View Full Version : Which bulb socket ?
Motown 454
04-03-2020, 03:13 PM
Hi I've been trying to figure where to get a bulb socket to fit in these metal under dash courtesy light brackets.
https://static1.pt-content.com/images/pt/2020/04/sl500jpg20courtesy20light20bracket_zpste-1.jpg (https://s172.photobucket.com/user/Hardcore454/media/Dash%20and%20Interior/s-l500.jpg%20courtesy%20light%20bracket_zpsteml1ybr. jpg.html)
Factory holds a 631 bulb, I tried using that to search. I tried by size of the hole it clips in. I guess I'm loosing my touch with being locked up here. Any help will be appreciated. LED or regular bulb. Can't just run to the Autozone to find a fit.
NDubs68
04-10-2020, 01:26 PM
It looks like napa#LS6542 would fit. Socket grounds through the bracket and has a single wire lead
Motown 454
04-10-2020, 02:06 PM
Thank you!
NDubs68
04-10-2020, 05:56 PM
Thank you!
You’re very welcome. Here is a link to the quick reference we used to use in case you might need other connectors. There’s alot more if the store has the old illustrated guide. https://www.napaechlin.com/media/2951/ne11211-illustrated-connect-guide.pdf
