View Full Version : Which ptfe lined fuel line do you like or hate?
mc1984ss
09-09-2020, 08:20 AM
Currently working on my stainless hardlines that run the length of the car. I want to use ptfe lined hose to connect to the engine and fuel tank. There are a lot of choices these days! What are your experiences good and bad, any I should stay away from? I want to buy once and never have to replace them. Thanks in advance
anguilla1980
09-09-2020, 11:01 AM
I had been using Holley Earl's and Mr Gasket hoses and fittings for fuel, but I recently switched over to HotRodFuelHose.com and their stuff (for just my PTFE fuel lines). Great stuff for a very fair price.
I still use Holley Earl's and Mr Gasket for everything else.
dhutton
09-09-2020, 11:25 AM
I use Holley Earls Vaporguard. Not a fan of the stainless wrapped Teflon lines. The Vaporguard has an OEM look.
Don
carbuff
09-09-2020, 02:17 PM
For PTFE line I liked the product from Pegasus Auto Racing. Their 910 product line is lightweight and was easy to assemble with their fittings. I used it for all of my fuel lines and rear axle and gas tank vent lines.
ULTM8Z
09-09-2020, 03:31 PM
I went tank to rail with Aeroquip about 12 years ago with zero issues. Put heat shield wrap around the line anywhere it got remotely close to exhaust.
anguilla1980
09-09-2020, 03:54 PM
Which heat shield did you use? I need to make a buying decision on that for a new engine I'm putting in next month and I have no idea which will block and at the same time not soak and hold it in. It's for a road race car that will be singing at high RPM and the headers will be coated.
ULTM8Z
09-09-2020, 04:44 PM
Basically just the DSE wrap with the velcro. Fiberglass with metalization on the outside. Wrap it around the lines and secure with the velcro.
CarlC
09-09-2020, 07:12 PM
That hose, both the 810 and 910, are made by Goodridge. Far and away the nicest PTFE hose I've ever worked with. The hose can practically be tied in a knot and the fittings install so easily it's crazy. Like good tools though, you will only cry once.
anguilla1980
09-09-2020, 07:25 PM
Gotcha, I've used that before years ago. Thanks
ilikeike
09-10-2020, 07:10 AM
I really liked the Earl's Ultra Pro the last time I made some fuel line changes, but the black -6 is no longer available due to some supply issue, just the SS braid in that size. I think it's the same as the Pagasus/goodridge stuff with the ribbed inner hose liner .
It's really light and extremely flexible, it is a little more costly than some.
https://www.holley.com/products/plumbing_an_fittings_and_hose/hose/ultrapro/
70Uglybird
09-10-2020, 07:25 AM
HA! I Just placed my order yesterday for thr 810 and fittings for my setup....and yes I'm not too proud to admit that I cried a little. The 45 degree fittings should be platinum for that price :)
OLDFLM
09-10-2020, 09:30 AM
Goodridge 910
