View Full Version : Conversion from Accel Superram GenVI to Holley Dominator or Terminator X Max
68 SuperRam
10-07-2020, 09:10 AM
Gearing up and planning on a winter project - want to upgrade my fuel management system on my Accel Superram to either a Holley Dominator or a Term X Max.
Was leaning more toward Term X Max - cheaper and not sure I need all the bells and whistle of a Doninator - kindly advise - if you feel otherwise.
Want to keep the same Superram setup - was hoping that someone close to these products could offer any advise or recommendations as I start to think of parts, etc.
350 Superram Setup, small cap F-body Distributor, 4l60e tranny
ryeguy2006a
11-12-2020, 09:52 AM
To run the Terminator X Max, you'd also need to convert your 350 over to 24x crank and 1x cam signals as well as coil near plug for spark. There's a company called EFI connection that offers a kit for that to be done. It would essentially convert your 350 to make the ECU think it's controlling an LS1.
thedugan
11-12-2020, 12:17 PM
Subscribed I have the same SuperRam setup and want to replace my Accel DFI with a Holley system
68 SuperRam
11-13-2020, 08:10 AM
In speaking with the tech at Holley a while back - they indicated that I would require a Term Max X Universal kit - and purchase separately the TPI wiring harness, they did not mention anything about crank / cam signal - but I can inquire.
CapSS92
11-13-2020, 03:09 PM
The instructions seem to say the same thing. Just a TPI harness.
https://www.holley.com/products/fuel_systems/fuel_injection/terminator_x/terminator_x_and_x_max_universal_kits/
ryeguy2006a
11-13-2020, 07:21 PM
https://www.eficonnection.com/home/category/engine-hardware/crank-and-cam-signal-kits/efi-24x-product-line/efi-24x-sbc
Jason_Aschle
12-06-2022, 08:46 PM
I realize that this is an older thread, but I just found it and figured that I'd add some info.
I have a small block / superram setup in my Camaro and am running a Holley terminator X. There is a harness adapter to allow running the factory small cap HEI distributor, so coil on plug is not mandatory. I run the universal MPFI harness from Holley, everything is ultra simple to use !!!
Aschle
12-07-2022, 11:45 AM
Here's an older picture of mine, but it's the same basic setup
CapSS92
12-08-2022, 09:47 AM
Aschle you were able to run it with the small cap distributor? I have a friend with a Ramjet 350 and he hates the computer. It runs rich and only a handful of guys can tune it.
Aschle
12-08-2022, 06:37 PM
yes, it is a plug and play deal with the harness. 204017
CapSS92
12-08-2022, 06:38 PM
Cool thanks!
