View Full Version : Uneven rear spring preload
cwylie
10-05-2020, 08:43 AM
Im running a speedtech torque arm rear with ridetech coilovers. I have almost an inch maybe more preload in the passenger side spring to get it to the same ride height at the drivers side. I cant think of any logical reason for this other than maybe a bad spring. Thoughts?
Pragmatist
10-05-2020, 09:33 AM
It takes scales to properly set up springs.....
cwylie
10-05-2020, 11:34 AM
Yeah to do it 100% it would take scales. Out of all the coil-over setups I have run on different vehicles in the past this is the only one that took significantly more preload on one side than the other.
dhutton
10-05-2020, 05:29 PM
What do the preloads look like on the front? Both the same?
Don
Pragmatist
10-06-2020, 05:05 AM
FWIW my 67 Chevy II has coilovers and one of the rear springs seem to be an inch more compressed than the other. When I finally put it on scales the rear weights were within 14lbs.:screwy:
cwylie
10-06-2020, 06:58 AM
Yeah the fronts are pretty close to even.
10-12-2020, 06:21 PM
Did you disconnect front and rear sway bars before leveling or setting preload?
