View Full Version : My 8HP70 swap.
Hakan
10-14-2020, 01:28 AM
Hi, Håkan from Sweden here. Now that i have finished im doing a thread of my swap.
This is the car i made the swap in, 1965 Dodge Coronet 440 with a mild 512cui engine and Holley sniper.
180169
I have a very slow going pro touring project in the garage, same car as above:
180170
I have been wanting to replace the old leaky 727 for an overdrive transmission a long time and in january or so i first heard of successful swaps in Poland of the 8HP70 using the https://htg-tuning.com/ GCU.
This seemed like a good solution since it replaces the stock ECU in the transmission and fully controls it.
So, i started researching and at the time i only knew the 8HP70 could be found in Dodges and BMW´s and since the Dodge ones is very expensive in Europe i went with a BMW (i didnt find any measurments of the bellhousing so i had to estimate from pictures if it was likely to fit).
I got one from a BMW F10 2014 but as soon as i got it home it was clear that the bolt pattern was way to small.
So, after that i did more research and found out the 8HP70 was in a lot of different cars and found a Jaguar XF 2.2D wich looked right in size.
180171
This one was spot on in size, so now i had to fabricate an adapterplate. I found a blueprint of the 727 bigblock bellhousing so i could get the measurments of the engine side from that minus the holes for the starter.
180181
As for the transmission i first tried a method i saw online using a lexan plate secured o the transmission and then using guides in the holes drill thru the lexan to get the hole positions, i then had the guys in the measuring department at work run it in a Zeiss measuring machine. I then double checked the distances between the guide pin holes on the transmission vs the measured and it turned out this method wasnt exact enough.
So i brought the transmission to a company and had them measure it properly, both the bellhousing and the output shaft flange.
(To be continued, got to go to work).
Hakan
10-15-2020, 01:44 AM
I got very precise measurments so i then used Solidworks to make a model of the adapter, since the Jaguar 8HP70 has the torque converter sticking out a bit from the bellhousing i needed to make a quite thick plate.
In conjunction with this i had to get a flexplate with ring gear for the starter since the torque converter doesnt have one. I decided to use one from ATI: ATI915650X used to put GM transmissions on Mopar bigblocks.
Ill write all measurments in millimeters since thats what i use and i dont want to accidently miscalculate to inches and cause confusion.
When i calculated the thickness of the flexplate and how much the torque converter was sticking out plus the needed play in-out of the transmission i ended up with a 35 mm plate.
The flexplate is used with a crank adapter so the center hole is bigger then the crank pilot so i had to make an adapter for this. It adds 2 mm behind the flexplate and centers it.
180182
180183
Also the pilot on the torque converter needs an adapter since its much smaller than the original one, seen in the picture above.
Check to see it mounts straight. I used ARP 200-2902 bolts for the flexplate.
180184
All good :)
Next was making new holes in the flexplate for the torque converter bolts, made on the Deckel mill.
180185
Fits like a glove :) (you can see the flexplate adapter here also)
180186
180187
180188
Hakan
10-15-2020, 02:07 AM
All this took a long time since i had to finish one step before i could do the next.
Got the adapter plate from gas cutting, this is steel since the weight isnt important on this car, its cheaper and i can weld the dowel pins on.
180189
Time to make the holes on the bigger mill at my brothers work. Its made in one setup and the holes for the dowel pins are drilled and reamed straight through to avoid having to flip it over.
180190
180191
I finished drilling and making threads at home.
180196
Testfitting with dowelpins, fits very snug (i later read that 3 pins isnt necessary and you an skip the top one).
180193
180194
Engine and transmission mounted :)
180195
Did a test with an indicator gauge on the flexplate and measuring to the input shaft on the transmission, about 0,23 mm total runout.
https://youtu.be/O_AQvlQgR6E
Hakan
10-17-2020, 01:34 AM
I had to make connectors for the oil inlet and outlet, i used AN6 because the biggest oilcooler i could find at the speedshop had those connectors.
180237
180236
Next was fitting the starter. Since i didnt have any measurments for this i made a plate with welded bolts that fit to the starter and then i aligned it to the starter ring with a nice gap. I then welded the plate to the adapter and made shims to align it in the length axis.
