View Full Version : 1965 Pontiac GTO clone pro street
Johnzee67ls3
06-12-2020, 02:40 PM
1965 Pontiac Tempest for sale with clean NV title. 235 body code, previous owner did the GTO badging. Recent restoration with many receipts. Back halved with roll bar and narrowed 9” with 4:11 gears and ladder bar rear suspension. Front/rear disc brakes with proportioning valve. Freshly built Mark IV big block Chevy with receipts! 489ci bored and stroked with all new parts including:eagle rotating assembly and domed pistons ~10.05:1 compression, comp cams flat tappet cam 292/292 .550/.550 lift 110LSA, brand new summit racing iron heads part#152125, roller lifters, new pushrods, lifters, oil pump, timing set. Edelbrock air gap with summit racing 750cfm carburetor. 12qt fuel cell in trunk with new Holley blue external pump and regulator, kicked out 7qt oil pan works with full headers nicely. Engine stays cool by use of griffin radiator, 195 degree thermostat, and cooling fan wired to come on and off seamlessly. Th400 trans- recently gone through and checked out fine. New Hughes 2500rpm stall converter with b&m shifter in the factory console.
Body: Recent paint job with no rust, small scratches and cracks present in a couple of spots. Weld racing 15” rims with 31” by 18.5” Mickey Thompson sportsman rear tires. All pieces and parts are there and in working order. Fresh interior with auto meter gauges giving the vitals. Car starts, runs and stops great. Located in Reno, NV can help with shipping within reason. $33,000
17676917677017677117677217677317677417677517677617 6777176778176779176780176781176782176783
