View Full Version : 1969 Camaro Full DSE RHS LSX 427 twin turbo, best of the best
classiccarcustoms
10-08-2020, 09:38 AM
I am offering up my 1969 Camaro Best of the best. When I say "no money spared", i mean it, not CPP or RideTech parts.
With that out of the way here we go. The list is long so hang in there.
1969 Camaro, clean CA title in my name.
-Car was taken down to metal.
-Rear spoiler was molded in and laid back.
-Rear bumper was hand built and pocket into the car.
-Side marker light shaved.
-Kindig-it door handles installed.
-Drip rails shaved.
-All factory body spot welds and normal imperfections smoothed.
-Firewall smoothed.
-Smoothed dash speaker grill.
-Body had been primed and blocked 6 times for show car finish.
-DSE mini tubs.
Every part of the car has been mocked up before body work and car was running and driving, then pulled apart for paint. Many hours in to this build.
Now for the good stuff.
Engine & transmission:
-RHS LSX 427 all aluminum block.
-Callies dragon slayer crank.
-Callie Ultra rods.
-Wiseco custom billet forged turbo pistons.
-Mast motorsports heads built by LME to match.
-Titanium instake valves.
-Inconel Exhaust valves.
-8 pac racing valve springs.
-Rpm racing rocker arms with Smith brothers grunion kit.
-Smith Brothers push rods.
-ARP stud kit.
-GP tuning turbo cam.
-Billet timing chain.
-LME billet intake with dual injectors and dual electric throttle bodies.
-LME billet valve covers.
-Nelson 88 mm twin turbo.
-Blow off valve.
-Dome pressure sensors.
-60 m waste gates.
-Magnum T56
-Bullet proof scatter shield.
-McLeod Daul disc clutch kit.
-Billet flywheel.
-McLeod Clutch master cylinder.
-McLeod Clutch throw out bearing.
-Holley Dominator EFI module
-Holley dual injector driver module.
-Holley traction control module.
-Concept-One front pulls set up.
-Stainless work turbo headers.
-Custom 3" Stainless mandrel bent tightly welded exhaust all the way out the back.
Front suspension:
-DSE Hydroformed sub frame, powder coated and complete with coil over and rack and pinion steering, spline sway bar.
Rear suspension:
-DSE quadra link with dual adjustable coil overs.
-DSE sway bar.
-DSE rear tow hooks.
-Mosser 12 narrowed 12 bolt.
Brakes:
-Baer 6 piston front
-Baer 6 piston rear bakes with E-brake.
-Baer re master black master cylinder.
-Hot Rod shop Hydro boost kit.
-Hand built stainless steel lines.
Fuel:
-Ricks custom stainless tank, custom 3 Walbro 450 pumps camaro style module assembly.
-Stainless steel hand built lines.
Extra:
-DSE mini tubs
-DSE exhaust trunk clearance.
-DSE trunk fuel door.
-DSE floor spring pocket braces.
-DSE weld in sub frame connectors.
-Bowler raised transmission tunnel.
-Ring Brothers Billet hood hinges Air frame (Also bought black ones) you pick
-Ring Brothers billet trunk hinges. (Also bought black ones) you pick
-Ring Brothers billet door strikers. (Also bought black ones) you pick
-Ring brother black hood adjusters
-Billet black door sill plates
-Ring brother black billet door vents
-Custom Billet trunk latch.
-Eddie Motor sports billet tail lights.
-Sequential LED tail lights.
-American Auto wire car wire harness.
-NuRelic power windows.
-Ididit tilt steering column.
-Rain Gear hidden wiper kit.
-Vintage a/c kit.
-Vintage a/c 3 knob controller.
-New black stock dash gauge bezel.
-Budnik billet steering wheel.
-R/S front grill.
-American heart beat electric r/s headlight door conversion.
-Anvil carbon wiper cowl panel with vent delete.
-AutoRad complete aluminum radiator support with aluminum radiator, inner coolers.
