View Full Version : flush mount glass
732ndgen
04-26-2020, 07:49 PM
looking for flush mount glass for 69 Camaro to get my ride on my the road.any help would be appreciated.
Schwartz Performance
04-26-2020, 07:58 PM
Pretty sure Fesler is the only source (Pilkington is their mfg).
joeko23
04-27-2020, 07:16 AM
Auto city has flush mount glass without bankrupting you:
https://www.autocityclassic.com/1968-1969-2-door-hardtop-12337-12437/
dhutton
04-27-2020, 08:42 AM
Yep but it’s oversized and needs to be trimmed.
Don
CapSS92
05-01-2020, 08:14 AM
Is that hard to do or would a glass shop be able to do it without issues?
dhutton
05-01-2020, 09:17 AM
It really depends on the shop. Some won’t do it, some will. Price will vary widely imho....
Don
CapSS92
05-01-2020, 09:46 AM
Ah I see. That's a pretty big price difference however. $1800 vs $399. Technically you could destroy 2 windshields trying to get it done right and still be ahead of the game. The old issue of price vs. quality. :) Reminds me of the control arm and spindle debates lol.
Alex
dhutton
05-01-2020, 02:11 PM
If it’s only a little you might get by with a belt sander. Sounds easy....
Don
joeko23
05-01-2020, 06:18 PM
I’m sure you can reach out to auto city and ask them exactly what needs to be done to get the glass to fit. Once you speak to them you can make the decision. They also may be able to recommend some local shops they or customers have worked with in the past.
Alwhite00
05-02-2020, 04:15 AM
Why the heck don’t they just make it fit out of the box? They could just sand it when they mfg. it.
minendrews68
05-03-2020, 03:22 PM
Just a thought, but I would say because there are too many variations of the windshield and rear glass openings to make them a exact fit.
jlcustomz
05-03-2020, 06:36 PM
Glass can be ground down with a good abrasive type with belt sander or sanding discs. Glass getting too hot is the first way to damage it. too hot, especially near the edge will crack it. Best to have water mist when sanding. Can even check with infared temp gauge. Best not to be over 140 to 150 degrees with annealed glass. Aluminum oxide paper will wear out the quickest & overheat the fastest. Silicon carbide is much better. Diamond abrasives are the best.
Separate subject, but just to mention have used a glass scratch removal system past year at work that actually works pretty decent on minor scratches on most glass & have gotten out heavy scratches on softer windshields. Way better than that near useless cerum oxide powder, but not exactly a cheap tool.
https://glasweld.com/product-category/scratch-removal/scratch-removal-kits/
Tsaints1115
05-04-2020, 06:23 AM
Well for one, because the precision in assembling 60s-70s era cars left something to be desired they need to make it with room to adjust for each individual car.
Perry M
05-04-2020, 07:49 AM
I have purchased glass from Autocity and sanded it down using a belt sander with the appropriate paper (google for sanding belts for glass). Be sure to keep a flow of water on the glass to keep it cool as you sand.
dhutton
05-04-2020, 08:09 AM
How much material did you have to remove?
Don
05-04-2020, 08:55 AM
This is all great info! I didn't even realize AutoCity made that. I'd rather screw up & learn something from a $400 glass x 2 than go the other way :P
-Dale
Perry M
05-04-2020, 10:43 AM
Don
I ordered front and rear glass for my 67 Camaro. When they arrived, the windshield was broken. They shipped me a new one immediately. All I had to do was send them a picture of the broken one. To answer your question, about a 1/4'' from the sides. I only did the front windshield so far. It took awhile but was not hard to do. The rear glass will be easier since it is smaller and the fitment is closer.
dhutton
05-04-2020, 12:12 PM
Thanks. Good to know.
Don
Charles
05-04-2020, 04:40 PM
Perry,
Does Autocity ship the glass with the required adhesives? Im sure there is special adhesive that needs to be used so the rear/front window does not blow-out in high speeds since there are no moldings holding it in place anymore. Looks like a good deal, specially if the car is in bodywork stages and you can work the window openings...
Perry M
05-04-2020, 05:26 PM
No, I didn't receive any adhesives from them. I'm pretty sure they could provide some if requested. I already have some from a prior attempt at installing glass.
jlcustomz
05-04-2020, 07:59 PM
Fast cure urethanes are the usual professional product these days, though your basic slower dry caulk tube sized windshield urethane will give the same result the next day. There are also black primers do darken the glass so the sun doesn't rot the urethane, as new car glass comes with dark edges.
Charles
05-04-2020, 09:56 PM
Will look into purchasing a set from them for my 67 soon, thanks for the info.
SD67
02-01-2021, 09:39 PM
Anyone use these guys? https://www.amhotrodglass.com/ Looks like Chris Holstrom just dropped some into a 68 Camaro he's building and I am considering it as well.
dhutton
02-02-2021, 09:21 AM
For some reason I thought their windshields were lexan/acrylic.
Don
joeko23
02-02-2021, 08:28 PM
Don, I think your right. It says:
“Selling The Finest Acrylic Automotive Products”
Tsaints1115
02-03-2021, 08:41 AM
I know Rad Rides has gotten windshields that are silica coated "lexan" in the past.
motionautoart
12-03-2023, 02:57 AM
so I lve the look I am building my car now 1 quarter tirmed off new one fit new roof set on no welding as of yet , shaving off rain gutters '.
I guess i should get now auto city . Right ? thanks !
601 hp 434 sbc, urathane in glass, 4 link ride tec with ride tec frame connectors
No roll bar do i have to worry about cracking windsheild on launch ??? help on this
raustinss
12-03-2023, 07:49 AM
God no
