View Full Version : Custom HolleyEfi 12.3 on 1969 camaro with 69 nova dash pad
frankv11
12-01-2020, 11:42 PM
Upon a lot of trying to get this huge 12.3 Holley Efi Performace screen into a 69 camaro . I am finally done . Its made entirely of .063 aluminum fits stock steering column , it faces driver eye sight perfectly , bolts on to stock location and made to use 1969 nova dash pad which in my opinion is best looking by far.
Making a few of these $3k, $300 deposit gets you on the list. running about 6 weeks out.
Check out YouTube link https://youtu.be/Rz0Q6LVP13E
191219191220191221191218191222
rchaskin
12-02-2020, 04:40 AM
Beyond Awesome!!!!
That is a cool piece.
ryeguy2006a
12-02-2020, 04:50 AM
Wow, those are beautiful Frank!
cam1968327
12-02-2020, 07:55 AM
Upon a lot of trying to get this huge 12.3 Holley Performace efi screen into a 69 camaro . I am finally done . Its made entirely of .063 aluminum fits stock steering column , it faces driver eye sight perfectly , bolts on to stock location and made to use 1969 nova dash pad which in my opinion is best looking by far.
Making a few of these $1500, $300 deposit gets you on the list. running about 6 weeks out.
Check out YouTube link https://youtu.be/Rz0Q6LVP13E181629181630181631
That is some fine work there! Quality looking piece!
214Chevy
12-02-2020, 08:02 AM
Top notch Frank!!
badazz81z28
12-02-2020, 09:09 AM
I wish someone was doing this kind of thing for sec gens
cwylie
12-02-2020, 10:14 AM
Man I wish this would have been out 6 months ago before I bought the Holley can bus gauges. This looks great!
frankv11
12-04-2020, 07:34 AM
Thank you all for the compliments . Im pretty happy with the outcome. The cluster gauge has curvature like the OEM and added as much Dept as possible but the HolleyEfi is huge and flat. So it was tough to make it look good And using that 69 nova dash pad really complimented the flow while bringing a little contrast from those sharp flat areas .
jamminj007
12-04-2020, 09:13 AM
About how long will it take to complete one?
Jonathan
frankv11
12-04-2020, 05:51 PM
Jonathan
Im running about 4 weeks out at the moment
frankv11
12-25-2020, 12:45 AM
Another custom Holley Efi 12.3 .063 aluminum gauge cluster , this one is for 1970 nova which is very similar to 1969 camaro . But car will Need a few very straight forward modifications 182401182402182403
cam1968327
12-25-2020, 06:45 AM
True Craftsmanship Sir!
frankv11
12-25-2020, 08:57 AM
Thank you cam1968327
BK2LIFE
12-26-2020, 06:52 AM
anyone have any of these in actual usage? what does it look like out in the sun? does the screen go blank, is it bright enough to see it? i have been contemplating getting this set up, just curious, because in bright sunny AZ it gets super hot in cars, and mr sun kills thing with screens.
frankv11
12-26-2020, 09:47 AM
You know Holley has put it through its paces used in many Baja racers etc..
BK2LIFE
12-26-2020, 09:59 AM
freebies given to race car drivers for a weekends race doesn't really explain if a near $1500 display piece will do for 2,3,4,5, years from now in a daily driven vehicle with multiple freezing and heating cycles from mother nature.
along with that, if i hold my cell phone in direct light i cant see the screen. If i hold up my autometer gauge in direct light, i cant see it just fine.
So, just curious, in a real life daily driven vehicle, not a 5 hour race across a desert for one day, how well does the holley dash work?
BigBronco
12-29-2020, 09:26 AM
What a snarky comment. I have seen countless cars now running the smaller 6.86" dashes (Pro and regular) as well as the 12.3" Pro.
I just finally picked up a pro to run with my Terminator X on my Nova.
Have you been to an LSfest or ford event lately? Can see plenty of them.
csouth
12-29-2020, 08:25 PM
I have the 6.83" Prodash and the display works just fine in the sunlight. The have an ambient light sensor so the screen actually gets brighter as the light diminishes if you set the brightness set to auto.
frankv11
12-29-2020, 08:38 PM
Thank CSOUTH and BIGBRONCO for shining light on the situation
csouth
12-29-2020, 09:51 PM
No problem. You've made a very nice piece. I actually had to modify my bezel to get my 6.8 in my Cutlass.
syborg tt
12-30-2020, 12:28 AM
Nice work Frank.
Very impressive fabrication skills.
frankv11
12-30-2020, 12:57 AM
Nice work Frank.
Thanks Marty
BK2LIFE
12-31-2020, 02:36 AM
What a snarky comment. .
apologies for seeming snarky.
Was just curious as actual usage from those who have used the digital dashes, if they are good for a daily driver.
I have seen several in cars at car shows/SEMA etc. But have never been in one driving to know if there is any loss of view due to light.
-Sorry to OP for the hijack, the dash you built is high quality, and if i owned the car, i'd buy one asap.