-DSE radiator close out panel.
-Marquez Hand built front bumper.
-Forgeline wheels 19X12 rear 18X9 front
-Michelin Pilot sport tire.
-Clayton billet pedal assembly.
-Clayton drive by wire pedal assembly.
-Fesler front and rear flush mount glass kit. All body work done to fit the glass.
-New smoked side glass kit.
-All modules and coils are mounted inside the car on custom brackets.
-New factory deluxe door panels.
-Dakota Digital HDX gauges.
-E-Stop Electric E-brake.
-LLC Shop rear package tray wrapped in black leather.
-LLC shop speaker box for DSE car.
-Billet trunk mounted battery bracket.
-Optima battery.
-American auto wire battery shut off and remote jumper leads.
-New factory dash grab handle and trim
-Black or polished or stock Billet R/S headlight door covers.
-New felts, seals, gaskets
-New door latch's
-Power trunk kit
-Billet ride billet left and right outer mirrors.
-Billet ride black billet inside rearview mirror.
Much more i am forgetting.
Car will be painted show quality upside down inside out.
Car will be re assembled, running gear installed and running and driving.
What will need to be done:::
Interior of your choice.
Install side glass and power windows.
Wire in headlights and taillights.
Engine and gauges, battery, a/c all wired in and in working order.
Car will be painted next week.
classiccarcustoms
10-25-2020, 06:34 AM
Ok
Underside is all sealed up and painted tin table bed liner. Went with metallic gray. Firewall this week then take off rotisserie and paint entire car. 180561180562180563
Neuone
11-06-2020, 05:28 PM
Painted yet?
badazz81z28
11-06-2020, 07:52 PM
Very nice selection of parts...I agree it’s funny when people say no expense spared and I see parts that are from from top of the line.
classiccarcustoms
11-07-2020, 03:36 PM
"Is car painted yet?"
I am very very picky, i had body shop block and prime car a couple more times and fix any factory imperfections inside door jams, hood jams and so on. I just sighed off on color and body lines yesterday, they will start to paint the car next week. It is going Gunmetal Grey effect, black z28 stripes
classiccarcustoms
11-10-2020, 12:06 PM
181021181022181023
Body should get painted next week.
Neuone
11-18-2020, 06:30 PM
Looks great!
classiccarcustoms
11-19-2020, 08:08 AM
Thank you. Cant wait to see it painted and rolling again. Went down to body shop and installed all the suspension and brakes.
.182303182304182305182306
97CAIVIAROSS
01-02-2021, 06:56 PM
Looking good! Anymore update pics!? Beautiful car with a lot of nice parts. I’d trade my two for this one. Lol
classiccarcustoms
01-03-2021, 09:03 AM
Thank you.
I will try and get some this week.
I have been out of town. I asked the body shop to hang the door and wet sand and polish the car then I am going to pick up the body and get it running again and install all the parts.
Then I will take back for them to hang the front clip sheet metal. I will post in my build thread. Just another 69 twin turbo camaro...
I posted my build for sale while it was at the body shop and we all know how body shops can stall and even kill a bad ass build. Well that is what happened.
So the owner of the body shop and i sat down and I explained that I want the car done and a #9.5 or higher and if I have to pay more to get that done in a timely matter I will.
That worked for the next 2-3 weeks when I stoped by there was 3 guys working on my 69 and now she is painted.
Looked great when I seen it last week. Those pictures were straight out of the booth no wet sand and polished yet.
I have a couple guys still calling everyday and wanting to purchase the car.
I might sell it or I have a 66 nova and 61 impala.
rodd68
01-03-2021, 09:01 PM
is car for sale still
classiccarcustoms
01-04-2021, 10:55 AM
I shouldn't because i could never buy or do this kind of build again but I would consider it.
Hemi8
01-04-2021, 05:48 PM
Cool ride, love that color, what is the paint color/manufacturer? Looks over the top.
