View Full Version : Shocks touching lower control arm mount??
Cheveezy
04-11-2020, 05:28 AM
Guys, I'm not a suspension expert but I'm pretty sure the shocks should not be rubbing against the lower control arm mount? Any advice here?
79T/Aman
04-11-2020, 05:57 AM
there are 3 glaring things here,
The shock mounting bolt should position the shock further out.
Your pinion angle may be to high.
That aftermarket shock bracket is not properly designed to clear without a lot of shock mount offset.
Cheveezy
04-11-2020, 06:06 AM
Thanks for the comments, any suggestions on how to fix the shock mounting bolt or the shock mount offset? The rear is a Quick Performance 9".
79T/Aman
04-11-2020, 06:26 AM
a longer bolt with a large diameter sleeve to space the shock out and check that your pinion is not pointing up.
Cheveezy
04-11-2020, 08:55 AM
Something like this looks like it might work?
https://www.speedwaymotors.com/Coilover-Shock-Mount-5-8-Inch-Bolt-w-Support-Collar-4-1-2-Inch,3332.html?sku=91636010-PLN
79T/Aman
04-11-2020, 06:12 PM
yes that should do it.
MonzaRacer
04-15-2020, 06:40 PM
Your shock mounting bolt is wrong it doesn't have a spacer of the appropriate width between between the shock and the mount.
BMR Sales
04-16-2020, 05:53 AM
Agreed, OP needs something like this
https://i.hmjimg.com/images/2020/04/16/_MG_2957.jpg
Cheveezy
04-16-2020, 02:48 PM
Thanks guys, I ordered this and it arrived today, will install this weekend and see if it works.174788
