View Full Version : Fuel injector recommendation
Vimes
10-17-2020, 04:25 PM
Seeing as my own project is stalled out, my dad has asked me to replace the 5.3L in his truck with a 6.6L. Can anyone recommend a good, reasonably priced 42lb fuel injector for a Chevy Gen3 engine? Ideally it's something that will fit on a 2001 Silverado without any adapters or anything. The engine should be ready by Thanksgiving, so I have a little time, and I'd prefer new.
JustJohn
10-20-2020, 05:15 AM
That Packard 4 tab connector and Multec 2 short outline is not a common one at all. I looked through our application database and the most readily available injector I can see with the same outline is for a 2000-2003 Chevy S10, which is 23 lb/hr.
If you can space the fuel rails higher for a taller injector, the 1998 - 2002 Honda passport has the same connector but will flow 26 lbs/hr
You really need to convert over to an Amp or USCAR connector to open up your injector options.
andrewb70
10-20-2020, 05:33 AM
John speaks words of wisdom.
I would swap over to a LS7 injector, but as John said, it will need a USCAR connector. The USCAR connectors and terminals are readily available, so with a decent crimping tool and some care, changing the connectors is not a big deal.
Vimes
10-22-2020, 08:59 PM
I fear no wiring project, so I'll look into that. Thanks.
Hotwire
10-23-2020, 04:38 AM
You could send your factory injectors out to get reflowed. People are "decapping" the factory injectors to turn them into 64lb/hr setups. Only difference in the flow rates are the diameter of the holes in the end cap.
Vimes
11-22-2020, 09:49 AM
Unfortunately, my father passed away from a heart attack last week. I've cancelled the project and the truck is now gone.
r67nova
11-24-2020, 06:48 AM
Sorry for your loss.
Vimes
11-24-2020, 12:19 PM
Thanks. It was a real shock even though it was kind of expected. His health had been declining for the last year.
andrewb70
11-24-2020, 12:35 PM
My condolences.
