View Full Version : O-Ring vs. Inverted flare on power steering box
Cheveezy
09-07-2020, 09:49 AM
I just ordered a borgeson box that takes o-ring style fittings but also comes with the adapters for inverted flare. I already have hoses with 6AN so I am asking which would be the preferred way to go, o-ring or inverted flare? My gut tells me inverted but thought I'd ask the pros.
Cheveezy
09-09-2020, 05:35 PM
Anyone?
Tsaints1115
09-10-2020, 06:39 AM
Maybe call Borgeson directly?
Lonnies Performance
09-10-2020, 06:49 AM
You can get adapters from o-ring to -6 AN like this from Summit to use your -6 lines.
179200
https://www.summitracing.com/parts/sum-220009b
I've used them with good results.
The inverted flare adapters will be similar to this but also require new lines.
Cheveezy
09-10-2020, 09:53 AM
179200
Thanks. I already have inverted flare fittings with 6AN hose ends and Borgeson sent the inverted flare adapters. My question is which is a better option based on experience, o-ring or inverted flare?
stab6902
09-10-2020, 10:58 AM
It's really six or a half dozen. Since it's an O-ring box I'd stick with that. The O-ring setup requires less torque to seal (which is probably why GM switched to it), and you won't have to use an extra adapter.
Cheveezy
09-10-2020, 01:12 PM
Good input, thanks!
