View Full Version : Terminator x universal on Pontiac 461?
yellow1098Greg
04-07-2020, 08:24 AM
Hi guys! So I’m still building my 461 and tryin to decide which FI I’m gonna go with for it.......I’m ordering my heads and intake for my new motor soon......Shooting for around 650hp...I am currently running a Holley super sniper with only the 4 injectors so I know I will need to at least upgrade to the 8 injectors with the new Holley xflow. I am happy with how the sniper performs in my current 350hp motor but I have been advised on the new motor to step it up to the multiport terminator X. I just wanted to learn the benefits of doing so...I was told it will be a smoother better performing system for my higher hp setup that will see a lot of street driving and once a month track days. Not to mention better clearance for the shaker when I run a nitrous plate. I’m just looking for an education on the difference between the two and how multiport would be a better setup for me...
Also was wondering about the intake setup for a multiport on a non LS setup....I currently run a northwind and they don’t offer that with efi bungs but they do sell a Victor which is much higher and might have fitment issues......I just wanted to know if anyone is running the terminator on a non LS setup and how they have it setup and the feedback to decide if I should go this way or just stick with the TBI
Wacker7977
04-07-2020, 09:48 AM
I'm curious to see how you like it. My mild 468 makes about 500 hp and the guy I had tune my carburetor said that if I ended up going efi down the road I'd be disappointed if I ended up going throttle body type rather than multi port injection.
What heads are you running? Might want to give Butler a call to see what they have to say about it.
yellow1098Greg
04-07-2020, 12:43 PM
I’m running Butlers Edlebrock CNC 340cfm heads.....I was told the same exact thing ....But when I spoke to Butler the guy im Working with he thought the new TBI Holley Xflow would be almost just as good......but the MPFI I was told would have better throttle response and be able to run a bigger cam with more street ability....so I’m alittle torn....I also haven’t been able to find much info on people running the terminator x on old iron mostly just LS setups
anguilla1980
04-07-2020, 04:39 PM
I went Terminator Stealth to replace my AED 4150. I can't see how it could be not as good as the carb, at a minimum. My current combo is at 450HP and my upgraded one later this year will be 600HP, the systems max. I'm running a very modified Torker II intake so I can keep my RA II setup functional for cold air. I'll be swapping my 670 heads for Edelbrocks this summer along with a new cam to match and new hedders.
I got everything, the 6EFI CD box, the 6EFI coil, the dual sync dizzy, etc. I stayed with the HP ECU and didn't upgrade to the Dominator ECU tho. I start the install in just a couple of weeks. I'll have Westech do the tune.
If I were 800 or over, I would do the SEFI. I'll never be at that tho, my build is for a well-balanced road racing setup and not drag strip.
OLDFLM
04-08-2020, 06:51 AM
I've got the Terminator TBI/Holley HP ECU on my 440 now and LOVE it!! 6EFI CD box, coil and dual sync as well with a Rick's Restomod tank and GM fuel module.
I had a very tricked out Holley 950HP before with all of RobbMc Performance's fuel system, 1/2 sending unit, 1100hp mechanical pump etc. and this Terminator TBI beats it in every aspect hands down!
I replaced the Northwind with a Tomahawk single plane intake to clear the Formula hood and the TBI is 1/2" shorter than the 4150 was so more room for a taller air cleaner...
Sbeck09
04-08-2020, 10:52 AM
To answer your questions about the TBI vs MPFI, realize the advantage is centered around the accuracy of fuel delivery per cylinder. With TBI it is acting much like a very accurate carb. It lets each runner suck down what it wants of the air/fuel mix and that works pretty well especially on milder engines. Where the multi-port setup excels is by precisely squirting the fuel down that runner, ideally at the intake valves. This provides a multitude of advantages. So yes, moving to something like the Terminator would be a smart decision.
I am running a Dominator on a very worked over small block Ford. Luckily I have some great choices for MPFI intakes since my engine is popular. I have Andrew (andrewb70) from here on the forums doing all my remote tuning and it's been amazing. It's too bad that more people don't realize how capable these Holley EFI systems are on engines other than an LS. The only "downside" you could argue is that the non-LS engines aren't quite as plug N play, but it wasn't bad at all to get mine up and running.
