View Full Version : How to wire a 110v home bluetooth speaker into a car??
FLYNAVY53
04-19-2020, 04:09 PM
Ok, hear me out.... I want to install a Marshall Stockwell wireless bluetooth speaker in my 1972 C20 Suburban. A company called "Cool & Vintage" restores vintage Land Rovers, and uses Marshall bluetooth speakers, in a custom center console, wired into the cars electrical system somehow. I'm looking to copy their idea for a simple and classic looking installation without installing a full audio system since my truck is all original dash, door panels, etc.
174994
174995
174996
So what's the easiest, safest way to power a 110v AC appliance off the car's 12v DC power supply.
Thanks for the help!
joeko23
04-19-2020, 04:23 PM
AC to dc converter
blitzer454
04-19-2020, 06:09 PM
This speaker uses an AC adapter to get 15V/1.8A power to the speaker. Instead of using this adapter I would connect the speaker to the car battery using a buck boost controller like this one (https://www.ebay.com/itm/3A-Mini-DC-DC-Boost-Buck-Adjustable-Converter-CV-6V-30V-to-5V-9V-12V-15V-18V-24V/263540074000?hash=item3d5c366610:g:3aIAAOSwNbFaoO3 A).
FLYNAVY53
04-20-2020, 08:37 AM
AC to dc converter
Understood....would the proper method of wiring this be to use a relay in the power supply coming from the battery to the inverter and then use a keyed 12V source to power the relay, that way the inverter, and thus the speaker would only see power when the car was running?
- - - Updated - - -
interesting....so how would you wire this?
vette427-sbc
04-20-2020, 12:21 PM
I also vote for the booster... It has a 12V positive and ground input, and a variable DC voltage output. Just cut the wall plug off and wire the variable out (15V) to the power input of the speaker.
blitzer454
04-20-2020, 12:58 PM
Run a 5 amp fused 18 gauge wire from an accessory switched source to the input side of the buck boost board. Use the same wire gauge for the ground wire and connect it from a good chassis ground to the input side of the board. For the output side of the board I would buy the same barrel plug that is used on the AC adapter or if you don't plan on ever using the AC adapter you could just cut off that barrel plug and use that wire and plug instead. Then turn on the ignition key and adjust the output of the buck boost board to 15V and then you're ready to plug into the speaker power jack.
FLYNAVY53
04-21-2020, 03:28 AM
I appreciate the info guys. So if Im understanding you correctly, the speaker actually needs to see 15V/1.8A power to operate. In the "at home" application, the AC adapter that is integral to the power cord is converting the 110V AC coming out of the wall to 15V DC for the speaker to use? But in my instance, all I need to do is use the buck boost board to convert, or boost, the car's 12V DC to 15V DC in order for the speaker to work off the car's electrical system?
Again, thanks very much for the help!
vette427-sbc
04-21-2020, 06:20 AM
Yep! Most ac convertors actually list input/output voltage
FLYNAVY53
04-21-2020, 08:01 AM
ok perfect, thanks Chris!
