View Full Version : Best products and process to fill the quarter to roof seam gap?
67BrewserSS
12-08-2020, 09:18 PM
Hello,
I recently had most of the sheet metal replaced on my 67 camaro. I’ve decided to hold off on body/paint until later in the build and will initially be running with a vinyl wrap. Before I can wrap it I need to smooth out the seams at the quarter panel to roof panel. I know these were originally done in lead at the factory. Curious what everyone recommends using now? I have zero body work experience but think I might try to take this project on myself.
thanks for any help!
67BrewserSS
12-08-2020, 09:24 PM
Also for the roof the a pillar seam.
181943
Sinnister69
12-08-2020, 10:30 PM
I used lead free body solder
I heard of others filling the seam with weld
Others used fiberglass reinforced fillers
All-metal
There are many options
dhutton
12-09-2020, 05:53 AM
I use SEM Carbofil with good results. It is carbon fiber reinforced and has a bit of flex to avoid cracking.
Don
minendrews68
12-09-2020, 06:37 PM
I used lead on all my body work, there and to tighten up the gaps. Regular body filler on straightening out the waves in the body panels
