View Full Version : Insted of buying tubular A arms for an f-body
1320feet
04-18-2020, 01:08 PM
As I understand it, tubular a arms main advantage it to gain some caster. I was thinking of machining the stock shaft back 3/8 to 1/2 (from blue line to red line in photo)and adding a spacer to the other end. Why will this not work?
174921
dhutton
04-18-2020, 02:26 PM
Depending on the car you might move the wheel back too far and cause rubbing.
Don
TheJDMan
04-18-2020, 05:52 PM
I think there is a lot more to it than that. A proper set of UCA/LCAs will correct all of the deficiencies of the stock F-body suspension. I don't see how taking some material off the cross bar will help anything much.
F-Body International
04-18-2020, 07:20 PM
Moog sells an offset version.
https://www.summitracing.com/parts/mog-k6146?cm_mmc=ppc-google-_-search-_-brands-_-keyword&gclid=Cj0KCQjwyur0BRDcARIsAEt86IDij4Z40Tp4URt7xprd ilSZkDD0HywQdHnOk8D9T5P-w1xCMLyYJzwaAsM7EALw_wcB
Also, Global West has their own version for an offset crosshaft.
It’s probably just better to buy an offset shaft if that’s what you want.
79T/Aman
04-18-2020, 08:28 PM
offset shafts don't affect caster.
chevelletiger
04-19-2020, 07:38 AM
I think what your effectively trying to do is move the upper ball joint back,to increase caster,will it work? I dunno.
If you do try it I would do it in small increments and see if it changes anything,but in the end if your not doing the alignment yourself at home,the cost of the experiment might cost as much as buying tubulars that have the geometry revised.give it a shot and report back.
Good luck.
1320feet
04-19-2020, 10:09 AM
I just made some calculations and 3/8" would only add 1.9° and 1/2" would be 2.6°. Therefore 5° would have the joint back almost an inch.
chevelletiger
04-19-2020, 11:05 AM
Moving the lower bj foward is what also equates to the increase of positive caster,just a thought for you.
- - - Updated - - -
What vehicle is this for?
1320feet
04-19-2020, 08:11 PM
2nd gen Camaro.
79T/Aman
04-20-2020, 05:34 AM
waist of time honestly, cut the mount off and re-weld it rearward.