My opinion, if you are willing to spend money on building an engine then be willing to use a nice EFI system that can help that beast run like a new car while being safe on the hardware. You'll wonder how you even debated this question once you do it.
yellow1098Greg
04-08-2020, 01:07 PM
That’s exactly why I purposed this question....thank you for the feedback....being you have the small block Ford makes it alittle easier when it comes to the intake setup.....I don’t know if any vendors modify or sell them for a Pontiac.....I do want my engine to run as efficiently as possible because I do drive the car a lot
OLDFLM
04-09-2020, 04:47 AM
They used to make the Tomahawk with the fuel injector bosses already machined... go on PY and ask if someone has one they are willing to sell. Or ship your intake off and have it machined for about $700.
yellow1098Greg
04-09-2020, 06:09 AM
How does the tomahawk perform? I know butler sells the Victor with efi bungs but I’m not sure I can fit it with my shaker.....I still haven’t seen your car around here in Orlando ....I know it’s a bad time but I’d love to see it one day
F-Body International
04-09-2020, 11:18 AM
This is my simple approach. This is not end-all be-all, but my general opinion with traditional V8 engines....
I would only do TBI on an iron headed Pontiac with a true carb style intake that has a heat crossover. That crossover helps warmup time and fuel vaporization.
Since your engine lacks a crossover due to the aluminum heads, I would just go straight to port injection.
yellow1098Greg
04-09-2020, 11:36 AM
you got me sold....after some reading I think I have my decision made.....now just to find the intake....and with the intake challenges getting it port matched to the heads ....butler can do this with the Victor I just don’t know if it’ll fit
andrewb70
04-09-2020, 12:07 PM
Even if you are using a manual transmission, I would recommend getting the Terminator X Max. It is a little more money, but adds the ability to do DBW and transmission control. While you may not need these features now, it is nice to have them available for future use. Also, if you have a T56, the Terminator X Max has an easy way to wire a VR (2-wire) style VSS through the J4 connector. Having a speed input to the ECU opens up more tuning opportunities, such as turning off the cooling fans above a certain speed and also adding an advanced table to raise target RPM speed based on speed. The latter is great for improving drivability.
04-09-2020, 12:52 PM
As mentioned on my thread where you asked, I would look into the Speedmaster if you want to keep cost down. The other option is the Edelbrock Torker II EFI intake. Both are the low-profile you need.
Jon
04-09-2020, 01:15 PM
Pretty sure you're meaning the Speedmaster (name changed over the years).
$132 port fuel injection Pontiac intake brand new on eBay...
https://www.ebay.com/itm/274264152712
yellow1098Greg
04-09-2020, 09:27 PM
I guess my question is with something like that would I lose some power vs a Victor or a northwind ?
04-10-2020, 03:38 AM
On a dry intake (port injection), I wouldn’t think hard about it. The main thing is port matching and blending the runner to the head as best as you can.
Hammered
04-11-2020, 04:07 AM
I've been running a sequential EFI system on my Pontiac for over 10 years now and have been very happy with it. The only problem I have is that it's all based on the Accell technology which is not supported and so I will one day need to migrate to something else, probably the Holley HP. My E-heads were ported to 310 cfm and the engine made about 560HP with the Edelbrock TII intake. Other specs can be found here: http://1967firebird.atwebpages.com/efi1.php After the dyno, I port matched the TII and the only problem is that the roof height of the runners was not sufficient to get a perfect match. I think they are about 1/16 - 3/32" off, but the floor and sides matched up fine. I did not get have the opportunity to dyno the engine again to see what power the port matching made so I can't help you there, but there must be some Victor versus Torker numbers out there for carbed engines.
The TII sits about 0.2" higher than stock if I recall correctly and locates and angles the throttle body the same way as the factory did. In other words, the only difference is the added height. With the Victor, you'll not only have height to contend with, but I'm pretty sure the angle and centering will be off as the Victor puts everything square and center.
yellow1098Greg
04-13-2020, 06:11 AM
Great info and thank you! I will definitely look for those carbed comparison articles and videos....I figured there would be an issue with fitment on the Victor... on my current engine I have a northwind with the Holley sniper I did wonder if that would be higher than a Victor or any MP setup since the sniper TBI is larger. Maybe the height on the throttle body would make up the difference .....
