View Full Version : largest brakes for 15 inch rims
1977nova
12-24-2005, 10:13 AM
Hello everyone,
I have did many searches but I have only pieced together information on this subject. What is the largest rotor caliper you can put in a 15" rim? on the 15 or 17 rim post I read that 12.19 wilwood fits and also the 12" corvette fits. Can anyone confirm this? Personally I would like to go with the 11.75 corvette rotors but I would need to make a bracket to mount the caliper as I am using the 2nd gen platform. I just dont have any extra spindles as of yet to make up a bracket. I would like some concrete evidence as opinions seem to wildly differ on this subject so I would like to know if anyone has seen that this works/not works.
Thank you
Mark
Steve1968LS2
12-24-2005, 10:49 AM
Well, I KNOQ 12.19 fits cause we just shot a Mustang II with 15" steelies and those brakes..
Some of it would depend on the design of the wheel..
1977nova
12-24-2005, 01:11 PM
Do you know what type of wheels they are? I would like to use torque thrust or plain steel rally's
osdmike
12-26-2005, 06:26 PM
Hi!
I have Wilwood 12,19"dia. x .81" rotors in the rear. (Ford 9")
Calipers are Wilwood 120-1052 Dynalite(They don´t sell them anymore)
Replaced with 120-6806 Dynalite .(I think ?)
It´s tight , but it works ,with My American Racing Torque Thrust "D", 15x10.
I the front I have slightly smaller rotor dia.(10.75"x.81") with the same calipers,so that´s not a problem.
I intend to put 12.19" in the front in the future.(If possible)
So I hope that will work.
Good Luck
"Osdmike"
Camaro -69
Sweden
TPI Monte SS
12-26-2005, 06:46 PM
If you're using the 2nd Gen suspension up front, you can grab a pair of spindles and calipers off a '91-'95 Caprice, then get a pair of '89-'92 1LE Camaro rotors and have 12" brakes on your car for under $300. :) The B-body spindles are the same height as the F & X-body. Plus, the cop cars and taxis used 15" steel wheels so you know the brakes will clear.
I'm using them on my Monte SS, and for factory-type parts, my car stops very well.
BonzoHansen
01-04-2006, 08:04 AM
It is advisable to check the wheel clearance closely with 15” wheels. I considered the 12” upgrade, but have been told that the 12” upgrade will not fit under my stock 15” 5-spoke Z28 wheels due to the design of the drop center of that particular rim.
I am going to keep it simple until for now until I upgrade the entire suspension. I’ll be using high quality pads & shoes, s/s lines and slotted rotors recommended by Ltorres (Precision Brakes Company – sponsor).
jakespeeds
01-04-2006, 08:43 AM
I had 15" rally wheels with 2" drop spindles and the 1LE rotors and calipers on my Nova for a long time. They were close but fit fine.
Ackattack
01-04-2006, 11:57 AM
I know a lot of the LS1 drag racers run 15in wheels. Most wheels require grinding on the caliper for clearance, but bogarts don't.
BonzoHansen
01-04-2006, 04:19 PM
I know a lot of the LS1 drag racers run 15in wheels. Most wheels require grinding on the caliper for clearance, but bogarts don't.I bet the are aluminum wheels. Steelies seem to have larger drop centers.
1977nova
01-04-2006, 08:41 PM
I would like to use steelies. So it looks like im with smaller than 12
TPI Monte SS
01-05-2006, 04:19 PM
Didn't you read my (or jakespeeds) post above? Certain 15" steelies WILL work. Cop cars came with 12" brakes and 15" wheels, and I know several guys that have the 12" rotors with stock chrome '83-'87 HO/442 15" Olds wheels, and stock '83-'85 Monte Carlo SS steel wheels, along with the '86-'88 aluminum wheels.
Bottom line, measure and find a set that'll fit over the 12" brakes; they're out there.
jakespeeds
01-06-2006, 06:14 AM
I thought maybe I was the only one able to see the post I put up there for a minute. I am just getting my subframe back from the strippers. As soon as the DSE setup is welded in I will be putting the front suspension back on with the 1LE brakes for now. Then I will be able to take a pick with the 15" ralleys in place to give you an idea of the room left. But I never had a problem.
1977nova
01-06-2006, 06:56 AM
Sorry I should have stated that I want the same size all the way around and I was responding to the LS1 brakes.
Mark
jakespeeds
01-06-2006, 07:52 AM
Mark,
You want the same size brakes front and rear? That's not a good idea.
LTorres
01-06-2006, 01:34 PM
Mark,
Jakespeeds,
Why not on the same size rotors front/rear? I am interested to hear what your opinion is on why this is "not a good idea".
LTorres
01-06-2006, 01:38 PM
Jakespeeds,
You should check out what we just put together for the SCCA ASedan class of cars.....just so happens I met a fella off this forum that has become a liason between PBC and the SCCA. If you go here I think you may find my 1LE kits pretty impressive in the 12.19" realm. They are for road racing complete with 12.19" 2 pce rotors, Staggered bore Billet Superlite 4's, Thermlock pistons and much,much more.
go here
http://www.precisionbrakes.com/scca.html
This section of our site is new and has much, much more coming soon..
Let me know what you think?
jakespeeds
01-06-2006, 01:39 PM
"Not a good idea" was the wrong way to put that. "No reason too" would be better. By the way is Nigel still around over there? He helped me out a lot when I was build my brake kit for my Supra.
jakespeeds
01-06-2006, 01:42 PM
I was the one that was all for the 1LE brakes. I am using them on my Nova right now. They work great. Although they are factory rotors and factory calipers.
