View Full Version : In search of a 6.0 or 6.2 aluminum motor
clu269
04-18-2020, 12:16 PM
Looking for a LS2, LS3 or L92 complete preferably stock. Want to build a 408 to 416CI stroker motor. thought i would look here first.
jwcarguy
04-19-2020, 07:33 AM
if you are going to build a stroker engine, way look at just starting with a new block, since a stock engine you wouldn't be using 75% of the parts anyways
spacepirate
04-23-2020, 04:37 PM
I'd check the LS parts for sale groups on Facebook.
732ndgen
04-23-2020, 05:47 PM
how close are you to green bay wi.
clu269
04-28-2020, 08:28 AM
5 hours
clu269
04-28-2020, 08:30 AM
Thought if I found complete motor with ECU and harness it would still be the way to go.
Sbeck09
04-28-2020, 11:14 AM
I recently ran across this link:
https://www.eastwood.com/atk-ls3-415ci-620hp-base-ls02-59087.html
After pricing out a fresh stroker build or a crate version from MAST, TSP, etc. I realized this is a great deal. Just swap the intake to the OEM LS3 version and away you go along with a warranty. I cannot find a cheaper method of getting a ready to run LS3 stroker. I have an upcoming project that I will likely do exactly this for. Just an option. Otherwise, starting from a fresh block will likely be best for a full stroker build. There is a few vendors that will sell you a mostly plug 'n play harness kit with a reprogrammed ecu for a reasonable amount.
