Madspeed
05-27-2020, 08:45 AM
I have the early WD front sub I bought MANY moons ago. At the time Willwood did not make the big brake kit fo rthe close bolt hole calipers (Early spindles) My qustion is If I use the upper lower and spindles from the later will it work If i just change the upper swing shafts? I have both spindles and see that the later are taller. If I can then I can use the brackets i have if not I have to pay 165.00 a bracket from willwood. FFS they must be Un-obtainium. I have them coming but I can return them if need be. Id rather update to 14 inch rotors later and get the 14 inch brkts instead. and the rotors at 325.00 each FFS more Un-Obtainium
Ken
Ken
