View Full Version : Project Lime67 update
BigPerm
08-26-2020, 12:11 PM
I think like most of us, life happens and our builds begin to span multiple years, which also helps the wallet. But I've recently thrown some more money at my 1967 Mustang Coupe, and thought I would share the progress.
My first recent upgrade was to a Classic Instruments AutoX dash. I was getting tired of dealing with crappy speedo cables breaking, as well as the A-pillar gauges I was running. Long story short: this gauge setup is awesome!
178807
178808
Next up were the brakes. I had gone back and forth between Wilwood and Street or Track, but ended up going the SoT route as it was more inclusive of parts, and I preferred the rearward mounting position of the front calipers. 13" front, 12" rear w/parking brake.
178815
178809
178810
178811
And last but not least: wheels and tires. I had a really hard time finding a wheel I liked for a reasonable price, but ended up going with Torq Thurst IIs in 17x8 and 17x9.5. Tires are 245/45 front and 275/40 rear. I run about -1.5-2 degrees of negative camber to keep the front tires front rubbing with the ride height.
178812
178813
178814
178816
Next up: I need to sort out my leaf springs as the driver's side sits lower than the passenger. I also want to add subframe connectors, a baffled oil pan as I'm looking to start autocrossing this thing, and fuel injection.
ICrombie
08-28-2020, 08:15 PM
Sounds like a good plan, I really like the color, very unique!
chunger
08-29-2020, 11:13 AM
Have the same issue - drivers side sits lower than the passengers. First thing all spring companies will tell you is to swap the existing ones side to side to see if the lean follows.
BigPerm
09-24-2020, 01:44 PM
So I was actually able to get around to this recently. I removed both springs, labeled them, and compared them on the ground. They were basically identical in shape, so I swapped sides and re-installed them. Got the car back on the ground, and it sits the exact same way: driver's side about 3/4"- 1" lower. Any suggestions? It bugs me just knowing that it sits that way, and also how it is potentially twisting the car.
chunger
09-25-2020, 10:32 AM
It sounds like we are in the same boat. I think the next step would be to see of the frame bent/twisted. You can at least get an idea of this at home by measuring the dimensions (easier if you can get the car on a hoist). I'd start here:
179659
After that, I think I'd look up a frame shop in my area, take these measurements along and have them measure it. Probably more precise than using a tape measure.
