View Full Version : Richmond 4+1 complete was behind LS
Benttube
09-13-2020, 02:09 PM
Sold
Richmond 4+1 was behind 5.3 LS and worked great. Went a different route with that car. Includes LS flywheel and clutch, Wilwood hydraulic throw out bearing and master cylinder, shifter and old model aluminum bell housing
If shipping buyer is responsible for arranging. I will package it and take it to terminal or arranged pick up location.
Located in Sale Creek, TN
showdog75
09-14-2020, 01:43 AM
Nice to see someone from my area on here. Hixson here
Camarosal
09-15-2020, 08:50 AM
Not to familier with that tranny 4+1 what does that mean overdrive?
Benttube
09-15-2020, 01:52 PM
The 4+1 is not an overdrive. It is just a 5 speed with lower gears that works well with a higher rear end ratio (lower numerically).
I would definitely be running this one if I didn’t already have a 3:70 rear gear and planning on a relatively short tire (335/30/18).
vcho455
09-15-2020, 08:11 PM
Which version of the DN 4+1 is yours, crash box or synchro version?
What ratios are installed?
Is the shifter the H plus 2 or the ratchet style?
Are you willing to sell without the LS components?
How long along ago was it gone through and what kind of use has it seen?
Benttube
09-16-2020, 09:21 AM
vcho455 - I honestly cannot answer the majority of your question. I posted the only external casting and stamped number I could find in the pictures. If you have any way of telling which options it has I will try to find out.
I am not aware that it has ever been gone through. It was in a car I bought and run and drove great.
Benttube
09-20-2020, 01:30 PM
Found the chart below online for Richmond ratios and counted the revolutions between input and output. Definitely seems to line up with the 1st 1:3.29 column.
TANKMASTERJ
09-20-2020, 05:12 PM
Probably be great with like a 2.73 or 3.08 rear
ImaBadMan
09-23-2020, 12:36 PM
I can't make out the part number starting with "7". Can you clarify that so we can look up which trans this is? I'd like to find out the torque rating.
Benttube
09-23-2020, 04:34 PM
Looks like 71-58112
Benttube
10-10-2020, 01:39 PM
180066180067180068180069
Benttube
12-31-2020, 05:32 PM
Bump
Benttube
02-05-2021, 05:08 PM
Sold