180238
180239
180240
The Jaguar 8HP70 i use have a similar output axle flange as the Dodges but it is a bit smaller so i had to make an adapter for it also.
I used the Spicer 3-2-119 Flange Yoke for 1350 universal joints and had a company CNC cut the adapter, i made the threads myself.
180241
I used 12.9 grade M10 allen head bolts to fasten it to the flange.
180242
And ARP 200-2807 for the yoke.
180243
Hakan
10-17-2020, 02:40 AM
Now it was time to modify the transmission so the GCU can control it, HTG-tuning have made an instruction wich can be found here:
https://drive.google.com/file/d/1vMySoC7SqkrdxqOuGEXvuOwFeSe-BnD6/view
Unfortunately when i did my soldering the instruction said to use thinner wire and they found out later that 17awg, 1mm2 was needed to drive the solenoids so i had to redo some of the cables as seen in the picture.
180246
180247
I used Permatex grey to secure the cables.
On these transmissions the oil filter is integrated in the oilpan, one for the Jaguar was about 110$ or so but since i had heard that all 8HP70´s should be the same in this area i bought a cheap one for a BMW instead at 35$. It fit but one bolt in a corner was a bit tricky to get in, i think it was because of cheap product and not a difference in bolt pattern. And with this in the car for the first time in like 20 years it is not leaking transmission fluid! :razz:
Here is a pic with the oilpan off and the torque converter attached to the flexplate, Bolts are 12.9 grade M10 allen head. The procedure to remove the mechatronic unit is kinda easy. The tricky part was to split the plastic cover to expose the ECU, you have to grind off 2 "knobs" on the plastic to separete the 2 halves. Unfortunately i dont have any pics of this.
180248
When you are done with the soldering and have assembled the mechatronic unit again but before you put the oilpan on you should do a valvetest to see that the soldering is correct. See the testing part on htg-tuning.com FAQ section. Here is my result (poor pic):
180249
Time to see how it fits in the car, since i have my project car in a rotisserie i put the engineblock and transmission on a lifting table and rolled it under to see how much i need to cut out of the tunnel.
180250
180251
180252
180253
The clearance was decent but it was hitting the transmission crossmember, the 8HP70 is much bigger in this area than the 727. I cut out part of the crossmember.
180254
Now i could get it to where it should be but it was very close to the tunnel so i decided to cut it all out and make a new one plus a new inverted crossmember.
180255
180256
180257
Later it turned out i should have made the crossmember a bit higher to allow the transmission to be raised a bit more for better driveline angles, it works for now though.
New transmission mount needed, i could use the outer holes in the transmission crossmember and drilled 2 new ones in new location. I used a Energy Suspension Transmission Mounts 3.1108G and welded up the frame (not the best pictures).
180258
180259
Vimes
10-17-2020, 04:49 PM
Nice work. You're going to like that transmission, but you'll probably want around 3.08 rear gears depending on tire diameter. That first gear's a lot steeper than you had.
Hakan
10-17-2020, 11:25 PM
Thanks. Yes its a great transmission, i have 3.55 now and i might change it in winter. Currently im using gears 2-8 so first gear is actually second.
I have 2100 rpm in 100 km/h.
Hakan
12-03-2020, 07:04 AM
Here is a video of a short testdrive in manual mode:
https://youtu.be/gHw2cBnD4ac
rjsdotorg
07-02-2021, 07:07 AM
180181
Hi Hakan,
Do you have the CAD available?
We have Solidworks and I'd like to mate an 8HP to my 413 Dodge.
Ray
Hakan
07-14-2021, 11:40 AM
Hi Hakan,
Ray
I dont have access to solidworks now but i think the files in the linked google drive map is the right ones. Print them out in scale 1:1 and compare them to engine and transmission before you start building anything.
Also use the correct jaguar transmission, there are a few different ones.
https://drive.google.com/drive/folders/1Vez-L5F0CkL-9xVfdpmNBp38gHnUkp2C?usp=sharing
rjsdotorg
07-14-2021, 12:33 PM
Do you have a part number or Jag year/application for yours?
I'm hoping to use the 8HP70 from behind a Dodge RAM / Hemi, and I will check vs. the Jag patterns of course.
I would not have confidence in the Jag trans mounted in a 12,000lb RV for long...
