View Full Version : LS3 GM Hot Cam - prefer new or pulled out of a crate engine
jorgezee1
04-25-2020, 08:53 AM
Hello,
Looking for the LS3 GM hot cam.
Let me know if you have one.
Will need it shipped to CA, 91792
thanks,
Jorge
andrewb70
04-25-2020, 10:18 AM
Jorge,
If you're looking for a mild, inexpensive cam, look into the Summit Racing "ghost" cam. I use one in my Cougar and it works very well, although you will probably need a valve spring and pushrod upgrade.
icemanrd19
04-25-2020, 10:26 AM
That hotcam worked great in my car. Made about 425rwhp. I could even send you my tune if need be depending on your operating system and which ecu
markaaron80
04-25-2020, 12:09 PM
I have a new, never fired LS3/480 (495hp) hot cam crate engine. I have purchased a Brian Tooley camshaft. My car is at painter now, but engine is out. Make me a reasonable offer.
Mark
478-228-one8four1
I'm in Georgia
jorgezee1
04-25-2020, 03:16 PM
Thanks guys!
I have a 2012 Camaro LS3 going into my 69 camaro. I have the GM ecu Kit for the 430, but I would like to install the hot cam only for the reason I can keep the stock valve train and want close to stock drivability. I sit in traffic for an 1.5hrs I need something that will just idle and drive nice.
Mark I will send you a text.
Jorge
jorgezee1
04-25-2020, 03:20 PM
The ecu is a e67 tuned for the 430 stock cam. Hopefully it can easily be tuned for the hot cam.
XLexusTech
04-25-2020, 03:52 PM
Mark
478-228-one8four1
I'm in Georgia
Tell me more about this cam.. I have same motor..
jorgezee1
04-25-2020, 04:51 PM
when buying a LS3 crate engine, you have three options of power LS3/430, LS3/480 and LS3/525.
LS3/430 is basically the production Camaro/Corvette engine. The LS3/480 is the same engine with the GM hot cam. And the 525 is the biggest cam (don’t recall what cam)
most of these cam are still mild compared to today cams from any of the big name cam companies. I just want to run the stock valve train and have stock like manners with just a little more power.
icemanrd19
04-25-2020, 05:10 PM
Hotcam and my tsp stage 2 runs just like stock except more power. If you have a gmpp controller with a e67 ecu I have a tune for both
jorgezee1
04-25-2020, 06:28 PM
That would be fantastic!
I bought the GM ls3/430 harness and ecu and Mark is selling me the hot cam from his crate motor to run in my LS3. If you could share a tune to get me started that would be great!
Jorge
icemanrd19
04-26-2020, 05:48 AM
XLexusTech
04-26-2020, 07:02 AM
OK got it... so your saying their are better cam option over the 480 525 from specialist.. got it..
