View Full Version : Pad Knockback Issue
Sleeper68
09-30-2020, 06:51 AM
Hi everyone,
I have been chasing a pad knockback issue on my 68 Camaro for awhile now. I just blew up the old M21 muncie and now have some time to focus on some things such as this knockback issue.
The reason I believe I have a knockback issue is the car will get a "low" pedal after I take a series of hard corners. The more corners I take without hitting the brakes, the lower the pedal gets. It is very stressful especially when tearing up the mountain roads where I live. The pedal gets so bad that I have actually learned to tap the brakes coming out of corners to bring the pads back up to the top. Once you tap or pump the brakes the low pedal goes away, until the next series of corners. This system works ok on the street but is very hard when autocrossing because the corners come up so fast. I have not yet learned to left foot brake properly (threshold) so I stll RF brake when racing.
Here are my braking system specs:
Master Cylinder, Input system, and pedal:
Wilwood, 7/8" Bore, tandem
No booster
6:1 factory pedal
SSBC proportioning valve
All flexlines are braided SS jacket, DOT approved.
Front
13" J55 corvette rotors
GM short spindles
factory 1st gen camaro drum brake hubs
SSBC D52 Floating Calipers, 2 piston, 43mm bores
Rear:
Wilwood kit WIL-140-12570-R (https://www.summitracing.com/parts/WIL-140-12570-R)
12.2" rotor with integrated parking brake drum
Wilwood D154 floating caliper, 2 piston, 1.125" bores
semifloat axle by Moser
Factory style axle bearings
2psi residual pressure valve (RPV)
One day I attempted to determine which end or corner of the car the knockback was coming from. I did this by taking a series of hard corners then slowing down using the engine only. There was a pull of up hill so I used the hill to slow the rest of the way. Once stopped I turned the car off and left it in gear. I then walked around the car and grabbed each of the calipers and attempted to move them, both inboard/outboard and fore/aft. The fron calipers were pretty dang tight and did not move much. The rears however had slop to them inboard/outboard. I then got back in the car, pumped the brakes 2 times until they felt fully firm and the pedal "up" and repeated the walkaround. The rear calipers were now tight like the fronts. At the time of the test, the prop valve was set 2 turns from full pressure to rear brakes.
This all leads me to believe the source of the knockback is the rear even though it is the end with the single RPV. THE RPV is plumbed just before the "tee" fitting on the axle.
My question is: What now?
I have a 4psi and 10 psi RPV. I also have another 2psi RPV. Thinking about trying the 10psi valve first, then if it works moving to the 4 psi valve.
Please let me know what your thoughts are. Thank you.
Ryan
andrewb70
09-30-2020, 07:59 AM
Is it possible that the rear caliper is not centered on the rear rotors and you are running out of caliper float range?
ilikeike
09-30-2020, 08:53 AM
Seems like you doing what you can already, residual valve, floating calipers...What Andrew posted above seems like something to look into.
I was thinking about going to the same caliper you're using now, My Wilwood Dynapro calipers where giving me some bad pad knock at the autocross track (my GM metric floating calipers didn't) I put springs behind the caliper pistons, it helped a tiny bit, I might try a residual valve next before going to a floating caliper. I also run a manual 7/8" MC.
A floating rear is on the wish list, I blew it cheaping out on that when I installed the Torque Arm rear suspension last year.
Pumping the brakes when autocrossing sucks and adds time for me.
Sleeper68
09-30-2020, 10:15 AM
That is an interesting point. The caliper is definitely centered on the rotor because it has to be. The pads center it. But it is very possible the caliper is not centered on the available travel of the slider pins. I would hope so since the is was a purchased kit, but I did not check that explicitly.
I'll check it out. Thank you.
Do think a 10psi RPV is too much for rear disc brakes? Wilwood said they sell the 10 psi version for drum brakes typically
andrewb70
09-30-2020, 11:28 AM
Don't know about the RPV, but I can see their bracket being a little off, so the caliper is not necessarily centered on the slider pins. I'd double check that.
stab6902
09-30-2020, 12:04 PM
Depending on the design of the caliper piston seal and seal groove, 10 psi might be enough to cause brake drag. A very small amount of drag is okay, but you don't want to be in a situation where the rear brake temps go up as you're cruising down the highway for example.
Given your problem, I'd be inclined to start with the 10 psi RPV as well. As long as the car still rolls freely and the brakes don't heat up from dragging (use an IR thermometer on the rotor) you should be fine.
Sleeper68
09-30-2020, 01:46 PM
Interesting you bring up seal design. I believe the seals are square cross section orings, likely with a brake caliper specific "squish" specification, possibly based on the D154 GM caliper it is descendent from. I can ask Wilwood. What about the seal design in your opinion affects drag potential? Deflection of the seal and non linearity at low fluid pressures? If so that could be the cause of the lack of reaction force to piston compression and thus the knockback @ 2 psi.