Camarofreak67
01-01-2021, 04:41 PM
I hear you that why I am gonna put a 69 Camaro dash in mine
frankv11
01-01-2021, 06:26 PM
Got a few guys doing the same on theyre 2nd gens and firebirds [emoji106]
drb930
01-02-2021, 08:32 PM
Beautiful!
Will that fit a 5th Gen ElCo or G-Body?
frankv11
01-02-2021, 09:21 PM
Beautiful!
This is specifically for 69 camaro and can be used on 1969 - 76 nova with minor mods
bill1969camaro
01-08-2021, 08:28 PM
Is it paint ready or will it need body work ? Thanks.
frankv11
01-08-2021, 09:27 PM
99% paint ready
frankv11
01-08-2021, 09:32 PM
Little sneak peek at part #01-2021 for very special 1969 camaro ,
YouTube clip https://youtu.be/l9ThXlYzmOc
Will be making these below at $3k plus shipping running about 6 weeks out at the monent.
pricey but each one is about 80 labor hours to produce .
Brief description custom aluminum 1969 camaro Holley Efi 12.3 gauge panel with 69 nova dash pad. These fit 69-76 novas with minor mods to car.
These are custom made pieces using .063 3003 / 5052 AL . Composed of about 30 separate pieces that need to be precisely bent / shaped and Tig welded together without bleeding to inside corners for ultimate clean look . Will mount to stock locations and made for stock 3.5 steering column only and uses 69 camaro steering column lower collar. Very tight clearances for ultimate fit . Unit has overall curvature just like OEM , just very ergonomic in looks and function .
Check out @1969camaroslunkworks for other awesome products for first gen protouring builds
#holleyefi #holleyefidash #holleyefi12.3 #grayareasteelco #rawsteelcamaro #zerowoodinterior #1969camaross #1969camaro #1967camaro #1968camaro #firstgen #camaro #firebird #holleyperformance #jlaudio #camarohoodlouvers #musclecar #customintake #1969camarohoodlouvers #chevroletperfomance #protouring
#coldairintake #lscoldairintake #customkickpanels #jlmicrosub #firstgencamaros #kickpanelspeakers #kickpanels #customholleyefi
183226183227183228183229183230183231183232
csouth
01-09-2021, 09:30 PM
I might have to get with you about the possibility of doing a bezel for my Cutlass dash... I modified mine and used ABS for now. Cutlass piece is much smaller
frankv11
01-09-2021, 10:50 PM
Thank you but for the moment Im just doing this set up. Wish I could help
Just_a_69
01-10-2021, 09:39 AM
Great work. Do you know if it will work in a 69 camaro with the Ididit tilt column??
frankv11
01-10-2021, 09:54 AM
Yes it will work but will have a 3/4 gap around your steering column , I would check with I did it I believe they have a sleeve for stock dimensions
frankv11
02-04-2021, 05:24 PM
Still working my way down the list ,
1969 camaro custom Holley efi 12.3 cluster $3k
Kickpanels $750
Kickpanel speaker buckets $750
JLMICROSUB subwoofer enclosure $350
https://youtu.be/siq-0iowOz4
https://youtu.be/LISbzmNA_SQ
ATTACH]184405[/ATTACH]18440618440718440818440918441018441118441218441318 4414
TANKMASTERJ
02-04-2021, 05:42 PM
As impressed with Frank's fab skills on my hood heat extractors as I am all these photos just solidify it more. Excellent work frank.
Anyone out there needing his skills you will absolutely not. E disappointed.
Jason
frankv11
02-04-2021, 09:53 PM
Thank you Jason , i give it all I got , both on product an service 🤝
EMAC69
02-23-2021, 06:01 AM
Looks awsome bro
kasprzykdc06
04-27-2021, 12:22 PM
What were the minor modifications that had to be made for this to fit in the 70 Nova?
frankv11
04-27-2021, 12:41 PM
Will need to extend steering column 3/8 threaded hangers and drill a hole that will be hidden to attach panel
kasprzykdc06
04-28-2021, 08:48 AM
So does the steering wheel sit much lower then? I assume i'll need a tilt column.
frankv11
04-28-2021, 09:32 AM
Its not very much needed and youll probably wouldnt notice it but tilt would be good
jamminj007
04-28-2021, 05:27 PM
When can I order one?
hp junkie
07-04-2021, 08:17 AM
I just joined this site. This dash was what I was looking for. Can I get a # for the builder of this awesome piece Thanks Kevin
frankv11
08-06-2021, 06:04 PM
The all new 1969 camaro custom Motec mc1212 gauge bezel Description below applies to both Holley efi 12.3 and Motec mc1212
https://youtu.be/YRzLIE2R5Fg
Holley efi 12.3 / Motec MC1212191223191224191225191226191227
Pricing is $3k by order only $300 deposit remainder when ready to ship . Running about 5 weeks out at the moment . -1969 camaro Holley Efi 12.3 gauge bezel to be used with 69 nova dash pad. These also fit 69-76 novas with minor mods to car.
