65 drop top
04-24-2020, 08:54 AM
Hi guys, I’m trying to help a buddy out from another forum so here is his question,
Anyone here use the Terminator X with trans control on a 4x4 with VSS in transfer case? If so will it still shift normally in 4low since its seeing a different VSS speed due to low range. Stock PCM has a shift table just for 4low. So no big deal. Granted usually most just shift 1-2 in low anyway or manually shift it 1-2 typically.
Just wondering working on a LS swap, and customer wanted TX setup. Its a 4L80 so I could add the VSS reluctor to rear drum since the 2wd VSS is in the case and not worry about it, just don't want to have to tear trans apart its low mile unit.
Thank you.
Thank you.
