View Full Version : 1970 AMC big bad blue Mark Donohue javelin
5spd540
03-22-2020, 01:39 PM
This is my new project 173930
egoman
03-22-2020, 04:46 PM
Love that! Tell us your plans and how far you are willing to go. We are enablers, we wont say that it cant be done LOL
Jaymzz
03-22-2020, 04:48 PM
Nice always have loved the Javelin's!
5spd540
03-22-2020, 10:52 PM
Plan is to take it apart have it dustless blasted. Put big brakes on it. Put a 4link and front tubular suspension. About 425-500 hp 401 in front of a tremec 5speed. Pro touring build. Car will be big bad blue base clear. Let me know if you want other details.
5spd540
03-24-2020, 12:50 PM
Week 1 of work floors very solid. So that’s a good thing
173982
tonyuh60
03-26-2020, 02:12 AM
Awesome starting point. Car looks to be in great shape. I'l be following your build closely as I just started my 73 Javelin tear down.
5spd540
03-26-2020, 03:56 AM
car is tore down ready for blaster now.
174076
Zspoiler
03-26-2020, 05:26 AM
Back in 1978-9 a friend of mine had a car just like this one .I was an interesting era when these were around . Are you going to paint it in the same colors ?
5spd540
03-26-2020, 05:54 AM
​yes the car will be going back big bad blue like it was born with
5spd540
03-26-2020, 03:21 PM
car at the blaster now. Doing dustless blasting
174101
5spd540
03-27-2020, 05:30 PM
Car is blasted and in the shop ready for rust repair
5spd540
03-28-2020, 09:29 AM
174159
Peanut1959
03-28-2020, 03:46 PM
Whats in the water, today? This is the second AMC build I've stumbled on in less than 10 minutes. Love those offbeat rides! Subscribed!
5spd540
04-11-2020, 12:16 PM
174659
car all in epoxy now. Need to start bodywork
454bug
04-11-2020, 07:35 PM
Sweet project!
I’ve always loved the Javelins. One of my college buddies owns George Follmer’s ‘68 Trans Am Javelin. Same blue on the front 1/3 of the car.
https://static1.pt-content.com/images/pt/2020/04/Javelin3_zps1enngkiv-1.jpg (https://s241.photobucket.com/user/454bug/media/Javelin%20pictures/Javelin3_zps1enngkiv.jpg.html)
Looking forward to your updates! :cheers:
5spd540
04-15-2020, 03:03 PM
174771
4 link going in
tonyuh60
04-16-2020, 06:29 PM
Did you use the CFS 4 link?
5spd540
04-17-2020, 12:50 AM
Yes I used control freak suspension front and rear. I have not installed it all yet. Want to get all the welding before I paint the car. Car is ready for bodywork.
5spd540
04-17-2020, 12:55 AM
174877174878
here are a few pics on where I am on it now. Should finish up rear today
tonyuh60
04-17-2020, 03:10 AM
I’m waiting for mine to arrive. Using the same system. I may need to PM you to ask you some questions about the install if that’s ok with you.
What rear are you using?
Did you go with the F&R sway bars?
5spd540
04-17-2020, 03:57 AM
No sway rear sway bar for now want to see how it acts. Yes ask anything you need to. It’s not too bad to install. Just so you know all the parts you need are there but I bought roller thrust bearings for my shocks.
dapalong
04-17-2020, 08:19 AM
Love the 70 Javelins! Looks like a pretty solid car to start with. The trunk gutters are always rusted!
5spd540
04-17-2020, 02:52 PM
174892174893
4 link done. Not a bad job at all. Only took about 12 hours
68Formula
04-19-2020, 05:43 PM
Sure do! Speaking from experience.
68Formula
04-19-2020, 05:46 PM
Very cool. First one I've seen on a Model 20!
5spd540
04-22-2020, 11:51 AM
Back to bodywork. Should have all the bad cut out today.
