MAGONSTERZ68
06-30-2020, 01:50 PM
Would like to liquidate current project to start a new, whats my build worth these days?
Non RS Non SS, Z28 tribute vinyl stripes, base power convertible with tons of new extras.
Paint is about a 6.8, daily driver chips and dings, some lower quarter panel rust. Can see build specs at link provided.
Engine: Holley LS swap mounts, LS3, 11:1 compression, by Cody at Bakersfield Engine Machine, BEM 64.5cc heads 5 angle valve cut w/stg. II porting, BTR N/A STG2 cam, 90mm Edelbrock TB, Milodon Road Race pan and HV/HP Melling oil pump. Holley 3" mid length 1 7/8" headers and 3" turn down O2 pipes, Improved racing 215 Degree remote oil filter / thermostat and oil cooler. Lingenfelter 160 deg thermostat, Entropy twin 11" fans with soft start controller, runs a steady 200-210 with A/C in 100 deg Cali summers.
Transmission: By Brandon's Transmission in Bakersfield, Ca. Holley transmission cross member, 4L60E w/ Sonnax Guts, YANK converter 3200 stall, B&M transmission cooler.
Rear End by Rudy Medrano at RJ's Rear Gear Works, Bakersfield, Ca.: GM 8.5 - 10 bolt - 3.73 gears and Tru-Trac posi.
Exh. Holley WARLOCK Mufflers W/ DOUG'S electric cut outs and second set of Spin-tech muffs traverse mounted in original location.
Suspension DSE lower control arms, DSE sway bar, Hotchkis upper control arms w/ 600# coils, Hotchkis Chassis Max Handle bars and Ride Tech Tru Turn Steering System. Hotchkis Sub Frame connectors W/ X Brace and Competition Engineering solid body mounts.
Interior by Lupe at Bakersfield Landau: TMI Hounds Tooth Interior, Kilduff billet slap shifter, power lumbar and heated seats, cruise control, power locks and power windows. Vintage Air with billet 3 knob controller.
Wheels: 18" Aluminum Rally reproduction, Michelin Pilot Super sports all four corners: Front 18x8.5 w/5.125 backspace 245 45 18. Rear 18x9.5 w/5.25 backspace x 275 40 18. ZERO rub issues lock to lock in front and ZERO rear inner well rub either, even with off camber driveways.
thanks all,
https://www.holley.com/garage/view/4252-1968-chevrolet-camaro/
177267
thanks all,
177267
