View Full Version : 68-69 GM-A rear tires. 295/40-18 vs. 295/45-18
STREETFIGHTER50
08-15-2020, 08:32 AM
Just got my AR VN510 wheels. 18x8 with 4.5” BS and 18x10 with 5.97” BS. I’m most likely going with 245/45-18 up front. Trying to decide which rears to go with. Would 295/45’s be too tall looking?
BAMF68
08-15-2020, 08:35 AM
I have 18x10 with 6" bs. Running a 295/40/18 Nitto 555g2. Fender lips are not rolled and it's very close. 178598178599
cdrod
08-15-2020, 12:38 PM
The 295/45R18 is almost 2" taller (1.8") than the 245/45R18 and would probably look too tall. The 295/40R18 is a better match at only 0.6" taller than the 245 tire so the sidewall height would look almost the same front to back. A 285/40R18 is only .3" taller than the 245 tire so the sidewall height is nearly identical front to back; if that matters to you.
STREETFIGHTER50
08-15-2020, 02:44 PM
Sick ride! Sitting properly with them shoes! What are the front wheel/tire specs? Also, what suspension set up?
BAMF68
08-15-2020, 02:48 PM
Sick ride! Sitting properly with them shoes! What are the front wheel/tire specs? Also, what suspension set up?Thanks man!! Running a UMI Performance Stage 5, Viking coil overs. Front set up is a 18x9 with 5.5" back spacing, 275/35. Biggest tire combo for the front, really grips well and no rubbing.
71OLDS
08-15-2020, 04:24 PM
Here's some before and after pics that might help you with this. My 71 442 had 305 45 18s in the rear and I changed to 305 40 18s as I'm getting it set up for autocross. Very similar drop in diameter for the 295s you are considering. The 40 series rear levels the car a little more or said another way eliminates the slight rake with the much taller rear tires:
305 45 18s:
https://static1.pt-content.com/images/pt/2019/09/cqsBqlT-1.jpg
https://static1.pt-content.com/images/pt/2019/09/UwvrKiO-1.jpg
and here's the 305 40 18s:
https://static1.pt-content.com/images/pt/2020/08/M2j3iiJ-1.jpg
https://static1.pt-content.com/images/pt/2019/12/shlTLwr-1.jpg
STREETFIGHTER50
08-15-2020, 05:05 PM
Does the set up you have eliminate the inner fender wells? I would’ve love to run something wider up front, but my wheels are only 8”. 245/45-18 looks good at the moment. If I could run a 255/45 maybe. Might be too big.
STREETFIGHTER50
08-15-2020, 05:25 PM
305 45 18s:
Yall got some bad ass verts! Did the ‘71 require massaging back there to fit 305/45s? Those do look tall. Thanks for the before and after pics! You guys got me sold on the 40’s. Looks better and will handle better. Can’t wait to see your Olds finished!
BAMF68
08-15-2020, 05:28 PM
Does the set up you have eliminate the inner fender wells? I would’ve love to run something wider up front, but my wheels are only 8”. 245/45-18 looks good at the moment. If I could run a 255/45 maybe. Might be too big.Nope, factory fender wells. It clears my big sway bar as well.
71OLDS
08-15-2020, 07:19 PM
Thanks - For the 305/45s the lip was cut to the outside and my chrome trim piece was "folded" around the edge. This gave about 1/2" more clearance to the outside. Then to the inside had to "massage" the wheel wells with a BFH and some touch up spray plus the 3" tail pipes had to have flat spots put on them for a little more clearance. Now I'm trying to make room for 325/30/19s on the back for autocross and street. Notching the frame about 3/4" for starters to try to allow a 6.5" BS or even a 6 3/4". The current 305/40 drag radials will be my drag race setup and also are fun on the street sometimes.
For your fronts - my before after pics work for you again! :) Before is 255/45/18 after is 245/45/18. Both on 18x8. I would strongly encourage the 245/45/18s for several reasons. First the 255s at 27" tall really restrict the turning radius. One thing I've learned with the project I'm working on now (trying for 305/30/19 on the front) is the diameter on the fronts is just as important as the width. My 255s actually hit my sway bar on turn in so couldn't figure out how guys were running 315s on the front with no issues. Well...a 315/30/18 tire is only 25 1/2" diameter. Even though it's 12.8" wide on an 11" wheel, the short diameter gives you more room for width. Also the 245's at 26.7" (and a little thinner) give lots of room for full turning radius. A 255 on an 8" wheel doesn't put much more tire on the ground then a 245 on an 8 so there's no real advantage. Last is the weight. Most 255s are a pound or two heavier than a 245.