Mike
uwilluz
01-04-2021, 08:35 PM
Can u message me price and/or contact info ?
classiccarcustoms
01-05-2021, 04:46 PM
Thank you.
PPG
Straight out of the gun.
No wet sand and polish yet.
183294183295183296183297183495183496183497
classiccarcustoms
01-20-2021, 09:48 PM
18368018368118368218368318384718384818387218387318 3874183875184006184007
tkkleinjr
01-22-2021, 06:16 PM
Price?
classiccarcustoms
01-24-2021, 08:20 AM
I posted my 69 while it was in paint jail and I was very frustrated. Since it was painted I removed the price and asked ad to be removed. $185k the way it is.
Car is running, all new side glass is installed, power locks and windows installed.
Fesler dash installed, billet ac vents, power trunk, Digital tail sequential led boards, Eddie motor sports billet tail lights.
All seals, felts and rubbers installed.
Lokar billet shifter and ball.
Billet push button headlight switch and module added as well as bush button wiper switch and module.
Billet e brake push button, traction control and trunk buttons as well.
Matching billet switch for power windows in the console.
Everything is wired in and working.
classiccarcustoms
03-09-2021, 10:13 AM
Come get it before interior....
$185k.
I will have all the body panels aligned and installed before it leaves.
Everything is tested and in working order.
Duder69
03-09-2021, 05:40 PM
What’s the PPg color code? This color is amazing!
classiccarcustoms
03-18-2021, 07:10 AM
All pm replied.
Way more parts bought and installed since last update.
Factory rear seat frames are all modified and welded up.
classiccarcustoms
03-20-2021, 08:01 PM
186097
Fenders
Header panel
Billet mirrors installed
classiccarcustoms
03-21-2021, 04:52 PM
186141186142186143186144
Factory rear seat is rebuilt to fit DSE mini tub and Quadra link.
Fits great.
Going after Fesler top dash cap.
Had to dry fit Fesler front glass to double check dash cap. Not perfect. So I will keep trimming.
narkotic
03-22-2021, 02:44 PM
For $185k does that include everything you've done / are currently doing but no interior? Or will that include interior as well.
classiccarcustoms
03-22-2021, 05:48 PM
Includes everything that has been done to-date.
Does not include interior and front and rear glass will need to be installed after headliner is built.
I do have brand new seats for the front and made the factory rear fit the car.
All side glass is installed and adjusted.
narkotic
03-23-2021, 06:42 AM
A challenge to prospective buyers - getting a loan isn't terribly complicated for a classic car, but they will want to do an appraisal. No doubt this car will appraise, but not in its current condition. Not having interior is a challenge.
I've been through this recently - was going to buy a project car (from this site actually) that had great bones, but wouldn't appraise. At the rate the market is going, I'd rather borrow money as it's cheaper than pulling it out and paying cash for anything. So it would most likely need to be a cash buyer.
classiccarcustoms
03-23-2021, 07:25 AM
Never had one problem selling high end projects and completed cars.
My car is going to interior next week. Once done it will be around 240-260k.
I was giving buyer a chance to add his/her spin on interior.
The first person that looks at my 69 in person and knows what it takes to build a car of this calibration will buy it.
It’s not a normal Ridetech, cpp 5.3l or LS1 build.
Good luck on your search.
narkotic
03-23-2021, 08:35 AM
Please don't misunderstand me - your car is bad ass and worth the money.
All I was saying was, to prospective buyers, if they wanted to buy it as-is without interior, they would have to use cash. Doing this as a favor to them so that they don't go and run their credit and find out the bad news.
Unless you're aware of a lender that would go for it, by all means, let me know!
classiccarcustoms
03-24-2021, 05:46 AM
I had the color made. Took 3 days and over 30 spray out panels to get it just how I wanted it. Body shop charged me an extra $600 to do so.
