joeljet
06-09-2020, 08:07 AM
sale pending
car is a roller, front clip, engine, interior not installed in xenia ohio 45385 outside dayton
………...engine
bored and stroked 408 ls iron block, eagle rotating assembly, comp cam, arp studs
317 heads, bigger valves, ported and polished, comp cam springs, btr rockers, titanium keepers, arp studs
all new sensors, plugs, wires, gaskets, cometic head gasket
new ls2 lifters
reprogrammed computer
nick Williams and fast 90 intake
underdrive balancer and arp bolt
all f-body accessories and brackets
2 ls1 harnesses for converting (auto and manual)
………...tranny
6-speed with new ls7 clutch, flywheel, pressure plate, throwout bearing, mgw short throw shifter
or
stage 1 4l60e with new original hurst dual gate shifter, shiftworks adapter
………...rear end
Detroit true-trac posi diff with performance cover, tubes welded to center section
………….brakes
all new baer sport setup all 4
new stainless hard lines, hoses, booster, master cylinder, adjustable ssbc prop valve
…………...suspension
global west subframe connecters
solid and poly subframe bushings
all new ride-tech coilover setup, front installed, rear is triangulated 4-link still in box (but car is riding on fiberglass leaf springs for now)
new agr quick ratio steering box, new linkage, spindles came with baer brakes
…………...interior
dash is great 9 outta 10
gauges overhauled clock quartz kit installed
new firewall blanket, dynamat copy installed on about half the floor(got rest of the roll)
mint 2000? t/a black leather seats with lumbar harness and adapters to fit into a 2nd gen(have originals but they need a lot of help)
all interior plastic parts with many extras (doubles and triples)
all new condenser, compressor, evaporator, heater core, inside and outside a/c heater components, and controls overhauled by the a/c guys in florida
overhauled tilt column
all new intermittent wiper components and motor
new in box American autowire harness
new in box electric life electric window kit
tranny tunnel cut for 6 speed
new 3 pedal setup (still have 2pedals also)
both auto and manual consoles
good headliner cardboard thingy
……........body
almost ready for paint body, hood, doors, trunk primed, (firewall, dashtop satin black) (new amd parts still in the black coating)
urethane nose in great shape (need to redo primer didn't use enough flex agent in primer)(cracks on nose in primer only not nose it's still flexible)
original front clip some corrosion and patch panels on fenders, extra 78 t/a front fenders primered, and all new front t/a fenders, inners, metal valance, brackets, battery tray and rad support from amd
all trim and many extras
p.o. shaved rear bumper but it needs rechromed
windshield cracked but the rest are good
.............fuel
new ricks tank with internal pump, external corvette pressure regulator, new stainless hardline
..........wheels
new vintage wheel works v40's 17's with falken 275-50-17, 255-50-17
2 spare corvette donuts for spares needed to fit over the bigger brake rotors (mounted as rollers for now)
..............needs
paint
radiator and fans
harness converted or new for engine to car hookups
windshield
carpet
clean texas title
many extra parts, factory manuals on paper, receipts for all, not interested in parting out, don't need help selling
only trade I would be interested in is a nice chrome bumper vette with a/c and no luggage rack (I've got some cash for that trade)
$15,000 or reasonable offer I've got over 30k in parts, don't need to sell because of hard times arthritis in hands catching up with me, just want to get a complete car
thanx joel 937-347-1112
………...engine
new ls2 lifters
………...tranny
or
………...rear end
………….brakes
…………...suspension
…………...interior
……........body
.............fuel
..........wheels
..............needs
paint
radiator and fans
windshield
carpet
clean texas title
