View Full Version : headers for Schwartz chassis LS tall deck 68 Camaro dry sump pump
adamkphillips
09-04-2020, 10:07 AM
179017179018179019179020Custom 2" SS headers for Schwartz chassis LS tall deck in 68 Camaro with dry sump pump. 4" V-band $2000.00179026179027179028179026
TANKMASTERJ
09-04-2020, 02:24 PM
I'm going to call Dale and see if maybe he thinks this would work for my LS7 with speedtech pro touring subframe
TANKMASTERJ
09-04-2020, 02:26 PM
Would you mind measure from top of flange to bottom of collector and from frontal most portion of flange to frontal most portion of down tubes where it turns toward rear. Trying to calculate if it would clear my rack and pinion and if height would be an issue since ypours is tall deck
adamkphillips
09-04-2020, 03:12 PM
I will get the measurements (as best I can) tomorrow. Just FYI tall deck is 1/2 taller than standard. These were built specifically to avoid the Daily dry sump pump
TANKMASTERJ
09-04-2020, 05:17 PM
I don't think a. 1/2 height Would kill me.
And I probably should just order speedtech headers but the below has me not wanting to buy anymore from them.
I search for 6 months for the old ATS speedtech LS7 dry sump pan for my car.
It was a guarantee fit for my subframe and work with existing LS7 oiling system.
I Actually bought the front subframe and rear torque arm suspension package , brake lines etc. and an LS7 because on there website pan was and even still is available.
Called to orderp pan a few weeks ago and they say oh we quit making it Jan 1 2020.
But it's still for sale all over internet.
So I then looked high and low for a good deal on Dry sump pan and pump and etc.
But my car was so far over budget already I gave up one week ago and ordered a Mast Motorsports stroker oil pan kit and changed it over.
TANKMASTERJ
09-04-2020, 05:22 PM
From your existing measurements it appears headers are about 18-18.5 from top of flange to bottom of horizon pipes to collector. Would that be a fair assessment?
Then the only other real issue would be how far back tube #1 or front tubes slope I. Degrees to determine if I can clear the rack. Looks like you got a straight edge in front of the headers now maybe a measurement from the straight edge back to tube # 1 would tell me what I need
TANKMASTERJ
09-04-2020, 05:31 PM
I m sorry to harrassing you. I just blew up the pictures of your measurements on my laptop. I think they say what IAM asking. I'm going to measure tomorrow. My LS7 is sitting in the frame out from under my car179029