04-13-2020, 07:42 AM
Holley 4150, Holley 4500, and TBI (sniper, FiTech, etc.) are the same height.
The only throttle bodies which have a lower profile are the efi 4 barrel carb style throttle bodies.
So many options these days. Heck, you can even bolt on an LS 4-bolt throttle body.
https://www.summitracing.com/parts/hly-17-93?seid=srese1&gclid=Cj0KCQjwm9D0BRCMARIsAIfvfIafBxh-B0s4n7T3o7aTCx_43e_AAEUI6856R7oPKr4tLhvccfrNSY8aAj SLEALw_wcB
yellow1098Greg
04-13-2020, 09:47 AM
I thought the throttle bodies were smaller on the MPFI setups.....I guess if I got that speedmaster intake I could send it to butler to get it port matched to my heads....just wanting to get max performance from my setup I was wondering if that lower intake would cost me power vs the Victor or a modified northwind
Alponcho
04-13-2020, 12:05 PM
Most likely I'll be using one of those shootout/hurricane/tomahawk intakes on my '70 Formula so that I can fit everything under the factory hood. My neighbor Frank G of AllPontic did some testing and said that it can work well---it does give up some power relative to Victor, but not as much as he thought it would, especially in comparison to the NW. He used it on a "mild" 505 for a friend of ours with EZ 2.0 TB...we were all very impressed...supper snappy and pulled like a freight train--cliche, but a perfect descriptor. Mine will be a 535 (TB) and a little less mild, and I know he wouldn't let me use it if he thought it would rob too much power--instead, he'd try much harder to get me to go with a different hood!
Hammered
04-14-2020, 04:56 PM
A Victor is going to require a lot of fab to make it fit with the shaker. The fore-aft position will be off as well as the height and angle so I don't think it's worth it for the power difference.
Port matching is easy if your heads are matched to a particular gasket. Mine are CNC matched to an SCE gasket (I forget which one) and I spent no more than two hours with a $20 die grinder from HF, a carbide burr and grinding rolls from Eastwood.
Finally, I'm pretty sure Terminator X is for LS and Cayote engines and the regular Terminator is TBI based. You may be thinking of the Dominator which unless you're racing, doesn't offer much more than the HP. Otherwise, you're right in that you can find TBs that are lower than a carb. A Quadrajet is about 3.25" high and you can find TBs less than two and run a spacer to make up the difference.
Also, you'll want to have Comp or someone spec an EFI cam for you. You'll make a lot less idle vacuum though so you'll need to use hydraboost for power brakes or go manual.
04-14-2020, 07:25 PM
The 4 barrel efi throttle bodies flow 1000+cfm. Very few engines have the ability to utilize a 2000cfm dominator efi 4 barrel....super victor might be overkill.
yellow1098Greg
04-14-2020, 08:40 PM
All great info thanks fellas....where are you finding a tomahawk intake nowadays? Butler doesn’t have any.....and that info about the terminator is golden about the vacuum issue and things like that.....the terminator does have a newer universal kit for non LS/coyote engines but if it’s gonna cause that many more issues that’s not ideal either ...Hammered which efi setup are you running on your 462?
OLDFLM
04-15-2020, 04:27 AM
This is the Tomahawk now apparently...
Hammered
04-15-2020, 05:27 AM
I'm not an expert on Holley's efi products, but knowing that I will one day need to upgrade to one, I have studied them. You need to talk to a Holley tech to validate what I say before you buy anything.
Terminator: The kits seem oriented toward TBI and NOT MPFI systems. The more generic kits seem oriented toward modern engines with crank and cam sensors. The actual ECU used in the Terminator kits looks like the Holley HP.
HP or Dominator are both suited to MPFI systems and are very flexible to accommodate almost any engine. You can see a comparison here: https://havocspeed.com/media/holley-hp-efi-or-dominator-efi-system-which-is-best-for-me/
Unless you need electronic transmission control or are going to do some serious drag racing, the Dominator seems overkill to me.
I am running the Accell Gen 7 and you can find details in the link that I provided in my first post. Holley bought Accell about 10 years ago and prompltly stopped supporting all of the EFI products. If anything goes bad, like even the distributor cap or rotor, I'm toast so I need to migrate to another system. For simplicity, I'm running a dual-sync distributor and that limits my choices to FAST or Holley. Holley's support is better and the PWM output control is useful for controlling the fuel pump on my return system to avoid overheating the fuel in the tank.