Zspoiler
04-22-2020, 01:43 PM
Those are neet cars .A friend of mine had a 1969 AMX 304 4 speed and the same color .While I stationed at Camp Pendleton California .I have also seen one of Donohue Tran Am cars at Seattle International /Pacific Raceway during the Vintage Races .
tonyuh60
04-24-2020, 04:49 AM
Looks fantastic. Thanks for the tip on the thrust bearings, ordered. I get my CF suspension in 3 weeks and the fun begins.
5spd540
04-24-2020, 08:47 AM
I need to give you my phone number cause their kits suck.
5spd540
04-25-2020, 12:03 PM
175201
started fitting the tko trans
tonyuh60
04-26-2020, 06:32 PM
what’s going on with it?
5spd540
04-27-2020, 12:20 AM
All this is the front issues.
The ball joints are different sizes on uppers from side to side. The lower joint on one side was drilled for a grease fitting the other side was not . The upper driver hole to put the 15/16 socket through to torque the bolt is not large enough to pass the socket through. The grease fittings are different angles for no reason and I called and he said it was luck of the draw. The grease fitting are different sizes some were too small for the drilled holes. Put your fittings in before you install them. There are a bitch to put In after the stuff is installed ask me how I know. The rear seems to be good.
5spd540
04-29-2020, 12:18 PM
175379
Welded up a hole or 70 in the engine compartment
5spd540
04-30-2020, 12:04 PM
Finished welding all the unneeded holes in the engine compartment and all the one for all the marker lights and the badges. Finished welding so now can finish blasting it. 175448
syborg tt
04-30-2020, 05:59 PM
175379
Okay that made me laugh. I felt the same way on the firewall on my 70 and I had to do was mark then with blue tape.
5spd540
05-01-2020, 01:23 AM
The tape was the only holes I wanted to save
5spd540
05-04-2020, 11:42 AM
Just so people that have not tried it don’t ever try to build a set of headers. Now I know why they are 1500$ and up for a set. I have about 40 hours in mine and still about half left to do on one side. I have the driver side done. 1 7/8 primary and 3.5 collectors.
syborg tt
05-06-2020, 06:34 AM
I watched Dave build the header & exhaust for the Syborg truck and was just blown away at how easy he made it look.
It's not and I commend you for doing your own.
5spd540
05-06-2020, 01:33 PM
i sent them out today for coating so should have them back in a month I would guess with shipping both ways
5spd540
12-04-2022, 03:39 PM
203879
thumper877
12-04-2022, 05:57 PM
So badass love that color we need some more pics. Beautiful job
203879
Mikey97D
12-05-2022, 05:23 AM
Agreed!!! More pics please!
Turbobuick
12-05-2022, 08:33 AM
Looks great nice update!
eversaul86
12-05-2022, 04:49 PM
Love the color! Can’t wait to see the progress. Yes, more pics please!
Martin
5spd540
12-07-2022, 01:54 PM
I have 1250 pics of this car so let me know what you guys want to see and I will post a few pics
thumper877
12-07-2022, 04:42 PM
Show some from the side. Only 1250 :)
5spd540
12-08-2022, 12:58 AM
203964203965203966203967203968[attach=config]203969
thumper877
12-08-2022, 04:27 AM
Such a cool car. I almost did my camaro this color. Seeing ur pics it would of looked good. What is that paint code? I may paint my Blazer soon. Did they spray it over a white base?
NCSU68
12-08-2022, 04:33 AM
Very Nice. Do you have the Donohue signature for the rear spoiler?
5spd540
12-08-2022, 06:46 AM
Its AMC big bad blue.
5spd540
12-08-2022, 10:14 AM
204008204007204009
813Demon340
01-10-2023, 07:47 PM
Your car is a stunner! I love how you tucked the bumpers in. Are you going to use the stock electric wiper set up or do something custom?
5spd540
01-14-2023, 03:51 AM
Going with a factory unit I guess. I never really thought about a custom unit of any type.
5spd540
09-02-2024, 02:40 AM
Car been in its bubble show case waiting its turn. Too much business to work on my own car. Too busy working on others.
813Demon340
09-02-2024, 06:55 PM
I feel your pain!