These are custom made pieces using .063 3003 AL . Composed of about 30 separate pieces that need to be precisely bent / shaped and Tig welded together without bleeding to inside corners for ultimate clean look . Will mount to 69 camaro stock locations and made for stock 3.5 steering column only . Very tight clearances . Shipped 90% plus ready for paint. Unit has overall curvature just like OEM , overall just very ergonomic in looks and function .- #grayareasteelco #rawsteelcamaro #zerowoodinterior #1969camaross #1969camaro #1967camaro #1968camaro #firstgen #jlaudio #camarohoodlouvers #musclecar #customintake #handmadeintheUSA
#Americanmuscle #protouring
#coldairintake #lscoldairintake #customholleyefi #customkickpanels #customhoodlouvers #customColdairintake #jlmicrosub #firstgencamaros #kickpanelspeakers #kickpanels #holleyefi #holleyperformance #1969camaroholleyefigaugepanel #holleydash #GAS_co
Build-It-Break-It
08-06-2021, 06:25 PM
Did the price jump from $1500 to $3000 on the bezel? I was waiting a few more months until my car is painted but was considering one.
frankv11
08-06-2021, 07:23 PM
Hi, yes price increased a while back post #134 I think
Way too much labor goes into this things
Build-It-Break-It
08-06-2021, 08:26 PM
Ah OK no problem, I missed that post. I understand, time is money. Thank you for the fast reply.
frankv11
08-06-2021, 08:48 PM
No problem at all 🤝
P dog
11-07-2021, 04:55 PM
I would like to order one what do I do
[email protected]
- - - Updated - - -
How you doing what’s the process to get one going for my 69 Camaro
[email protected] or call 916-798-1419
frankv11
11-07-2021, 05:15 PM
Hi
Feel free to call me anytime to discuss your set up
323-974-5357 Frank.v
frankv11
01-09-2022, 07:42 AM
These is what the 1969 camaro custom gauge bezel Motec c1212 looks like. Made two of these thus far . 195375195376
https://youtu.be/kOaTSDoHfUs
John McIntire
01-09-2022, 08:06 AM
Sick work Frank!
frankv11
01-09-2022, 08:14 AM
Sick work Frank!
Thank you john
jamminj007
01-09-2022, 12:27 PM
Love mine
frankv11
01-09-2022, 01:08 PM
Love mine
Love it [emoji120]
frankv11
03-01-2023, 11:45 AM
Just a few shots of the Holley efi 12.3 for 1969 Camaros 205959 this one here is for Ty Montoyas 69 camaro built by lakeside Speed and Shine in AZ . Debuting on the next Goodguys I believe 205960205961205962205963
frankv11
03-01-2023, 11:57 AM
Small clip of his car [emoji91][emoji91][emoji91][emoji91] https://youtu.be/0l2F62hXjaQ
frankv11
06-17-2023, 07:10 PM
This is what you should expect when you order the Holley efi 12.3 or the Motec C1212 . @emorris69 is joining a very exclusive club with Motec gauge cluster bezel for another of his 69 Camaros [emoji109][emoji631], also running the Holleyefi 12.3 on another 69. The man has got it going on [emoji120][emoji120][emoji120]. ______________Holley efi 12.3 or Motec C1212
Pricing is $3k by order only $300 deposit remainder when ready to ship . Add $300 for the Motec version. Running about 5 weeks out at the moment . -1969 camaro Holley Efi 12.3 gauge bezel to be used with 69 nova dash pad These also fit 69-76 novas with minor mods to car.
These are custom made pieces using .063 3003 AL . Composed of about 30 separate pieces that need to be precisely bent / shaped and Tig welded together without bleeding to inside corners for ultimate clean look . Will mount to 69 camaro stock locations and made for stock 3.5 steering column only . Very tight clearances . Shipped 90% plus ready for paint. Unit has overall curvature just like OEM , overall just very ergonomic in looks and function .- #grayaresteelcompany #rawsteelcamaro #zerowoodinterior #1969camaross #1969camaro #1967camaro #1968camaro #camarohoodlouvers #customintake #handmadeintheUSA
#Americanmuscle
#coldairintake #lscoldairintake #customholleyefibezel #customsailpanels #custommotecgaugebezel #motecc1212#customholleyefigaugebezel #1969camaroholleyefigaugepanel #custommotec #jlmicrosub #motecgaugebezel #1969camaromotec #firstgencamaros #customlt5coldairintake #customlt4coldairintake #holleyperformance #holleyefi123 #holleydash .
https://youtube.com/shorts/jQ4loJaP_N4?feature=share
207961
207962207963207964
Nativefx
07-12-2023, 12:26 PM
Quality work Frank! The cold air intake setup I got from you was just as impressive. I've been looking at trying to figure out how to us the Holley setup for my 68 charger and how it might look. Again, great job!
frankv11
10-02-2023, 09:07 PM
Thank you very much
