View Full Version : Auto X with a cracked windshield?
69camarokid
09-21-2020, 06:14 PM
Hi Guys!
Im about to do my first AutoX event and I am very excited!
My Camaro currently has a small (Under 6") crack in the lower driver side section of my windshield.
I am wondering is this will cause me to fail tech inspection (Assuming they have one?)
Basically Im just trying to find out if I'll need to replace the windshield before the event, because it would suck to drive out
2 hours to the event and then be turned away due to the windshield.
Any advice would be great. Thanks!
SSLance
09-22-2020, 07:49 AM
I work tech at most of our SCCA autocross events and I can't imagine ever failing a car for a cracked windshield. You should be fine...
F-Body International
09-22-2020, 12:41 PM
Common F-Body problem. I hope you have solid body mounts and frame connectors.
69camarokid
09-22-2020, 07:01 PM
This is what I was hoping to hear. Thanks!
- - - Updated - - -
Got some Polyuerathane mounts and weld in sub frame connectors. Rock on the freeway started a small crack and the hood surprise falling shut on me expanded the crack recently.
Thanks for the good looking out. Much Appreciated!
Chad-1stGen
09-22-2020, 07:48 PM
You should be fine
69camarokid
10-02-2020, 01:33 PM
Did my first AutoX event! I had an absolute blast! Thanks everyone for the info! Woot woot!
https://www.youtube.com/watch?v=6iPMQbmjnX0
badazz81z28
10-09-2020, 09:03 AM
Huh??? Common?!?!?
10-09-2020, 05:42 PM
Huh??? Common?!?!?
Do you have an explanation as to why people have problems with the lower corners of windshields cracking with more power, wheel hop and old suspension?
jameskerley
10-13-2020, 08:48 PM
Safelite was very good to us.
BMR Sales
10-14-2020, 12:49 PM
When you add Power, you will create more Flex in the car - this can lead to Windshield cracks.
adding Subframe Connectors will greatly reduce this flex!
