View Full Version : 1970 Chevy C10 Pro Touring Build - No Limit frame
1slogoat
09-07-2020, 11:33 AM
https://www.youtube.com/watch?v=6Rd5miSeac8&t=393s
Body
-Clean title with current CA tags
-Frame that came with the truck was not original and was twisted/parallelogram
-Original bed was in very poor condition, no bed included with sale
-Cab was put on a rotisserie and has been sandblasted and epoxy primed
-New inner and outer rockers
-New cab corners
-New smooth cowl panel (fiberglass)
-New custom firewall inserts
-Floors are solid with no rust
-Drip rails shaved
-Cargo lamp shaved
-New doors, hood, fenders, radiator support
-Stainless hardware kit for front end
-Porterbuilt hood hinges mounted on firewall
-Energy suspension cab bushing kit and new hardware
-New windshield
-New flush fit back glass kit
-New Precision weatherstrips for doors
-Ididit tilt steering column
-Original bench seat in decent shape
-High hump transmission cover by Slosh Tubz
Frame/Rolling Chassis
-No Limit C10 Pro-Tech Chassis (*high kick rails in the rear--bed floor will need to be raised)
-Setup for LSX family of engines
-Can mount a variety of transmissions
-Fuel tank with high flow pump capable of 800 rwhp
-Dual 3/8" fuel lines
-9" Floater rear end with Eaton True Track 3.30 gear ratio, Moser Axles
-Front and Rear Splined Sway Bars
-14" Wilwood 6 piston calipers, rotors and pads, 5 x 4.75 hubs
-14" Wilwood single piston rear caliper with integrated parking brake
-Frame has been powdercoated "Black-Magic"
-4 Link "Fat Bar" with heim rod ends
-Battery box with drop out battery tray (mounts in rear of frame)
-Flaming River road race rack & pinion steering rack
-Frame is set to accommodate up to 10-11" wide wheel up front, 12" in rear
-Total from No Limit for the above parts was $22,000, took 6 months to build
Currently has a 6.0 LQ4 with an Isky cam, springs, etc for boost, 4L80E with a Jake's 2800 billet stall converter and HD2 shift kit. Also have a KB Racing turbocharger kit with a Borgwarner S475 Turbo and 1000 hp Treadstone intercooler. I also have an Entropy LS Swap radiator/fan setup, Holley Dominator ECM plus wiring harnesses and sensors, new 80 lb injectors, LS6 manifold and throttle body, Holley front engine accessory kit. Goal was to make 700-750rwhp. Receipts and invoices all available.
$37,950 for everything
Located in Chatsworth, CA
[email protected]
​​​​​​​ ([email protected])
1slogoat
09-12-2020, 09:54 AM
Price dropped to $34,750. I'm likely going to start selling off drivetrain parts separately, including the turbo kit.
1slogoat
10-08-2020, 06:40 PM
Bump
1slogoat
10-13-2020, 05:34 PM
Price lowered to $37,950 for the truck and everything I have to go with it.
1slogoat
11-07-2020, 12:08 PM
Truck sold!