The total piston area of the rear calipers is 1.99 sq in each, so lets say 2 sq in to make it easy. @ 10psig line pressure we would then have a "normal" force on the pad of 20lb. The friction coeff of the pads is about 0.43 so lets say 0.5 to be conservative. That equates to 10lb of friction on each pad. Doesn't sound like alot but maybe it is enough to see cause non trivial drag. The efective radius the pad acts at is about 5.5" or 0.46 ft. The total pad frivtion force would then be 10lb * 2 or 20lb. 20lb * 0.46ft = ~9.2lb-ft. This would be on each wheel, or ~20lb-ft total.
I would think the air movement alone over the rear calipers and the heat sinking of the rotor would hide the drag from a thermal point of view. Your idea to feel it out by pushing the car is a good one.
Will attempt 10 psi RPV after checking the slider travel.
Unfortunately my Muncie decided it was time to leave this world a few weeks ago so I need to get the new trans in before any road test anyway.
Thank you
Ryan
GoodysGotaCuda
09-30-2020, 01:54 PM
I have the same problem with my rear Wilwood brakes. I tried 10# RPV for a short period before removing them. I felt that the drag was noticeable and the rear brakes were unable to effectively shed heat.
After a series of braking test I did a "cool down" period and monitored the temps. The front brakes were substantially cooler than the rear. My theory is the RPV drag was causing the increased temperature and I removed them. I have played with trying to tighten my bearing lash on my semi-float axle, which has helped a hair...but not a lot.
I've just chosen to live with it and check-up the brakes after reasonable turns. It's habit now.
stab6902
09-30-2020, 04:19 PM
Ryan
I'm not an expert on caliper piston seal design, but as far as I know, they are all square in profile, and the design of the seal groove has more of an impact on behavior than the seal itself. Here's a white paper on the topic if you're interested in more detail (not my paper btw, just stumbled on it looking for figures to illustrate what I'm talking about): http://www.simulia.com/download/solutions/automotive_cust%20references/brakes_analytical_auc03_delphi.pdf
Sleeper68
10-01-2020, 05:51 AM
That sounds like pretty significant drag. I think I'm going to try a call with Wilwood again once I verify the silder travel. The travel is a bit tight on the inboard side, but performing a free body diagram analysis of the caliper body didn;t net an explanation for any piston compression.
You say you were able to significantly reduce axle float in your housing and you're still experiencing a lot pad knockback. This is a little concerning because to me it means the movement of the rotor is coming from the axle's deflection... Much more difficult to address. Maybe it is full floater time.
Very interesting read. You use alot of engineering rhetoric. Are you by chance one?
My hope would be that Wilwood has the seal/groove design thing down. It is a pretty critical component of the caliper's design.
stab6902
10-01-2020, 07:20 AM
You caught me lol. I was a brake system vehicle test engineer for several years at a tier 1 supplier. I agree with Wilwood's point that you generally shouldn't use a 10 psi RPV with discs (production cars don't use any RPVs at all), but they might get you by for awhile until you can address the root cause at the axle. I don't think there's anything "wrong" with the design of the seal grooves or calipers - no calipers are really designed to deal with the discs moving around underneath them.
Sleeper68
10-01-2020, 08:01 AM
Nice. I have also worked for a Tier 1 Automotive suppliers (JTEKT and MAHLE) as a co-op student. Very interesting line of work. We had a machine go down. Had trouble getting part out of it within BMW' spec. We then shutdown the BMW line and they set us a bill for $2M. Glad I'm not in that realm as a professional. I do medical devices now.
The 4 psi RPV may be the sweet spot.
My hope was the floating caliper design would be enough to alleviate the knockback but it appears I am wrong. Do you think the movement of the rotor is mostly axle thrust play or axle bending moment from vertical and horizontal forces (mainly cornering)?
This car can generate about 1.1 g steady state. Rear static corner weights are about 650lb. I anticipate weight transfer at that acceleration of 350-450lb.
stab6902
10-01-2020, 09:37 AM
If the amount of knockback gets proportionally worse as you corner harder, I'd guess mostly bending. If it happens even during easy street driving, I'd guess mostly axle play. I'm assuming end play etc feels/measures tight with the car on jack stands?
Sleeper68
10-01-2020, 10:04 AM
I am not sure if the knockback gets much worse as cornering accel goes up. What I do know for certain is the knockback gets worse as the number of corners taken without braking increases. Mountain roads are the worst; especially after a series of corners through which the brakes were not applied. The knockback is nowhere near as bad when autocrossing, seemingly because the brakes are used much more often, maybe 2-3 turns max between brake applications.
Even a sustained "interstate" corner at highway speeds can generate some perceivable knockback.
Axle thrust play is approx 0.030-0.060" each side from my recollection. I will verify with an indicator.
