View Full Version : Fuel sending unit/line size help
DarkoNova
05-22-2020, 02:58 PM
So it looks like stock LS fuel line sizes are 3/8" feed and 5/16" return according to Google.
I was hoping to just buy a sending unit with two ports and just basically drop it in and be good to go. Problem is, I can only find sending units with a 1/4" return line.
Is that too small? Am I just going to have to add my own port for a return line?
Schwartz Performance
05-22-2020, 06:57 PM
What exactly are you finding? Does it say 1/4” NPT?
It’s not clear what sending unit you’re looking at, what tank you have, and even what car you have unless it’s a Nova like your username lol.
-Dale
CarlC
05-23-2020, 06:50 AM
Depending on what you're looking to do, the Gen5 Camaro SS (2010) typically can be made to fit, can be converted to 60psi constant, and only requires a single 3/8" line to the rail. No filters, external regulators, return lines, etc. are needed. A Gen5 SS module new is about $112 from Rockauto, or about 1/2 that used on many of the Camaro forums.
https://www.vaporworx.com/documentation/fuel-modules/
https://www.vaporworx.com/documentation/vaporworx-mechanical-systems/
DarkoNova
05-23-2020, 11:27 AM
Sorry, lol.
69 Nova.
I searched for sending units with return lines and can only find them with 3/8" feed and 1/4" return.
I originally wanted to just use the C5 regulator so I wouldn't have to run a return line, but I figured it would be easier to just plumb a return line since the engine is already set up for it.
Thanks Carl, I'll look into the Camaro stuff.
andrewb70
05-23-2020, 04:14 PM
When you say "sending unit" what do you actually mean? Some more details would be helpful.
DarkoNova
05-23-2020, 05:41 PM
The fuel sending unit.
I figured that would be the easiest way to plumb a return line, just get a sending unit with a built-in return line.
Aside from welding a sump onto the bottom of the tank or welding on a port for a return line, how else are you guys doing it?
I do like the idea of using a 5th gen Camaro module, but I'm not the best welder so I don't know how I'd go about modifying the tank to fit it.
Oh and if it makes a difference, the engine is an 07 L92.
andrewb70
05-24-2020, 04:06 AM
Why not just get a Tanks Inc. tank?
DarkoNova
05-24-2020, 10:18 AM
I already bought a Camaro tank to move the fillet neck up from behind the license plate to up between the taillights. I'd rather not have to buy another tank, lol.
andrewb70
05-24-2020, 10:34 AM
Then I would highly recommend going with the Vaporworks setup using the Gen5 Camaro SS pump and the modification to run it at a constant 58psi. This also eliminates the need for the Corvette filter/regulator and will eliminate any fuel starvation issues.
DarkoNova
05-24-2020, 07:41 PM
Actually I just went in the garage and checked out the Camaro tank. I think it IS a Tanks Inc unit. I remember buying it either here or on lateral-g. It's already got the drop section where the sending unit goes and it has another hole next to the sending unit hole.
I'm a bit confused about the 5th gen unit, though. Why do I need to modify it at all? Do 5th gens control the pump with PWM?
I have a Holley Terminator kit ordered, I'll have to see how that controls the fuel pump.
And then what about the fuel rails? Do I need new fuel rails since the engine has a return style setup?
andrewb70
05-24-2020, 08:12 PM
The TerminatorX just turns the fuel pump on. Carl can answer in more detail about his modification to the Camaro fuel module.
When you do the wiring for the Holley, I also highly recommend adding a power distribution module under the hood. This will feed the high demand circuits under the hood. I also do Holley EFI tuning.
DarkoNova
05-24-2020, 11:36 PM
Oh, that's good to know!
I just looked at the engine and it's a return less system, so either way I need to modify something.
I'll wait for Carl to chime in, then.
CarlC
05-25-2020, 10:25 PM
All Gen5/6, 2009+ CTS-V, GM trucks, etc. all use PWM to control the fuel pump/system pressure.
The regulator that is in the module is used only as a safety valve and cracks at 88psi. This is so that there are not two pressure regulation systems working at near the same pressure.
The C5 fuel filter/regulator is a return type and has a return. Every mechanical pressure regulation system has a return of some type.
Lots of info here: https://www.vaporworx.com/documentation/