04-15-2020, 08:01 AM
Hello,
This whole thread is in reference to the new Terminator X system. It's a new low-budget efi computer and harness designed for port injected engines. I know it may be confusing but this is different than the Terminator (dare I say, "older") TBI system.
https://www.holley.com/products/fuel_systems/fuel_injection/terminator_x/terminator_x_and_x_max_universal_kits/terminator_x_universal_kits/parts/550-936
04-15-2020, 08:05 AM
Hey Guys,
I saw Holley just released a TBI version of the Terminator X...$1500 new. Something to look into.
https://www.holley.com/products/fuel_systems/fuel_injection/terminator_x/terminator_x_and_x_max_stealth_4150/terminator_x_stealth_4150/parts/550-1002
- - - Updated - - -
I provided you a link before. Check it out. Jegs has them as well if you want to go that route.
yellow1098Greg
04-15-2020, 09:04 AM
Jon I have seen that terminator stealth...looks like it’s only good up to 600hp...I think there new TBI is the Xflow for higher HP setups.....I would like some more info from Holley with terminator x as far as the vacuum goes and if I will need to go hydroboost ....your info on the intake has been awesome!
anguilla1980
04-15-2020, 09:07 AM
I went with this Terminator Stealth setup: https://www.holley.com/products/fuel_systems/fuel_injection/terminator_efi/terminator_stealth/terminator_stealth_master_kits/parts/550-441K
Only difference I see is the ECU and the injectors are 100lb instead of 80lb plus they run at LS fuel pressure where mine runs at old school 43psi.
I wish mine supported 650hp instead of 600 :( I kinda feel ripped off.
Hammered
04-15-2020, 02:49 PM
Thanks for the correction, i was not aware of the -X which looks like a direct competitor to the Edelbrock Pro-Flo. There is a good comparison table at the very bottom of this page: https://www.holley.com/brands/holley_efi/products/fuel_systems/fuel_injection/terminator_x/
The only downside that I see is that you can apparently program it only through the handheld which I cannot believe gives the same programming range of options as the full computer interface through a laptop. The same is true of the Pro-Flo.
yellow1098Greg
04-15-2020, 04:40 PM
I’m not sure on the handheld I’m sure you hook it to a computer even a sniper does that.....but my big concern is looking into the vacuum situation you brought up and if I need to run a different cam because of it And the biggest for pontiacs is the dam intakes available
04-15-2020, 06:02 PM
You can usually run more cam than compared to a carburetor and still be streetable.
This is where open and closed loop tuning comes into play. This can also be blended for idle and off-idle transitions.
andrewb70
04-15-2020, 06:11 PM
I've recently tuned a Pontiac engine with Holley EFI, a throttle body system. It has a pretty rowdy camshaft and idles around 72-84 kPa. The trick is to rescale the load axis and get more resolution in the area where the engine actually operates.
yellow1098Greg
04-17-2020, 02:33 PM
I’m definitely looking for rowdy! My real problem is the intake and port matching from butler now...unless you guys know of anywhere that can add those efi bungs at a decent price after the fact
andrewb70
04-17-2020, 02:37 PM
You don't want too rowdy with EFI. If you can get 15in of vacuum, that would be optimal. There are many multiport Pontiac manifolds on the market.
yellow1098Greg
04-17-2020, 05:31 PM
so here’s the issue my friend....my heads are going to be aluminum 340cfm and that doesn’t go well with the smaller cheaper intakes I’m told by butler because of port matching....such as the speedmaster (old tomahawk) and the toker 2.....so I only have the option of the super Victor that they sell with efi bungs but that doesn’t fit well with my shaker hood...now I could go with a northwind but I have to pay like an extra 700 to get the bungs welded on......the reason I need to get the intake from butler is I really wanna make sure my intake is portmatched to the heads I’m gonna order to get to my power goal. Definitely a hangup right now
Hammered
04-18-2020, 08:18 AM
Sounds like you need to pay the money or revise your goal. At 650HP, I suspect you're already at a higher level of parts, like a forged crank for example, so another $700 shouldn't be a deal killer as hard as it is to swallow. Alternatively, you could add some weld to the roof of the T2 or Speedmaster runners. That may be less expensive than doing the bungs.