All of the RAM pickup versions have sufficient GCWR for an RV without trailer, but the model used with the 3.7L V6 is smaller pattern, apparently.
I also spoke with JVX Racing. They may have a big block adapter already to go in a couple of months. He said maybe some adjustments and tests are needed. I think his is for a different model 8HP as it will not need 33mm spacing.
Hakan
07-14-2021, 12:58 PM
I see, if you are in the USA its probably easier and cheaper to get a transmission from a dodge and have it measured and make an adapter or buy one when it gets available.
Hakan
07-14-2021, 01:02 PM
I used one from a 2013 Jaguar XF 2.2 Turbo diesel with article number: CX23-7000-DE.
rjsdotorg
08-26-2021, 07:37 AM
I did pick up a ZF from a 2015 RAM1500 Hemi pickup
191702191703
which of course is a different pattern than the Jag.
But, the 440 and 413 have the same 6 bolt crank and block, so all I need (that I don't have) is the dimensions of that.
I'll see if I can get them from the drawings - ie how much the crank flange sticks out from the block and the flange bolt pattern.
Here is the 413-1 RV block:
191704
Hakan
06-13-2022, 09:13 AM
A bit of an update.
I ditched the HTG-tuning GCU last year because it was crap (they sold it as OEM replacent or better but in reality it was in alpha or beta stage at best).
So instead i bought the Turbolamik TCU and with that it worked extremely well after 45 minutes of remote setup.
I will post some videos of it driving in a few days.
If you are planning to do this swap do not buy the HTG controller, they claim to have fixed the bugs but i wouldnt trust them.
JACB
03-02-2023, 12:45 PM
Great work.
Might the Sonnax 6-Bolt Adapter Flange Yoke T35-ALFY-07 have helped?
sonnax (dot) com/parts/4429-6-bolt-adapter-flange-yoke
Hakan
04-08-2023, 12:52 AM
Maybe, i dont remember to measurments on the Jaguar flange. At the time i did the conversion i couldnt find anything that fit.
andrewb70
04-08-2023, 07:54 AM
A bit of an update.
Can you please post more information and your experience with the Turbolamik TCU?
Vimes
10-28-2023, 12:20 PM
Neat, looks like they build engine adapters to put the 8HP behind various engines that didn't come with it stock, including the LS engine.
https://www.turbolamik.us/accessories/chevy-engine-adapters-domiworks/
Vimes
10-31-2023, 06:08 PM
Asked some questions. https://www.turbolamik.us can either use a CAN signal or a standalone TPS, tach and brake light signals, and they can work with GM Gen 3/4/5. Their engine adapters can bolt to any GM engine, and they make adapters for a large number of engines.
Another company, https://www.bouchillonperformance.com , can do the same but they are a Dodge-centric joint so is unlikely to have adapters.
Both standalone controllers are full, programmable automatic control.
andrewb70
01-14-2024, 10:17 AM
In case anyone is following along, I am installing the 8HP70 in my Cougar using the TurboLamik...
Vimes
01-14-2024, 04:58 PM
Ach, aye, I'll be folllllllllllowing alllllllllllong!
andrewb70
01-15-2024, 06:25 AM
Details starting here:
https://www.pro-touring.com/threads/109464-1967-Cougar-build-(over-700-pictures-and-videos)/page77
Autobahn-Outlaw
01-21-2024, 01:46 PM
I am following, too !
I make the 8HP70 behind a LS3 right now .
Later I need the wiring to the LS3, perhaps with Holley EFI.
How long does it take, to get the Holley EFI working with the Turbolamik ?
dezl
01-22-2024, 10:02 PM
doing the swap now. From what I understand Holley will data through can but not receive. Maxx ecu is much more user friendly for the turbolamik but lots of people use the hokey including myself
Tab
03-18-2024, 01:04 PM
Hello Hakan.
Great thread!
I am also in the process of using the same gearbox for my LS. Jaguar 2,2 8hp70
Also located in sweden.
Would be very helpful with some tips and ideas for this.
Would you be able to discuss the adapter plate? leet me know :)
Hakan
04-27-2024, 12:08 AM
Hello Hakan.
Great thread!
Hi, check https://www.domi-works.com/collections/8hp-adapter-kits, they have kits for LS engines to 8HP.
