View Full Version : Does anyone make a 3/8 GM Quick Connect male to -6AN female adapter?
ryeguy2006a
11-12-2020, 05:57 AM
I'm re-doing the fittings on my fuel pump assembly due to a broken stock fitting and need to find a male GM quick connect to -6AN female fitting. The only one that I found so far is in the UK, and I'd rather not wait 2 months to receive it.
https://www.ebay.com/itm/AN-6-6AN-JIC-6-FEMALE-To-Quick-Connect-3-8-MALE-Fuel-Line-Rail-Adapter-BLACK/382268993419?_trkparms=aid%3D111001%26algo%3DREC.S EED%26ao%3D1%26asc%3D225074%26meid%3Dfef960dee2e34 724ba98b4b623d028ee%26pid%3D100675%26rk%3D1%26rkt% 3D15%26mehot%3Dnone%26sd%3D382268993419%26itm%3D38 2268993419%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A1d14dbe1-24ec-11eb-b095-8a6c6fb3b116%7Cparentrq%3Abcac46c41750a0f053e109a6 ffff3e86%7Ciid%3A1
Anyone know of a US manufacturer that has one? My other choice would be to find a female to female -6AN union fitting with a 1/8" gauge port. I wasn't able to find one of those at all though.
Ryan
dontlifttoshift
11-12-2020, 06:07 AM
-_-
I am racking my brain trying to figure out why you need this. Got a pic of what you are doing?
ryeguy2006a
11-12-2020, 06:23 AM
I had a broken fitting on my Livernoise CTS-V fuel pump assembly. What I did to repair the fitting was replace the factory SAE quick connect fitting with a full flow 90* -6AN. I also need to add in a 1/8" port for my fuel pressure sensor, and would like to then convert back to the SAE quick connect.
Below is what I came up with initially, but I didn't like the 180* fitting after discussing with a tuner. It adds too much restriction, which is what I'm trying to avoid.
https://static1.pt-content.com/images/pt/2020/11/50558767541_cb8c54dd73_b-1.jpg
https://static1.pt-content.com/images/pt/2020/11/50558769441_c9e2f8b6db_b-1.jpg
This is the broken fitting that used to be a 3/8" SAE quick connect fitting.
https://static1.pt-content.com/images/pt/2020/10/50505563527_97e78f5f11_b-1.jpg
Ryan
joeko23
11-12-2020, 06:53 AM
Why don’t you get a female to female T with the 1/8” fuel pressure sensor. One female end goes in your new 6an you glued in. Then the other female 6an will go into the male 6an to 3/8” quick disconnect?
dhutton
11-12-2020, 06:57 AM
Your Vaporworx controller will compensate for the pressure drop through the 180. I think you might be overthinking this.
Don
ryeguy2006a
11-12-2020, 09:47 AM
I was told that having that 180* turn that it was the equivalent of adding an additional 12' of hose. If I can simply add a different fitting now, that can reduce that restriction I'd rather just do it now while it's all apart. I probably am overthinking it, but to me that's what's fun about working on cars haha