-Joe
Mr Nick
08-16-2020, 04:33 AM
I had 295/45/17 rear and 255/45/17 front for a while, and the rears were much taller "looking" than the front. More of a big 'n little drag race type look. I would highly recommend 285/40 or 295/40 on the rear to go along with your 245/45 up front.
cdrod
08-16-2020, 06:50 AM
Streetfighter:
You didn't say what car you have so the following info may not be helpful to you if you don't have an A-body. The pics below show the fitment on my '72 Olds 442/Cutlass convertible with a 285/40R18 tire on a 9" rim with a 5.25" backspace (+8mm offset). I have 1.5" clearance on the inside to the frame rail and about .75" clearance to the fender lip w/o out trimming or rolling. I have a 2.5" Pypes exhaust system which is a bit closer than the 1.5" clearance (not shown in these pics). I could go with a wider tire with a 10-11" wide rim and deeper backspace.
Rodney
178626
178627
178628
STREETFIGHTER50
08-18-2020, 07:57 PM
Maybe on my next set I might just have to try that out. 18x9 with 5.5” BS & a 275/35 would be awesome to have inside the stock fender wells
STREETFIGHTER50
08-18-2020, 07:59 PM
-Joe
Really good info for the front Joe! I see! Thank you!!
STREETFIGHTER50
08-18-2020, 08:02 PM
Yes I’m definitely going 295/40 and 245/45 for this set. Maybe Nittos
STREETFIGHTER50
08-18-2020, 08:08 PM
Streetfighter:
Rodney
178626
178627
178628
I have a ‘68 Skylark. My rear tire on it now is a 275/40 with same size/spec wheel as yours. My fenders have been rolled. I do have more space than on the inside than outside. 295/40 might be the max on mine.
STREETFIGHTER50
08-18-2020, 08:30 PM
I think it will be tight!
andrewb70
08-19-2020, 06:38 AM
295/40 rear and 255/40 front is a nice combination. I ran that on my 70 GTO.
STREETFIGHTER50
08-19-2020, 08:37 PM
What wheel set/specs? 9” front?
andrewb70
08-20-2020, 04:11 AM
18x9.5 6" back spacing in the front
18x10.5 6.25" back spacing in the rear
OLDFLM
08-20-2020, 04:30 AM
FWIW I've been running the 295/40/18 Falkens on the back of my 71 Firebird for over a decade and love the 40-series in the rear. I'll be changing the front 255/45/18 to a 255/40/18 soon when I replace the tires.
STREETFIGHTER50
08-23-2020, 02:10 PM
Not much Summer tire selection in the 295/40-18 size. For a matching front and rear set it looks like Nitto NT555 G2 is my only choice. I really like the Falken Azenis FK510, but they don’t have a 295/40-18. How would y’all feel about mixing the Azenis FK510 front with the stickier Azenis RT615K+ for the rear? This car will be driven only on nice sunny weekends. Cruising and some spirited driving when up in the hills.
andrewb70
08-23-2020, 02:26 PM
What's wrong with the 615s with 295/40 and 255/40 front?
STREETFIGHTER50
08-23-2020, 08:10 PM
What size rim do you have up front?
STREETFIGHTER50
08-23-2020, 08:25 PM
Wouldn't a 245/45 be better on the 8” rim? I was thinking 255/40 might be too wide on the 8”. Also, this would be the first time I’m considering these softer 200 tread wear tires. I’m guessing these don’t last long.
OLDFLM
08-24-2020, 08:40 AM
My fronts are 18x8 and the 255 fits that rim width perfectly imo! 18x10s out back fwiw
71OLDS
08-24-2020, 10:25 AM
A 255/45/18 is OK on an 18x8 rim but not a 255/40/18. You can check any tire brand on Tire rack or other tire sites and see:
255/45/18 = 8" - 9.5" rim
255/40/18 = 8.5" - 10" rim
-Joe
andrewb70
08-24-2020, 10:33 AM
-Joe
I may have use the 255/45. It's been a while. Check heights. You want the front to be about an inch less diameter than rear.
