View Full Version : Tilton 3 Pedal Assembly & 3-in-1 reservoir (Hard to Find)
jeremiahbelk
04-07-2020, 05:51 PM
I am going a different direction on the pedal setup in my Nova so my loss is your gain. Offering up a Tilton 800 Series 3-Pedal floor mount setup (Tilton 72-850) with the balance bars included and designed for pivot-mount master cylinders. The throttle pedal is designed for both drive-by-wire and cable driven applications.
3 Pedal Assembly ($500)
3-in-1 Reservoir ($500) SOLD
Text/Call (713)449-one5four1
Jeremiah
jeremiahbelk
04-08-2020, 04:59 PM
Open to reasonable offers...
jeremiahbelk
04-15-2020, 06:53 PM
Price Drop
I am going a different direction on the pedal setup in my Nova so my loss is your gain. Offering up a Tilton 800 Series 3-Pedal floor mount setup (Tilton 72-850) with the balance bars included and designed for pivot-mount master cylinders. The throttle pedal is designed for both drive-by-wire and cable driven applications. Also available is the hard to find metal Tilton 3-in-1 reservoir (Tilton 72-570) for front/rear brakes and clutch chambers. I have double the asking prices in each of these.
3 Pedal Assembly ($650)
3-in-1 Reservoir ($400)
Package for both ($900)
Shipping to lower 48 at buyers expense
Located in Houston, TX
Jeremiah
jeremiahbelk
04-22-2020, 05:46 AM
3-in-1 reservoir SOLD
3 Pedal Assembly NEW PRICE $500 - This assembly is new / never used or installed / paid over $1000 originally.
cwylie
04-22-2020, 06:46 AM
These mount the master cylinders in the car correct? Behind the pedals?
jeremiahbelk
04-22-2020, 08:16 AM
cwylie
They actually mount underneath the pedals in the pedal assembly. Feel free to text me for a video.
Jeremiah
jeremiahbelk
06-15-2020, 12:05 PM
Bump.......
Jeremiah
jeremiahbelk
06-15-2020, 12:34 PM
176866176866
Im curious if you have any pics of the pedals mocked up on the floor of the car? Do they interfere with the steering column? How did you plan installing them? I'm imagining a pedal box in the floor?
jeremiahbelk
06-22-2020, 06:42 AM
We sat this assembly in the car but they were never mocked up. I am running a roadster shop chassis under the Nova. I had originally imagined a floor mount setup like the high end Porches, Lamborghini's, and Ferrari's so I bought all of the parts I planned to install. Once the body was mated to the chassis and floors were fabricated, we realized that the main RS square tube frame ran right thru where the pedals needed to be recessed and mounted. If we had run a DSE, Heidts, or another aftermarket front clip, there would have worked perfectly. You have wiggle room to move the pedal assembly right or left to accommodate for your column. You can actually mount the assembly as far back as the firewall or as far forward as you can to accommodate for a shorter or taller driver. And once mounted, the pedal pads themselves can be adjusted for driver comfort. Hope this helps.
Jeremiah
jeremiahbelk
06-27-2020, 08:26 AM
Price drop
$425
