View Full Version : 1969 camaro jacking point weld in ideals
gchank
10-31-2020, 03:46 PM
Has anyone welded in a "jacking" point or somehow "armored" their pinch welds so they don't get destroyed when jacking. I am wide open to ideas but someone out there must have a good idea how to do this....pictures would be great..
F-Body International
11-01-2020, 02:10 AM
Please don’t attempt to jack your car up on the pinch weld. Use your frame sections or rear end.
gchank
11-01-2020, 04:55 AM
I don't as I use anything but those, but sometimes it could be necessary. Nobody fab'ed up a weldable jack point. If you had a jack point, I can guarantee you would use it instead of going to the frame from the front or under a control arm or whatever...
https://static1.pt-content.com/images/pt/2020/11/1703290-1.jpg
raustinss
11-01-2020, 01:36 PM
I dont see how or why you'd ever want to jack a car up by a rocker panel , the point of using the frame and or rear axle is not only are they strong enough... but thats also where the "load" is
