jwcarguy
09-27-2020, 07:30 AM
Project part out:
have a project that has been cancelled after a few years and selling off parts from it
-"1993-97" version Chevy LT1 350/ 383 (havent verified if a stroker yet) crate engine with one hour run time on it,("327" block casting #) it has a Delteq/ MSD opti-spark delete /conversion setup, ARP bolts, upgraded valvetrain, Arizona Speed & Marine 52mm TB, aftermarket accessory drive kit, new long tube headers, standalone engine harness and pcm (Turbo city), Corvette intake manifold w/ upgraded fuel injectors, Aeromotive fuel regulator, upgraded cast aluminum 90 degree air intake tube & filter, IMI Hi Torque mini starter
Asking $3500
- Have a Chris Alson/ Chassisworks "Sportsman 4-link" 3x2 Box Tube 32" Rear Frame Clip, w/ "Gold Bars" & heims, has dropped front crossmember w/ driveshaft safety loop, doble adjustable panhard bar, pair of Koni Drag Coil Over Adjustable Shocks and Springs, adjustable lower shock mounts with optional back brace supports, new Ford 9" Rear Axle assembly (54.25" wms to wms) w/ "new style" Big Torino ends, 4.11 posi ,31 spline axles, Billet upper Fill and bottom drain plug option, SSBC Rear Disc Brake kit with emergency brakes on calipers, brake lines & hoses on installed on rear, currently attached to a Chevy Luv truck chassis
driven approx one mile on setup, until parked
Asking $2500
I will be posting a 700r4 built trans w/ stall convertor and Genies Shiftters setup, w/ e-brake also
have more pics on request
in Las Vegas, NV
pm/ call/ text (702)677-4085
Asking $3500
Asking $2500
in Las Vegas, NV