71OLDS
08-24-2020, 10:35 AM
A few other options with the 295/40/18 and 245/45/18 combo:
1. Nitto 555G2s front and rear. I good reliable tire - not real sticky but gets the job done and is safe in the rain.
2. Nitto NT05s rear Nitto 555G2s front. There's your 200TW tire rear - stickier - don't get crazy in the rain - same as above for front.
3. Nitto NT05s rear and Michelin Pilot 4S front. same as #2 for the rear - much higher end tire on the front - incredible for corners and for both wet and dry traction. It's expensive but I'm running this tire on the front of my 442 now and love it. I have Nitto drag radials for even more grip for launching but like to combine with the MP4S on the front to make things a little safer overall when I get caught in the rain.
STREETFIGHTER50
08-24-2020, 11:54 AM
-Joe
This is trip. I just saw what you were saying in TireRack. You would think the opposite lol!
STREETFIGHTER50
08-24-2020, 12:12 PM
So no weird issues mixing front and rear tire compounds right? 300TW front/200TW rear? My nephew has the FK510’s on his BMW. I really like them. Also, I’m leaning more towards a Falken set so I can rotate them side to side. If I can fit 255/45-18 front that would be great. Hopefully I can get away with just removing that center screw in the fender. I will not be driving this car in the rain. Only on nice days :)
71OLDS
08-24-2020, 01:13 PM
Nah - no issues mixing TW ratings. I've got 100TW rear and 300TW fronts right now and the car drives great. You certainly can run the 255/45/18s on the 18x8 but it's just such a tall tire and for all the reasons I mentioned on post #10 here, I would still suggest the 245/45/18. If you decided to go with the 255/45s, just make sure your BS is perfect if turning radius (making U turns etc) is important for you. Also I believe your front and rear will be almost the exact diameter - or maybe only .1" taller in the rear.
cdrod
08-24-2020, 07:25 PM
Here's another good tire combo with excellent wet & dry traction:
Continental Extreme Contact Sport tires 340 AA
Front: 18x8 4.5"BS with 26.7" tall 245/45ZR18
Rear: 18x9 5.25"BS with 27" tall 285/40ZR18
STREETFIGHTER50
09-26-2020, 06:21 PM
Just got em back from the tire shop. These 295/40’s are thicker in person than I was thinking. Do RT615’s run bigger than other brands? A 45 series would definitely be way too tall. Should fill up my rear fenders much nicer :)
https://static1.pt-content.com/images/pt/2020/09/c8jS89-1.jpg
andrewb70
09-26-2020, 06:51 PM
They definitely run wider than the Nitto 555s in a 295/45
Tidony
01-23-2021, 01:44 AM
Any pics of them mounted on the car?
STREETFIGHTER50
01-29-2021, 04:42 AM
Oops I forgot to post these pics up. The 18x10” 5.97” BS with 295/40-18 Falken RT615 tuck in nicely. Really centered in the wheel tub. I had to adjust the exhaust just a little bit.
Before with the 18x9” 275/40
https://static1.pt-content.com/images/pt/2019/11/NezkjE-1.jpg
https://static1.pt-content.com/images/pt/2019/11/cgHtzD-1.jpg
Size comparison between the 275/40 Toyo Proxes T1 vs. 295/40 Falken Azeni 615+
https://static1.pt-content.com/images/pt/2021/01/cxuNE3-1.jpg
https://static1.pt-content.com/images/pt/2021/01/QdczuB-1.jpg
https://static1.pt-content.com/images/pt/2021/01/ka2eDh-1.jpg
https://static1.pt-content.com/images/pt/2021/01/xUOrlW-1.jpg
https://static1.pt-content.com/images/pt/2021/01/mzbtUa-1.jpg
Cheveezy
01-29-2021, 07:48 AM
Looks great!
Mr Nick
01-31-2021, 08:14 AM
Nailed it!
STREETFIGHTER50
02-01-2021, 12:49 PM
Thanks for all the info y’all! I really do like these a lot more than the previous set :)
