View Full Version : LS1 rear disc swap spacer
MAGONSTERZ68
05-03-2020, 08:19 AM
Where can I find LS1 rear disc backing plate to axle flange spacer. Swapping onto 10 bolt 68 Camaro. Thanks
BonzoHansen
05-03-2020, 04:13 PM
kore3?
F-Body International
05-03-2020, 04:30 PM
http://www.brphotrods.com/mm5/merchant.mvc?Screen=PROD&Store_Code=BRP&Product_Code=012-3400-00&Category_Code=BRK12F
MAGONSTERZ68
05-08-2020, 02:51 PM
sweet! thx
CapSS92
05-08-2020, 04:18 PM
Even cheaper. I just used it on an LS1 brake rear swap on a 68 Camaro. Worked like a champ.
Alex
https://www.ebay.com/itm/Gm-10-12-bolt-1-8-Axle-spacer-Plates-backing-plate-replacement-Disc-brakes/283712788285?hash=item420e99973d:g:7EUAAOSwqVdapZO v:sc:USPSFirstClass!79925!US!-1
https://www.ebay.com/itm/Gm-10-12-bolt-1-4-Axle-spacer-Plates-backing-plate-replacement-Disc-brakes/283869880199?hash=item4217f69f87:g:7EUAAOSwqVdapZO v:sc:USPSPriorityMailSmallFlatRateBox!79925!US!-1
MAGONSTERZ68
05-09-2020, 11:37 AM
Alex
is one for a single item purchase and the other for a pair thanks
CapSS92
05-09-2020, 11:55 AM
Both are for pairs.
Alex
MAGONSTERZ68
05-10-2020, 05:16 PM
Both are for pairs.
Alex
Gottem on order much appreciate the 411.
CapSS92
05-10-2020, 05:36 PM
No prob. Post pics when you're done. :)
MAGONSTERZ68
05-11-2020, 07:52 AM
Well im half way there, waiting on parts for now.....
05-11-2020, 07:36 PM
Which thickness did you go with?
I have not verified but make sure you have it shimmed to the correct spacing.
MAGONSTERZ68
05-12-2020, 02:33 PM
Always my friend, if i am anything its meticulous......
i believe the spacers are .250" in thickness. Have heard of some cutting out Drum brake backing plate for spacer material as well.
MAGONSTERZ68
05-22-2020, 09:00 AM
update, shims showed up they are .130 thick waiting on pads and rotors before I drop axle and get to measuring up.