Jakespeeds,
go here
LTorres
01-06-2006, 01:53 PM
No Nigel has moved on. Do you still have the Supra? We sell alot of those kits through www.horsepowerfreaks.com
IMO same size rotors are mostly aesthetic, we prefer setting up the rotors based on much more than diameters alone. Bias COG, pad compound, vehicles intended use, caliper selection, propvalve, step bore m.c's amongst other factors all play a vital role. Many find out the hard way, other's are already in the know, regardless one guys opinion of the identical system will vary as well.
jakespeeds
01-06-2006, 01:56 PM
Bummer. I know about your kit through HPF. The one I did was a couple of years before that deal. I made the adapters out of 7075 aluminum. I live real close to Wilwood and with there help found a hat that they already stocked that fit perfectly with no modifications. I matched it up with a Wilwood 13 in rotor and there piston radial mount calipers. Damn thing would stop on a dime.
LTorres
01-06-2006, 02:05 PM
You have specs for this...suh weet. I am sure there are many a Supra owner that would like to run that radial mount caliper. Too bad they cost so much, which one's do you have and how much did you pay? Radial mount is mucho expensive
jakespeeds
01-06-2006, 02:17 PM
The new owner of the car does. He bought everything. I used the Billet SL6R Calipers. You guys should know what I paid since I bought them through you! Honestly I don't remember now. I have an account with Wilwood now and just bought another set for my 85 Supra and for my Nova since I will be building a kit for both cars next. They are expensive but I love to stop! When I think of the alternative they seem pretty cheap. And with the cheapness of the average Supra owner I am suprised you are selling any of them at all.
LTorres
01-06-2006, 02:24 PM
I could of looked it up in the archive's but then again I would have needed your first and last name. Is it Jake Speeds?? Just thought it would be quicker to ask you.
You deal directly with Wilwood? Wow, you must do a lot of volume. Everyone else has to go through one of Wilwoods distributors unless you buy large volumes. Cool.
jakespeeds
01-06-2006, 02:30 PM
Jake Reed but the info is probably under Jason Reed. Seems to me it was like 360.00 a caliper. I don't do a lot of volume. Its kind of a long story. I just do a lot of special cars and they would like to make sure that these cars have Wilwoods whenever they can. Is it the caliper hat you would like to know? Since I know your not using a Wilwood hat in your kit. Problem is your kit puts the rotor center in a different place than mine did. So the hat I used would not help you. I was able to hold almost the same centerline as the factory rotor.
1977nova
01-06-2006, 07:01 PM
There is no real reason why I want the same rotors front/back. Its just what I would like. I would like to put 11.75 rotors all the way around but I am just seeing what else is available. Thanks for your input.
Mark
kman67rsss
01-09-2006, 07:43 PM
I have BAER serious street package all around on my 67 camaro, and have stock 15's on all four corners and they seem to fit fine.
I have the 11.75" rotors from the C3 Corvette, aka the JL8 system. Using the Corvette 4 piston calipers, I can put either the original steel ralley wheels or my 17TTII's on with no problem. This is at all four corners. The Vette calipers use different size pistons front to rear to accomplish the correct balance. I love the system. It works great, and there are plenty of pads to choose from.
Ken
69Nova
01-18-2006, 02:37 PM
I have a question. On my car I want to keep 15" wheels and still run the biggest breaks and if possible would like to keep manual breaks instead of power.
Is there somthing for me or am I crazy. And honestly if it will help out I might purchase some 16" wheels but not sure yet. I'm not even sure if I can get some good tires for what I want to do.
Oh and my application is a 1969 Chevrolet Nova that is driven hard on the street and will see some autox and track time.
Thanks for any help.
LTorres
01-18-2006, 04:19 PM
Why don't you just get the 140-2285 Wilwood kit? This would be sweet with 15" wheels.
10.75" rotors 2 pce, Rotor mounting adapters, Billet aluminum hubs, bearings and seals, 4 piston Dynalite calipers, BP-10 pads, brackets, hardware and instructions. $659.95 buy through me and mention this board and get a FREE 6 pack of 570 fluid and FREE shipping (in the U.S. of course).
Here is the with 12.19" kit should you go to 16" wheels($714.95 w 12.19" rotors) and the billet caliper option:
If you go with the 10.75" kit it looks pretty much the same but it has 10.75" rotors. FYI you would need the 10.75" kit should you stay with 15" wheels.
Optionally is the billet caliper shown above. The kit comes standard with a Forged Billet Dynalite shown here:
69Nova
01-18-2006, 04:35 PM
That sounds good to me. Now what about a rear setup.
All I need to do now is decide if I want to upgrade to 16" inch wheels, and wait for my tax return.
Thanks for all your help, you should be hearing from me soon.
70Nova4dr
05-22-2010, 01:55 PM
my GM 14x6 steel wheels clear Wilwood's 140-2285 kit(10.75 rotor and 4 piston calipers), i was surprised they fit, everyone i asked said i needed 15's
BonzoHansen
05-22-2010, 03:26 PM
Holy old thread batman! LTorres, there is a name from the past!
woody80z28
05-28-2010, 12:50 PM
No kidding...and I know by now you finally grew a set a put 1LEs on with your stock 15" steelies! haha
