View Full Version : 1968-72 Chevelle Door Lock Actuator Installation Kits
Modo Innovations
10-23-2020, 08:01 AM
We are pleased to announce the release of more door lock actuator installation kits. These new kits are for 1968 and 1969-72 Chevelles. Like all of our actuator installation kits, these connect the actuator directly to the latch itself instead of the lock rod that exits through the top of the door panel. These kits were designed to work with our MI 700 Keyless Entry Kits. Each kit includes laser cut powder coated steel brackets, 304 stailess steel rods, mounting hardware and detailed installation instructions with templates.
Part number MI 940 (https://modoinnovations.com/collections/convenience-items/products/1968-chevelle-door-lock-actuator-installation-kit) fits 1968 Chevelles.
Part number MI 950 (https://modoinnovations.com/collections/convenience-items/products/1969-72-chevelle-door-lock-actuator-installation-kit) fits 1969-72 Chevelles.
180537180538
lawrenq
10-26-2020, 08:48 AM
Any pictures of an install, I'm interested but it's hard to figure out where these will mount.
Modo Innovations
10-28-2020, 01:51 AM
Both kits mount the bracket below the door latch. The connection point for the rods are different on the two kits due to the crash bar inside the door on the 1970-72 (the latches are the same on the 1969-72). The 1968 connection point is on the opposite side of the latch. Below are pictures of the two kits installed. The outer door skin has been removed for both pictures. On the kit for the 1969-72 (MI 950) the crash bar on the inside has been cut out so that the install can be seen clearly.
MI 940
180636
MI 950
180635
lawrenq
10-28-2020, 04:23 AM
Thanks for the pictures, I have been having issues with my actuators slipping on the door lock rod over time, these will solve that issue, just placed an order.
Modo Innovations
10-28-2020, 05:16 AM
Thank you. That is the exact reason we developed all of our actuator installation kits. Eventually, all of those clamps that come with the aftermarket actuators become loose and slip.
chuckd71
11-02-2020, 05:19 PM
Cool stuff.
Modo Innovations
11-02-2020, 05:46 PM
Cool stuff.
Thanks Stu.
lawrenq
11-04-2020, 04:20 PM
I installed this kit this weekend and I'm impressed, the kit is well thought out and came with everything that you'll need. I used this kit with the spal actuators that I had, I also tested it with some cheap actuators I had and they fit the brackets too. The door locks are more quiet and sound more oem now. I'll be ordering a kit for my c10 next.
Modo Innovations
11-05-2020, 05:10 PM
Thank you for the kind words about our kit. I look forward to your order on the C10 kit.
Thanks again.
