance.
232_ray
12-11-2020, 04:05 PM
PM sent