While painting the car, I had them mix an extra gallon of paint for the new buyer if he ever wanted to paint added parts or touch up anything in the future.
narkotic
03-24-2021, 06:33 AM
If you found a buyer @ 185 for as-is, would you be able to put in a seat, headliner, windshield and wipers in case they wanted to drive it home? Or would it need to be brought on a trailer?
LSM3
03-24-2021, 10:40 AM
At $185k, pay the extra $1500 for enclosed transport....
classiccarcustoms
03-24-2021, 10:52 AM
Are you a serious buyer or are you just asking?
Front seats are new and installed.
Headliner-no. Interior shop was going to build me a 1 piece and wanted front and rear windows out until interior is complete.
Wiper arms-no they go on after front windshield is installed.
Wiper motor is installed and wired in and working (rain gear).
I have the Marquez front bumper, hood, wiper cowl and inner fenders all at body shop painted both side body color. Oh and rs grill assembly.
I just need to pick them up.
186218186219186220186221
classiccarcustoms
04-09-2021, 05:27 PM
Fesler gauge bezel done and painted.
Dakota digital gauges installed.
Billet ac vents.
Blue wire automotive push button wipers added.
Blue wire push button headlights added.
Viper 1 touch power windows modules added. 1 touch up and down.
Blue wire automotive power window switch’s all done.
Dash ash tray welded up and smoothed.
Ready for interior.
Working on rs headlight assemblies. 186977186978186979
SCPDaddy
04-11-2021, 12:16 PM
An absolutely awesome build.
I've always been curious (a) how the builds over a certain power level are planning on hooking up at full throttle, and (b) how long it's going to take to change plugs or header gaskets with some of the tighter engine compartments like this. Pretty sure (a) is not and (b) is going to suck.
But burnouts are fun and whoever can afford this can afford to pay someone else to hate the engine compartment maintenance.
classiccarcustoms
04-11-2021, 02:13 PM
Thank you.
Easy I made all the inner fenders removable with out taking fender off.
Plus u can get to everything from under the car. You get what you pay for. Use cheap headers, hardware/gaskets. U will get leaks.
As far as hooking up well that going to be in the tune, tires and driver Experience.
I did add traction control.
SCPDaddy
04-11-2021, 02:43 PM
Good points.
Which traction control system did you use?
classiccarcustoms
04-11-2021, 09:04 PM
Holley
classiccarcustoms
04-16-2021, 03:37 PM
187249187250
She is running.
Everything tested and working.
Just installing RS headlight assemblies and Marquez lower valance.187252187253187254187255
classiccarcustoms
04-25-2021, 05:54 PM
Out with the old original valance, in with the new. Marquez design lower valance.
RS hideaway headlights and HID lights installed
Black billet headlight doors.
Going to start to design front driving lights.
187609187610187611187612
theturboman2010
04-27-2021, 01:33 PM
Beautiful car Sir!!!
classiccarcustoms
04-28-2021, 06:24 PM
Thank you
Billet driving light, take 1. 187804187805
MotorCityMuscleCarz
05-01-2021, 07:38 PM
Thank you
I know that you're trying to sell the entire car and the billet driving lights you've created are just 1/1000 of the project, but they are so beautiful, if you happen to want to make an extra set and sell them to an appreciative '60 pro-touring Camaro owner for a reasonable price, please kindly count me in as a buyer who would gladly respond to a PM. Thanks in advance.
classiccarcustoms
05-02-2021, 05:51 AM
What’s a “reasonable price “ for billet driving lights?
I have a brand new set of MCB “driving light” kit I will sell.
MotorCityMuscleCarz
05-02-2021, 05:56 AM
I sent you a private message. Also, please let me know what the MCB driving lights kit looks like. Thanks.
classiccarcustoms
05-04-2021, 05:18 PM
LLC shop rear package tray and Hertz 6x9
188123188124188125
classiccarcustoms
05-18-2021, 07:25 AM
Audison amps installed.
Custom speaker box built and installed.
Stereo is all wired in and tuned.
