View Full Version : 69 Camaro Ridetech 4 link pinion angle help
oakhill510
07-28-2020, 06:36 PM
69 Camaro
5.3
t56
ford 9”
Ridetech 4 link
I need help with finding my pinion angle. I don’t think setting my pinion to 3 degree like Ridetech said, is going to do.
All 4 wheels are on the ground, using floor jacks to hold it at the ride height I want. I am doing the adding/subtracting way of setting my pinion angle. With that being said, what should my pinion angle be with the following information:
slip yoke angle -4.5
drive shaft +.8
Pinion -4.6
On the Tremec app, I inputed the above angles into the app and got the result:
Angle 1 - 4.4 (Red)
angle 2 - 3.6 (red)
operating angle - .8 (green)
Do I have to worry about the angles in the reds?
130fe
07-29-2020, 05:32 AM
What engine/trans mount are you using? I have the Holley stuff and it gave me a 3.0 angle?
oakhill510
07-29-2020, 08:04 AM
Motor side mount are eBay ICT and the frame mounts, I don’t know the brand. On the tranny crossmember, it’s a G-Force brand.
On my post, I had did my math wrong. I was adding instead of subtracting my slip yoke angle from the driveshaft angle.
New angles:
Slip yoke - 4.5 degree
DS + .8 degree
Pinion -4.6 degree
operation 1 — -4.5 - .8 = -5.3. (Slip yoke to DS)
Operation 2 — -4.6 - .8 = -5.4 (pinion to DS)
I believe I need to shim my tranny to try to get it to -3.5 degree and bring my pinion to 3 degree or under. For sure, I need to bring my DS from + to -
If I can achieve these angles
Slip yoke -3.5
DS -1 (or under)
Pinion -3 (or under)
I’m be in the greens accordingly to tremec app.
178147
cpd004
06-05-2021, 04:51 AM
Did you get this sorted out?
