View Full Version : K member frame bolt hole repair
J-440
07-29-2020, 08:15 AM
So my tubular K member decided to take a crap and when it did, one of my bolt hole mounts got bent. I drop the member and the hole is now cocked and concaved and the nutsert broke loose. Is there a tool like a slide hammer that will go into a 1” hole, secure itself on the wall and then I can beat it out? The frame is boxed and is a unibody and I only have access through the 1” hole. Any help is appreciated.
raustinss
07-29-2020, 03:38 PM
Pics would help , sorry not a big mopar guy to know what you're referring to
J-440
07-30-2020, 02:58 AM
Here’s a pic.
raustinss
07-30-2020, 03:40 AM
Not sure if you want to but I'd cut a hole in the side to access it , reweld it then weld the access hole closed again
brent1976
08-01-2020, 01:52 PM
Do they make rivnuts that big. If they do it’s a pretty easy fix.
J-440
08-04-2020, 08:12 AM
I've found some in that size but the 1" hole in my frame is too big for the rivet. Plus to compress a rivet of that size would require me to have Hulk strength so I was told.
raustinss
08-04-2020, 02:47 PM
Also not sure youd want a subframe being held on by rivnut
J-440
08-04-2020, 04:23 PM
It’s a Dodge unibody so everything is tied in. Granted the nutsert would be the weakest link between the other 3 bolts, I don’t think it would be that bad. When the k member welds failed it did damage to that one area.
mikedc
08-05-2020, 03:00 AM
What's the story on the tubular K-frame crapping? What happened? What brand was it?
J-440
08-05-2020, 03:35 AM
This was a complete setup from Magnumforce Racing. Came with tubular k frame, upper and lower a-arms, rack and pinion, spindles, 13” Wilwoods and coilover shocks. I was told this was good for the street and drag racing. I make a 3mph turn around in a parking lot and the weld snaps and the car drops the driver side. Since this design is 15 years old, they don’t have any replacement k members so I have to buy a whole new setup. And I mean nothing will bolt on to the newer stuff. 2020 can kiss my ass!!
brent1976
08-05-2020, 07:55 AM
What about through bolting all the way through the frame. I’m just thinking how to fix this without cutting a piece out of the frame to straighten it and weld a nut in there and then reweld the pieces back in.
J-440
08-05-2020, 07:59 AM
Interesting. Didn’t think of that. Thanks for the input brother.
raustinss
08-05-2020, 02:02 PM
If you go that route you're going to want to "sleeve" the hole by welding in a DOM piece of tubing so you could tighten the bolt without crushing aka collapsing the original rail
J-440
08-05-2020, 02:35 PM
Oh yeah definitely. Good thing I work in a machine shop.
raustinss
08-05-2020, 04:06 PM
Lol ...love when you have the skills and the material , good luck