Everything was built to be behind full trunk enclosure. “Hidden”
188785188786189105189106
Cop Magnet
05-19-2021, 02:37 PM
This car is awesome. Interesting approach, too--build thread and for sale thread all in one. GLWS.
BanditTA
05-28-2021, 07:12 AM
Beautiful Camaro.......
classiccarcustoms
05-30-2021, 06:32 AM
Thank you.
I had given a big deposit for one interior company last year to hold me a spot for February. They keep calling the day before and stating they need another week to catch up. I had my car set up for s second interior shop last month, they called and stated one of there guys got hurt and they need a couple days to catch up. I have all brand new deluxe interior I might just put in for now and start driving the car. In the meantime i just keep working on this build I.E driving light assemblies, Marquez design lower valance, stereo system.
Next step os tp charge a/c, 2 heater lines, change clamps for upper radiator hose, install inner fenders, grill and bumper, 1 piece headliner and then I can install front and rear Fesler flush glass.
Then I will start driving her.
TANKMASTERJ
06-05-2021, 07:24 PM
Are your fuel lines just stainless tube fanned and bent to fit?.
Flare fitting or?
I'm wanting to do mine in rigid stainless except a shorty at thee tank and at the engine
classiccarcustoms
06-06-2021, 10:58 AM
Stainless tube formed to body and frame. -An fittings at each end.
classiccarcustoms
06-07-2021, 07:57 PM
Take 3 with TMI headliner.
Raptor liner on inside roof then
Dynamat extreme then
Drynamat dynaliner
Then mocked up TMI Suede 1 piece header liner. In and back out 3 times so far. Thought I had it last go around and I turned on the stereo for the kids again and the liner was making a wobbly noise, so out again and I installed Dynaliner on the back side of of TMI headliner as well.
Now in for the fourth time.
I will get installed pictures tomorrow.
TMI headliner and sale panels all installed.
Glass guy is coming tomorrow to install Fesler front and rear glass
189495189510189511
classiccarcustoms
06-09-2021, 02:45 PM
Fesler rear glass installed 189528
Duder69
06-10-2021, 02:36 PM
Very nice and clean! Was wondering if you put the front glass in and how it fits with anivil cowl panel..
classiccarcustoms
06-10-2021, 09:14 PM
Front glass is not fitting to my liking.
I am very OCD. I ditched the Anvil wiper cowl.
Anvil wiper cowl works great with factory window stainless and windshield. Not so much with flush glass.
Crazy Horse
06-13-2021, 06:57 PM
Impressive Build!
Hope you get every penny!
classiccarcustoms
06-13-2021, 09:04 PM
Thank you.
Did a couple pulls on a dyno this Saturday.
Not bad.
841 rear wheel (980 ish motor) HP on 91 pump gas.
At 6,200 rpm 12 lbs boost, 43 psi, 4th gear, 131 mph.
Runs great. Going to make a couple changes and load another tune.
Tried to load the video. Unable to.
garickman
06-14-2021, 08:06 AM
Video or it didn't happen!
syborg tt
06-14-2021, 09:09 AM
What an awesome build !!
classiccarcustoms
06-14-2021, 11:37 AM
Any help on posting it?
garickman
06-14-2021, 05:11 PM
Ha, I don't even know how to post a picture!
slimjim
I like the look with the modern window seal. is it anything special?
classiccarcustoms
06-14-2021, 07:09 PM
Thank you.
Yes, Fesler overside flush front and rear glass.
slimjim
06-15-2021, 04:39 AM
Thank you.
I was referring to the rubber window seal. Just curious if it’s the standard type.
classiccarcustoms
06-15-2021, 05:19 PM
https://www.facebook.com/groups/105073956819424/permalink/791700551490091/
Try this link
rlewis69
06-18-2021, 06:54 PM
I like the Corbeau seats. How do they fit in the car & are they comfortable with lots of support? Did you have to get the bases shaved. I have heard they sit too high if you don't get the bases shaved. I really like the way they look in the car. Beautiful build, keep up the good work.
classiccarcustoms
06-19-2021, 06:21 AM
The Corbeau seats fit great. I am 6' 1" and I didn't have to shave the seat mounting brackets.
