View Full Version : Ridetech Info
Waggmore
07-31-2020, 12:59 PM
Picked these up for a 69 Nova project. Was just looking for information on them, I realize they are a older model. Also is the bushing at the top is still available for purchase.
Josh@Ridetech
07-31-2020, 01:11 PM
That's what we called a 104 series (the type of bellow assembly) Shockwave. The delrin bushings on top are still the ones we're using currently, you can find them here (there is a top and bottom bushing):
https://www.ridetech.com/product/delrin-ball-half-for-coilover-shockwave-stud-top/
https://www.ridetech.com/product/lower-delrin-ball-half-for-coilover-shockwave-stud-top/
I can see that it has one of our extended stud tops on it. If you get a chance, measure from these points and I'll be able to help you figure out what shock you have exactly.
178201
Also, measure the length of this stud top base as well. It's hard to tell which one you have from the angle of the picture.
178202
Waggmore
07-31-2020, 01:26 PM
14 in extended. Stud is 2 5/8s. Should for for a F body GM. Only have the front and compressor. Will be adding the rear also.
Josh@Ridetech
07-31-2020, 01:37 PM
You have a 3.6" stroke shock w/ our 2.75" stud top.
Here are the dimensions:
Collapsed: 11.05"
Ride Height: 12.83"
Extended: 14.05"
minendrews68
08-03-2020, 01:08 PM
Wow! How's that for service! Way to go Josh.
MonzaRacer
08-05-2020, 06:27 PM
Bret trained them well!
Josh@Ridetech
08-06-2020, 07:21 AM
Haha, thanks guys! :cheers:
