View Full Version : Recommended LS shops in the Sacramento/Placer County areas
STREETFIGHTER50
08-11-2020, 02:06 PM
Any recommended LS shops around not too far away? Really considering a 530HP LS crate instead of EFI swapping my on my rebuilt Buick.
andrewb70
08-11-2020, 02:40 PM
I can't help with shops, but this is a pretty well documented and straight forward swap...Holley makes everything you need.
STREETFIGHTER50
08-11-2020, 04:53 PM
Yeah Andrew this $7,399 LS3 is really tempting!
https://www.summitracing.com/parts/mll-psls3760ctf?seid=srese1&gclid=Cj0KCQjwg8n5BRCdARIsALxKb94I9HgIMkNrs7y15iZH eMKDdKx7WQAaGelZGyYghclqjTZIwKrYs_QaAo_zEALw_wcB
I’m thinking it would be so much better to drive all around and less to worry about it the long run vs. this BBB. To even get past the 500HP on this motor I’d have to go with aluminum heads and so much more needed little details which will add up really quick!
andrewb70
08-11-2020, 05:22 PM
Looks like a great engine, although I do not have direct experience with it.
Here are all the parts that Holley makes for the swap:
https://www.holley.com/products/engine_swap_parts/ls_swap_systems/1968-72_gm_a-body_ls_swap_components/
I would use the 1" forward mounts, the 302-2 or -3 pan, and the crossmember for whatever trans you want to use. I would also go with the Terminator X Max EFI system, which has DBW and trans control. You can use a 2009 Impala SS DBW pedal, which is practically a bolt in for 68-72 a-bodies. Holley also makes various styles of headers and full exhaust systems.
Lastly, for the fuel system, I would consult with Carl at VaporWorx and use on of his fixed pressure 5th gen Camaro SS fuel modules. You will end up with a very reliable and fast car.
If I can be of service with the tuning or wiring, let me know.
STREETFIGHTER50
08-12-2020, 04:25 PM
Thanks for the info and help Andrew. Man it looks like Holley really is the one stop shop nowadays. Thing is I’m limited with space and time. My garage is a mess right now and I have seven family cars here already all needing something done lol! If I can find a good LS shop that’s fairly reasonable I think I might pull the trigger.
andrewb70
08-12-2020, 05:49 PM
When you find a shop, make sure they use the Holley parts. You'll have a high quality swap. Good luck!
bavtech
01-26-2021, 09:54 AM
Are you looking for a engine or someone to do all the work?? What part of Sac?? I have customers/ pro shops all over town that I work with at my day job.
STREETFIGHTER50
01-27-2021, 02:56 PM
The LS dream is on the back burner for now. I ended up getting my Mustang back. I still may go with the Holley Sniper EFI though. Thanks for looking out!
