View Full Version : Cheap roller wheel options?
71maroesteban
04-23-2020, 01:41 AM
My 1969 camaro is getting close from being just a shell to a roller. However I don’t have wheels big enough the clear the Wilwood 6 piston and rear 4 piston. Does anyone have and good recommendations for cheap rollers? I don’t want to order my wheels yet since the car has no motor and trans and I want it fully assembled before I do that.
Schwartz Performance
04-23-2020, 03:44 AM
Can you just remove the calipers and use what you have?
Sometimes you can find C5+ Corvette or Gen 5+ Camaro wheels for a good price on Craigslist or Facebook marketplace.
-Dale
71maroesteban
04-23-2020, 04:21 AM
-Dale
Would my 15 inch wheels clear the rotors?
John McIntire
04-23-2020, 04:38 AM
Dale has a good suggestion. I've seen some take offs on FB Marketplace for really cheap.
I bought GTO spare donuts off eBay for mine. I don't have brakes on mine yet, but they work well.
raustinss
04-23-2020, 06:01 AM
I've seen guy buy black steel winter rims ,cut the centers out and set the offset to suit their needs then reweld
F-Body International
04-23-2020, 06:06 AM
Stock 2nd gen and 3rd gen wheels wheels are cheap.
Also, like mentioned, take off the calipers and/or rotors and throw whatever you have on.
pittpens24
04-24-2020, 03:24 AM
I have the same wilwood set up 6/4 on my '68 Camaro. Had no issues running my old 15" wheels in the rear at all - cleared with calipers on. Had to remove calipers in the front tho. Clears rotors no prob.
Bigblockscott
05-11-2020, 03:51 PM
No brakes on my roller yet, but I used 3/4" plywood to make 'wagon' wheels. Hammered a nail in the middle, used a piece of string to draw my circle, and used a random wheel spacer in my tool box as the template for stud spacing and hub opening. I've had no problems moving the car around in the garage with the drivetrain in it.175887
