View Full Version : 1969 camaro fuel inlet relocation?
71maroesteban
07-07-2020, 02:29 AM
I see some people use the ridetech gas inlet and a 68 tank on a 1969 they just drill into the tail pan, is it simply for cosmetic reasons? I read somewhere the fuel leaks from the stock location since it’s so low? Just wanted to know the reasoning behind it
dhutton
07-07-2020, 03:40 AM
I section in the gas filler section of a 67-68 tailpan so that is it nicely recessed. The reason I did it is because the 69 fuel filler is so damn low especially if you lower the car. It also looks good imho.
Here’s one that I did recently.
Don
TheBandit
07-09-2020, 01:20 PM
I always though the flip-down license plate filler location was cool, but as I get older and after lowering the car a lot, my knees and back are starting to hate me. I often have to crouch at the gas station and hold the nozzle at a reduced rate, otherwise fuel backs up into the neck and the nozzle stops prematurely.
I think relocating to the tail panel or somewhere higher is a practical consideration as well as cosmetic.
Also when I ran a vented cap, fuel would slosh out the back going down the road. Now I have a vent in top of my tank (with a safety check valve) so I can run a fully sealed gap.
- - - Updated - - -
Can you buy the relevant sheet metal parts aftermarket? I'm curious how hard they are to integrate into a 3rd gen Nova. I've seen it done on a few, but never seen how it was done exactly.
dhutton
07-09-2020, 02:53 PM
- - - Updated - - -
Can you buy the relevant sheet metal parts aftermarket? I'm curious how hard they are to integrate into a 3rd gen Nova. I've seen it done on a few, but never seen how it was done exactly.[/QUOTE]
This is the panel I use. Only $110 shipped. Well worth it imho.
https://www.ebay.com/itm/1967-1968-Camaro-Tail-Panel/263786941216?fits=Year%3A1967%7CModel%3ACamaro&hash=item3d6aed4b20:g:lHwAAOSwil5bNoFT
Don
71maroesteban
07-10-2020, 01:39 AM
Don
I kinda prefer the tail pan without the gas inlet. I wanted to know if say I was to auto cross/track the car if fuel would slosh bad enough to leak out of the stock inlet since it’s so low?
dhutton
07-10-2020, 03:07 AM
It will be ok if your cap is not vented. If it’s vented you will likely leak fuel out the vent.
Don