I am running a TMI 1 piece headliner.
As far as the brackets the rear bolts are a pain in the butt to get in. If I could say one more thing about the Corbaeu brackets for these seats in a first gen it would be that with my hand in the slide track release and releasing the seat to slide and I slide the seat all the way back, my hand gets pinched between the release handle and the bracket itself. Anyone else have this issue? Before final mount I am going to mill off some of the bracket to get more clearance for my hand.
Support in the seat is amazing. Fit in the car is very nice, I am OCD and when you travel the seat all the way back with out carpet in the car the outer side of the seats (plastic cover) rubs very very minor on the factory wire covers that run down the side of the car, so I cut and re shaped those.
If you need pictures let me know.
Just reshaping my RS grill today and just received my Anvil front bumper. I have 3 bumpers to try: 1-Anvil, 2-Marquez, 3-Endura bumper. I will be selling the other 2 after today.
Then car goes back to body shop to paint the grill and install the hood and polish the car. After that she will be on the road.
classiccarcustoms
06-19-2021, 10:55 AM
R/S grill & headlight door alignment take 7!
I hate being OCD.
Goal is to have it fitted today.
Added SEM plastic repair. Now shape to fit.
18982818982918983018984718984818984918985018985118 9852
classiccarcustoms
06-19-2021, 03:41 PM
Anvil carbon fiber bumper
Take 1189864189865
Duder69
06-19-2021, 03:59 PM
Always wanted to know how good they fit
classiccarcustoms
06-19-2021, 05:10 PM
I have a factory style Endura bumper, Marquez bumper and a Anvil carbon fiber.
I will use one and sell the other 2
I have trimmed and shimmed off and on 8 times the Anvil one.
It’s almost done
srode
06-20-2021, 01:18 AM
Curious why you preferred the Anvil over the Marquez and the factory style Endura?
classiccarcustoms
06-20-2021, 09:07 AM
Ok so when I painted the car I had stock lower valance. Marquez was not available. So I bought endura bumper. And a Marquez bumper. Painted everything.
Then I bought a Marquez valance. Painted it.
Crazy thing is Marquez valance has no provisions for a from bumper, not even his own front bumper. His bumper has 90 deg tabs that I would have to cut a hole in his own valance.
Stock endura bumper. Same I would have to cut off the factory inside mounting brackets.
So I ordered an Anvil one. It mounts through the lower grill mounting holes.
This is why I have 3-4 parts for this car. Lol
189870189871189872189873
Duder69
06-20-2021, 11:28 AM
Anvil 69 Camaro lower valance the way go !
189882
classiccarcustoms
06-21-2021, 04:05 PM
How do you mount the lower part of the grill with that valance
srode
06-22-2021, 02:29 AM
It’s almost done
Sent you a PM about the Endura Bumper is you are interested in selling it.
classiccarcustoms
07-17-2021, 09:42 AM
Hood and Fesler front glass installed.
Next is grill, bumper and make a hood latch
190440190441190442
classiccarcustoms
07-23-2021, 06:18 PM
Almost ready for car show tomorrow
190649190650190651
97CAIVIAROSS
07-25-2021, 10:05 AM
190649190650190651
You got the stance perfect! Car looks amazing. Did I miss the video of it running?
Derek
classiccarcustoms
07-25-2021, 04:57 PM
Thank you.
Don’t know how to post video
compos mentis
07-27-2021, 08:42 AM
Thank you.
A moderator posted this tip on posting a vid.
https://www.pro-touring.com/threads/134766-Video-posting
classiccarcustoms
07-31-2021, 08:37 AM
I will try that.
Thank you
Working on trunk close out panels this weekend.
Goes to Finishline interior on Tuesday for carpet kit and seat covers.
191004191005191006191007
classiccarcustoms
08-01-2021, 09:32 AM
Trunk close out almost ready 191034
classiccarcustoms
08-11-2021, 08:15 AM
Custom German weave carpet kit done.
Leather front seat covers with deluxe inserts done.
Just made new rear seat to match.
191325
classiccarcustoms
08-29-2021, 01:28 PM
Carpet kit and front and rear seat covers all done. 191746191748191749191750
1moretoy
08-29-2021, 01:42 PM
You always have beautiful builds. Have any projects or cars coming up for sale?
classiccarcustoms
08-31-2021, 05:39 AM
Thank you.
My 69 is a amazing car if your looking for an over the top but suttle outside build.
I have a 70 c10 frame off LS and a 66 chevelle I might be selling. Not sure yet.
1moretoy
08-31-2021, 08:14 AM
Thank you.
I recently sold my turbo Ls C10. I'm in the hunt for a few cars. 66-67 nova or chevelle, 70 chevelle or 69 camaro. Your camaro is beautiful but way out of my price range.
Stage7
09-06-2021, 06:04 PM
Amazing build.
JonB
10-04-2021, 12:56 PM
Is the camaro still for sale? How do I reach you? Thx
classiccarcustoms
10-05-2021, 06:04 AM
Yes
831-818-5883
STREETFIGHTER50
10-14-2021, 01:36 AM
Awesome build!! Baddest ‘69 yet!
classiccarcustoms
10-14-2021, 07:41 AM
Thank you.
classiccarcustoms
12-05-2021, 01:32 PM
194393194394194395194396
Took her out today. Put 300 miles on
mario65
12-05-2021, 04:02 PM
Message me the current price please
DWCamaro69
12-06-2021, 02:45 PM
"Took her out today. Put 300 miles on"
Car looks great in that Southern Utah sunshine. Jealous as it's 40 and raining in Oregon and cars are sitting in the shop with their winter covers on :(
ryeguy2006a
12-08-2021, 10:54 AM
Congrats, the car has come a long way. Someone will get a killer ride!
classiccarcustoms
12-08-2021, 02:40 PM
Thank you
classiccarcustoms
12-10-2021, 05:27 PM
Sold
STREETFIGHTER50
12-10-2021, 07:18 PM
Someone just got one of THE Baddest ‘69 Camaros ever built! Congrats to both of y’all!
ryeguy2006a
12-15-2021, 12:20 PM
Congrats! It's been great seeing this car come together.
classiccarcustoms
12-16-2021, 06:02 PM
Thank you
It was a long road. 194723
This was the night she left194724
ryeguy2006a
12-17-2021, 07:01 AM
Bittersweet I'm sure.
JTrevor
12-18-2021, 10:31 PM
I didn’t realize it was still for sale. Absolutely beautiful work. What did it end up selling for?
classiccarcustoms
12-21-2021, 05:11 AM
Thank you.
Car was not cheap.
The new owner is a member on here. I’ll let him chime in if he wants to tell the purchase price.
cam1968327
12-21-2021, 10:47 AM
Thank you.
Car was not cheap.
Beautiful build sir!
classiccarcustoms
12-21-2021, 07:48 PM
Thank you.
On to the next build. 72 K10 (Texas speed LS3550 hp. IFS and 4 linked rear, 71 K20 Duramax IFS front, 4linked rear, 67 Nova.
I have a very very clean 69 Chevelle SS Done car I will be posting.
sheck44
12-27-2021, 04:47 AM
Looking forward to seeing the 69 Chevelle
Cheers
Steve
rlewis69
06-26-2022, 06:42 PM
Those corbeau seats are really nice, are they the black leather or vinyl? The head rests are kinda tall on these seats, from other sites i've seen them on, did you have them cut down?
classiccarcustoms
06-28-2022, 05:54 AM
Thank you. Leather. Headrest removed and covered up. Back of seat cut down 2". Looks great with windows down. I hate looking through the windows and seeing big beats sticking up.