BTW, my engine makes about 10" of vacuum and I can idle it at 650-700 rpm if I want and it's very streetable.
yellow1098Greg
04-18-2020, 08:23 AM
good point haha I think your right....the theme that get us all......”well iv come this far”
OLDFLM
04-20-2020, 08:27 AM
I'd get a Speedmaster that already has the bungs and have the tops of the runners welded and then simply use 120x240 gaskets and port match the intake yourself after having the tops of the runners welded for more height.
PonchoJohn
08-26-2020, 02:26 PM
I know this thread seems to have lost momentum, but I've been contemplating the Terminator X vs MS3Pro Ultimate lately for a 400/5 speed combo...
The 'universal' Term X kit should work if you add a 24x or 58x reluctor wheel for a crank position sensor.
The cam sensor can be purchased through Luhn Performance in Wisconsin, or you can make one from an old distributor and a Hall Effect sensor(well, I'm hoping the Holley can use that setup), or Holley markets a dual sync dist. that can kill multiple birds for you...
For me, I have an Offy 2x4 intake, a Holley LS 2x4 adapter lower, and will be sourcing a 105mm top, and a tapered 105mm throttle body (unless the math shows that a 92mm setup will work, because that's WAY cheaper on the wallet).
I also have LS truck coils. I'm hoping I can emulate what the ECU wants for an LS, or that the Term X will be able to understand what I'm doing and run with it (no pun intended) because the MS3 can.
08-26-2020, 05:17 PM
Any stock HEI can be locked out and used for a sensor. You would need to convert the module to a 7-pin which feeds the computer a signal and controls timing. Holley or Megasquirt can control a computer HEI module.
andrewb70
08-26-2020, 06:26 PM
All of this can be done, just depends on how much adaptation you want to do. You don't need to run a 24 or 58 tooth wheel on the crank. You can do a crank trigger.
PonchoJohn
08-27-2020, 07:35 AM
- - - Updated - - -
Large cap HEI won't work with a 2x4 intake, plus I want it as short as possible to clear the 2x4 Holley adapter, but that's nice info to know about doing a 7 pin module conversion.
PonchoJohn
08-27-2020, 07:46 AM
So the Term X can use a crank trigger? That's good to know. I was planning on making a simple crank trigger if I went MS3.
Can the Term X recognize an on/off cam sensor- imagine using the distributor with a 180* solid trigger wheel??
If so, the Term X sounds like a no-brainer to me- That's a LOT of stuff for $1,000!!
andrewb70
08-27-2020, 09:01 AM
I suggest that you download the installation manuals for the Terminator X systems, both the universal as well as the LS specific. You should also download the terminator X software and go through the various options in the System ICF of all the available ignition options. There is a ton of available information in those manuals and also in the "help" file that comes with the software. I also have a couple of videos that go over the terminator X software:
https://www.youtube.com/watch?v=v5Otn-AyncE&t=10s
PonchoJohn
08-27-2020, 09:52 AM
Very cool- Thanks, I will do that!
yellow1098Greg
09-17-2020, 08:35 PM
Thanks for bringing this one back...alittle update I went with the northwind and will send it out for bungs....I wasn’t familiar with the crank trigger part also
My427stang
09-23-2020, 05:57 AM
This is a good thread, I'll be jumping into the X information for a 462 FE with an 8-stack TB system, build will be a common combo I do, 15 inches of vacuum, 550 HP/595 ft lbs with a 780 vac sec QFT carb, peaks at 5750, but the owner wants fancy :)
I have used a few different carb-style TBs and EEC-IV adaptation on my own car, but looking forward to digging into the X
yellow1098Greg
09-28-2020, 12:49 PM
So am I!!! Another question I have which Throttle body would you guys use with the termi X?
andrewb70
09-28-2020, 01:00 PM
Holley makes very nice die cast TBs:
https://www.holley.com/products/fuel_systems/fuel_injection/throttle_bodies/4_bbl_throttle_bodies/parts/112-588
They come in other colors as well.
yellow1098Greg
09-28-2020, 01:07 PM
Thank you! Those are great options !
